Chevy Silverado transmission issues depend on which truck you’re looking at. Certain 2020–2022 Duramax trucks had a recall for possible rear-wheel lockup. Some older Silverado 1500s with the eight-speed had a different problem: a shudder under light throttle. And the six-speed has service bulletins of its own.
Shopping for a 2019–2026 Silverado 1500? Start with Aaron Turpen’s 2019–2026 Chevy Silverado 1500 transmission problems guide for a closer look at each transmission.
Before writing off a model year, get the VIN and ask a Chevy dealer to confirm the original engine and transmission codes. Two trucks with the same year and trim can have different equipment. Here’s what to check before buying.
Silverado 1500 eight-speed: Test for a shudder at steady speed
GM bulletin 18-NA-355 covers certain 2015–2018 Silverado trucks equipped with the M5U or M5X eight-speed. A separate bulletin, 19-NA-121, lists new-generation Silverado 1500s with the MQE eight-speed and the 2.7-liter turbo or 5.3-liter V8 built through March 1, 2019. Both describe a vibration that can feel like driving on rumble strips even when the truck isn’t changing gears.
Drive it once the transmission is warm. On smooth pavement, use light throttle at a steady, legal speed and note any repeated vibration. Ask for the repair order if the seller says the fluid was exchanged. If it still shudders, get a diagnosis before buying. GM’s guidance for 2023–2025 2.7-liter eight-speed trucks points out that a similar sensation can come from the engine. See our report on GM’s newer eight-speed diagnostic procedure.
Silverado 1500 six-speed: Ask what caused the surge
GM bulletin 20-NA-142 lists applicable 2015–2018 Silverados, 2019 Silverado LDs, 2019–2021 new-model Silverado 1500s and 2022 Silverado 1500 LTDs with the specified six-speed. It describes surging that a technician may trace to the torque converter.
The bulletin’s repair path depends on mileage and diagnosis. Don’t assume the service outlined for an eight-speed will fix a six-speed. If there was a repair, ask whether the shop changed fluid, replaced the converter or did something else, and whether the problem returned.
Silverado 1500 ten-speed: Check diesel recalls and gas repair records
The biggest safety check is recall 24V-797, which includes certain 2020–2022 diesel Silverado 1500s. A worn transmission control valve can lead to harsh shifts and, in rare cases, momentary rear-wheel lockup. Dealers install software that monitors for wear; the update itself does not replace the valve body. GM also issued follow-up recall 26V-083 for certain trucks that may not have been repaired correctly the first time. We covered the incorrectly installed software update when GM issued the follow-up. Check both by VIN, and ask whether GM’s separate coverage for valve-body wear applies.
Gas Silverado 1500s weren’t included in that diesel recall. They can still have different issues: bulletin 24-NA-181 addresses a loss of reverse or a transmission that won’t shift past third on certain 2024 5.3-liter trucks with the MHT transmission. That bulletin doesn’t establish how often the problem occurs. For the redesigned truck, see our 2027 Silverado first drive. A short drive can tell you how it shifts today, not how it will hold up.
Silverado 2500HD and 3500HD: Check the diesel VIN before buying
The same 24V-797 campaign also includes certain 2020–2022 Duramax Silverado 2500HD and 3500HD trucks. The 2026 follow-up lists only certain 2020 HDs, not every HD in the original recall. Chevy started pairing the HD’s 6.6-liter gas V8 with a ten-speed for 2024, but the same number of gears doesn’t put those gas trucks in the earlier diesel recall. On a 2024 Silverado HD, a separate GM bulletin, 24-NA-211, addresses a harsh seventh-to-eighth upshift at about 40–50 mph on trucks with the listed transmissions. The remedy is a calibration update, not the older diesel recall. See our Silverado 2500HD known-issues guide for the newer trucks.
For any Silverado, look up open recalls at NHTSA and get the dealer’s repair history. If it regularly bangs into gear, slips or loses reverse, have it inspected before making an offer. A clean recall check can’t explain a symptom you felt yourself.
