2027 GM 8.3L Duramax: 555 hp, 1,230 lb-ft and a whole new diesel
September 24, 2026
GM’s new 8.3-liter Duramax on display with an engineer at the powertrain event.
GM’s new 8.3-liter Duramax on display with an engineer at the powertrain event. (Video still: Tim Esterdahl)
GM’s new 8.3L Duramax is a big engine, and I mean that literally. Walking around the display at GM’s powertrain event, I wanted to get past the headline numbers and see what truck owners will actually be living with: the pumps, cooling system, oil checks and exhaust hardware. There is a lot more here than a bigger displacement badge.
The available diesel arrives in the 2027 Chevrolet Silverado HD and GMC Sierra HD with 555 horsepower and 1,230 pound-feet of torque. GM describes those figures as best in class. The company says the updated trucks will reach U.S. dealers beginning in late 2026, with pricing still to come. Here are the four things that stood out during my conversation with GM.
A new 8.3L Duramax built around low-rpm torque
GM explains the redesigned Duramax and its low-rpm torque.
GM explains the redesigned Duramax and its low-rpm torque. (Video still: Tim Esterdahl)
The engineer’s explanation started with water-to-air intercooling and the shorter path the pressurized air takes into the engine. He said the new diesel reaches its full torque at 1,400 rpm, compared with 1,600 rpm for the outgoing engine. For someone pulling a heavy trailer, where that torque arrives is worth paying attention to alongside the peak number.
GM describes this as its first clean-sheet HD V8 designed, developed and manufactured in-house for heavy-duty pickup use. The release lists a compacted graphite iron block, a forged crankshaft and connecting rods, steel pistons and a variable-geometry turbocharger. It will be built at the expanded DMAX plant in Brookville, Ohio. This is an engine walk-around, so I still want to see how all of that feels with a trailer behind the truck.
Gear-driven pumps, an oil sensor and a dipstick
A close look at the diesel’s oil-fill and service hardware.
A close look at the diesel’s oil-fill and service hardware. (Video still: Tim Esterdahl)
One of my first questions was about the parts owners will service. The engineer showed me the gear-driven fuel and water pumps, then explained the gear-driven oil pump on the back of the engine. He also pointed out the oil separator, spin-on oil filter, aluminum oil pan and conventional drain plug. Those are details I know many of you look for before shopping for a truck.
And yes, this diesel has a dipstick. It also has an oil-level sensor, so owners get both an electronic reading and a traditional way to check the oil. That is a different setup from the updated HD gas V8 and the new light-duty V8s we have been covering. In the interview, the engineer pointed to 15W-40 on the diesel’s oil-fill information.
Two DEF injectors and more control over regeneration
The new Duramax’s engine hardware during the technical walk-around.
The new Duramax’s engine hardware during the technical walk-around. (Video still: Tim Esterdahl)
We walked over to the exhaust hardware because I wanted to understand what had changed there, too. The engineer described two diesel exhaust fluid injectors, the diesel oxidation catalyst, the particulate filter and the selective catalytic reduction hardware. He also corrected my assumption that one large section was a muffler. It was part of the aftertreatment system.
For owners, the more interesting discussion may be regeneration. GM says the new system allows a driver to manually initiate a regeneration while driving or idling. The engineer also highlighted lower-temperature regeneration and more information through the dash. I asked whether two injectors would mean more DEF consumption, but he was not certain, so I do not have a confirmed consumption figure to give you. Better long-term reliability is what I want to see; that will take real-world use to judge.
The engine is only part of the HD update
GM points out components on the new 8.3-liter Duramax.
GM points out components on the new 8.3-liter Duramax. (Video still: Tim Esterdahl)
GM pairs the new diesel with an Allison 10-speed automatic and says the HD updates also include upgraded exhaust braking, rack-and-pinion electric power steering and electronic brake boost. The new steering and braking systems are intended to make these big trucks more consistent and easier to control. There is also a new Terrain mode for the Silverado ZR2 and Sierra AT4X.
The release lists maximum available conventional towing of 20,000 pounds and gooseneck towing of 38,000 pounds on properly equipped trucks. Those are lineup maximums, not ratings for every cab, axle, trim or engine combination. I am interested in the big numbers, but I am just as interested in how this truck launches a trailer, manages heat and handles regeneration after years of work. That is where this new Duramax will have to prove itself.
