What is this? 2027 Toyota Tundra Raptor fighter spied
July 30, 2025
2027 Toyota Tundra Raptor fighter 1
What is Toyota working on? Could it be the much desired Raptor fighter? (Photo courtesy KGP)
For years, Toyota fans have asked for it and now there is a 2027 Toyota Tundra Raptor fighter driving around. Is this truck coming soon?
Our spy photographer captured photos of this truck driving around and while it is definitely a test mule showing off what they could be working on for a full model refresh after the changes for the 2026 model are now official. Here’s what the spy photographer had to say.
The basics with 2027 Toyota Tundra Raptor fighter
2027 Toyota Tundra Raptor fighter 2
The up close view of the front end reveals a lot of modifications. (Photo courtesy KGP)
The truck appears to be a mix of trims, but with big body modifications.  There are Limited badges on the rear doors, but the hood says its a TRD Pro.  The tailgate reads “TUNDRA”, instead of the standard TRD Pro tailgate, which normally reads, well,  “TRD Pro.”  The mix suggests that this might be a mule being studied by Toyota engineers for production feasibility, or PR purposes. If you like the look of a truck and want to run a vehicle lookup, you can enter the registration into a car check site. This instant history check will pull up a heap of information, such as the make, model, and type of vehicle, and much more. Please note that this registration lookup will only work in the UK.
Is it camouflaged?
2027 Toyota Tundra Raptor fighter 3
Another oddity is the colorful camouflage on the truck breaking with Toyota’s traditional black and white design. (Photo courtesy KGP)
The Tundra in question is wearing proper manufacturer “M” plates, and has a colorful graphic wrap pattern covering its obviously widened front and rear fenders.  It’s not Toyota’s usual black-and-white graphic camouflage, but it still manages to obscure some of the surface development details.  So the question is:  Is this stylized wrap simply an eye-catching design element, or is it possible that the goal of this wrap is to look like a customized off-road truck while still managing to obscure some of the styling—essentially hiding in plain sight?
Wide body design
2027 Toyota Tundra Raptor fighter 4
The bulging fenders are a trademark of the Ford Raptor and Ram RHO and not something Toyota has for the Tundra. (Photo courtesy KGP)
There are some aftermarket wide body kits for the third-generation Tundra, but nothing we could find online matched what we see in these photos.  Our admittedly compromised front-3/4 shot (snapped from the driver’s window as the Tundra surprised us as it came around a corner) leaves some details in questions.  This Toyota test truck has a completely reworked front bumper.  There may be some pieces not installed, like a front skid-plate, but its clear that the new front bumper set-up yields loads of clearance and an excellent approach angle.
Front fender vents, wide rear too
2027 Toyota Tundra Raptor fighter 7
This prototype is making use of a lift kit to fit these larger tires. (Photo courtesy KGP)
This Tundra has thoughtfully integrated front-fender vents, matching a noteworthy design trait found on both the F-150 Raptor and the Ram 1500 RHO.  We couldn’t find any aftermarket examples that shared this design detail, suggesting that this body kit is a proper Toyota effort.  This Tundra tester also has widened rear fenders to match its front.  Unfortunately, we couldn’t get any suspension or shock absorber details from our shots, but the wide body design allows for long-travel suspension capabilities to match the factory baja trucks from Ford and Ram.
Are those 37s?
2027 Toyota Tundra Raptor fighter 5
The rear end sports a new suspension setup, a unique bumper and a mix-match with the rear tailgate badge. (Photo courtesy KGP)
This Tundra was fitted with massive BF Goodrich All-Terrain T/A—the same tires fitted to the F-150 Raptor.  We couldn’t make out the size, but they look like they could be a match for the 37-inch tires available on the full-size Raptor.  The big BFGs wrap Method off-road racing wheels—namely Method 703 Bead Grip Machined-Finish wheels.
Signs of beefed-up suspension, new steel bumper
2027 Toyota Tundra Raptor fighter 6
The two images show the prototype on the left and the traditional Tundra TRD Pro on the right. (Photo courtesy KGP)
The Tundra’s multi-link, coil suspension set-up looks intact, but we can see a new, machined Panhard Rod stabilizing the rear axle.  The view is helped by the big rear-end clearance.  The rear fenders don’t dip downward as they do on the current crop of Tundras, and they integrate into a new steel rear bumper design.  Again, we couldn’t find an aftermarket match for this bumper.  The bumper doesn’t seem to have integrated plugs for power and trailer lights, so this may be a rough fabrication—a design simply to test its clearance and departure angle.
So, is this a prototype for a Tundra designed to battle the F-150 Raptor?  It certainly seems to check all the of the design boxes, and the components look legit.  It’s not traditionally camouflaged, but its wrap does complicate the lines of the new body panels.  Is it a PR effort that may be destined for the stand at this year’s SEMA show, or is it something with real production possibilities?  All we know is that it looks the business, it was returning from a test run, and it entered the safety of Toyota’s Michigan Tech Center.  Consider us intrigued.
2,850 messages 4,746 likes
For years, Toyota fans have asked for it and now there is a 2027 Toyota Tundra Raptor fighter driving around. Is this truck coming soon? Our spy photographer captured photos of this truck driving around and while it is definitely a test mule showing off what they could be working on for a full model refresh after the changes for the 2026 model are now official. Here’s what the spy photographer had to say. The basics with 2027 Toyota Tundra Raptor fighter The truck appears to be a mix of trims, but with big body modifications. There are Limited badges […] (read full article...)
Avatar of TheDo114
TheDo114
Well-known member
779 messages 1,219 likes
Come on Toyota, just do it!
