By the Mirai Trading Editorial Team
Toyota’s revived Scion brand is bringing a kei truck to America. As PUTT reported, the KEI-01 will be built in Indiana starting in the second half of 2027, with a 660cc three-cylinder, a CVT and four-wheel drive.
But Americans have been buying kei trucks for years. Used Suzuki Carrys, Honda Actys, Daihatsu Hijets, Subaru Sambars and Mitsubishi Minicabs already work on farms, hunting leases, golf courses and job sites. They come from Japan, and they are at least 25 years old.
So should a small-truck shopper wait for the new Toyota or buy an imported truck now? The two look alike, but they are regulated very differently. Here are six things to know.
1. They reach U.S. roads through completely different legal doors
The KEI-01 is engineered to meet Federal Motor Vehicle Safety Standard No. 500, the rule for low-speed vehicles (LSVs), according to Toyota. It is a new vehicle certified for a specific federal class.
An imported Japanese kei truck is not certified to U.S. safety standards at all. It enters under the 25-year exemption. NHTSA says a vehicle at least 25 years old can be imported without meeting the Federal Motor Vehicle Safety Standards, and the clock runs from the date of manufacture. EPA has a separate exemption for vehicles at least 21 years old in original, unmodified configuration.
That age test is by month, not model year. In November 2026, a truck built in November 2001 or earlier qualifies. One built in December 2001 has to wait another month.
Here is the catch: federal import eligibility says nothing about whether your state will let you drive it on the road. That decision belongs to each state.
2. Speed: 25 mph by design vs. “depends where you live”
Toyota says the KEI-01’s maximum speed will be 25 mph. That is built in, because federal rules cap LSVs at 25 mph.
A stock 660cc Japanese kei truck has no such factory limit. Expect roughly 50 to 65 mph flat out on level ground, and a more comfortable 45 to 55 mph cruise. A loaded 4WD truck with a four-speed or an automatic sits at the low end of that range.
But the speedometer is not the speed limit. State law decides where an imported mini truck can go:
- Florida lets a registered and insured mini truck use only streets posted at 35 mph or less, and lets counties and cities ban them on their roads (Fla. Stat. 316.2122).
- North Carolina allows mini trucks on roads posted at 55 mph or less (N.C.G.S. 20-121.1).
Same truck, very different usefulness. In Florida, an imported kei truck behaves a lot like a KEI-01. In North Carolina, it can cover country roads the Toyota cannot.
3. Your state may not register one at all
This is the biggest risk with an imported truck. In 2011, the American Association of Motor Vehicle Administrators issued best-practice guidance recommending that states not issue on-highway titles or unrestricted registrations to mini trucks that do not meet U.S. safety and emissions standards. It suggested ownership-only or off-road titles instead.
Some states followed that advice. Others wrote mini-truck laws like Florida’s and North Carolina’s. Several have changed their rules more than once in the past few years, and a few leave it to counties or cities.
The KEI-01 has a simpler path, because many states already have rules for federally compliant LSVs. Those rules usually limit LSVs to lower-speed roads, so check your state’s LSV law too.
Before buying either one, get your state DMV’s answer in writing for the exact vehicle, including whether it gets a road title, an off-road title or none.
4. Payload is similar, and neither is a tow vehicle
Toyota rates the KEI-01’s bed at up to 600 pounds. Japanese spec sheets for the Carry, Acty, Hijet and Sambar list a maximum cargo load of 350 kg, about 770 pounds.
Don’t confuse payload with towing. For the classic imported trucks, the Japanese makers did not publish a U.S.-style trailer rating, and a 25-year-old truck with worn brakes and old tires is not the place to guess. A light utility trailer on private land is one thing. Highway towing is another.
5. One is coming in late 2027. The others are for sale today
Toyota calls the KEI-01 an “intentionally low-volume, niche vehicle.” It will start in a fleet-focused pilot through selected Toyota dealers, with limited retail sales a possibility later. Toyota has not announced pricing.
Imported kei trucks are available now, from U.S. importers and dealers or straight from Japan. Trucks bought in Japan usually come out of the country’s large dealer auctions. An exporter buys the truck, handles the Japanese deregistration paperwork and ships it. If you are comparing models, Mirai Trading’s kei truck guide lays out the common chassis codes and engines for the five main truck families, which makes it easier to read a listing.
Two other differences matter to fleet and farm buyers. A new KEI-01 will come with Toyota dealer support. An imported truck is a used vehicle with Japanese-market parts, so ask where you will get brake parts, filters and tires before you buy. And both trucks are right-hand drive: Toyota confirms the KEI-01 is too.
6. What to check on a 25-year-old kei truck
If you go the import route, inspect it like the old work truck it is:
- Build date. Match the export certificate to the chassis plate. A truck that is not yet 25 years old by month should not be in the country.
- Auction sheet. Japanese auction houses grade each vehicle and map its dents, rust and repairs. Ask for the original sheet and a translation.
- Rust. Check the frame, bed floor, cab corners and under the floor mats. Trucks from Japan’s snowy north see road salt too.
- 4WD and low range. Make sure 4WD engages, and test the rear differential lock if the truck has one. Many work trucks do; not all.
- Tires and brakes. Old tires on a light truck are a common, cheap fix, but budget for them.
- Title paperwork. Make sure you get the export certificate, its English translation and the U.S. customs entry papers. Your DMV will want them.
The Scion KEI-01 is the safe, simple choice if you only need to move people and gear at 25 mph, and if you can wait until late 2027 and get one through Toyota’s fleet program.
An imported Japanese kei truck makes more sense if you need one now, need more than 25 mph, and live in a state that will register it for the roads you actually use. Check the law first, then the truck.
About the author
The Mirai Trading Editorial Team writes buyer guides on Japanese kei trucks and JDM imports for Mirai Trading LLC, a Japan-based exporter that sources vehicles from Japanese auctions for U.S. buyers.
Disclosure: the author works for Mirai Trading LLC, a Japan-based kei truck and JDM exporter.
