1 Million+ GM Vehicles Including Colorado, Canyon Under Investigation for Brake Failure
August 25, 2026
Chevrolet Colorado included in GM eBoost brake investigation
The Chevrolet Colorado is included in NHTSA’s expanded investigation into possible GM eBoost brake assist failures (Photo courtesy of Chevrolet)
GM brake problems are back under investigation as the National Highway Traffic Safety Administration (NHTSA) has expanded an investigation into General Motors’ eBoost brake assist system to include the Chevrolet Colorado and GMC Canyon.
The investigation now covers more than one million vehicles and focuses on reports of possible loss of brake assist caused by issues with the electro-hydraulic brake system. At this time, NHTSA has not issued a recall.
What Is NHTSA Investigating?
Chevrolet Colorado Z71
The Chevrolet Colorado is among the GM vehicles included in the expanded NHTSA eBoost brake investigation (Photo courtesy of Chevrolet)
NHTSA has escalated the case from a Preliminary Evaluation to an Engineering Analysis, designated EA26006. That is significant because an Engineering Analysis is the final investigative stage in NHTSA’s defect-investigation process before the agency can move toward formally requesting a safety recall if it determines a defect exists and the manufacturer does not voluntarily recall the vehicles.
During an Engineering Analysis, investigators can conduct deeper technical analysis, request additional information from the manufacturer and evaluate whether the suspected defect presents an unreasonable risk to motor vehicle safety. If NHTSA ultimately determines a safety-related defect exists and GM does not voluntarily act, the agency can move toward formally requesting and ultimately ordering a recall.
The scale also matters. The Engineering Analysis encompasses an estimated 1,164,820 vehicles, so a resulting recall could potentially be very large. Inclusion in the investigation, however, does not mean every vehicle being studied will necessarily be recalled.
NHTSA is examining reports involving GM’s eBoost braking system in which drivers can experience a harder brake pedal and may need additional effort to stop the vehicle. The agency is investigating whether a defect exists and whether vehicles equipped with the system require a safety recall.
Chevrolet Colorado and GMC Canyon Added to Investigation
GMC Canyon and Chevrolet Colorado
The Chevrolet Colorado and GMC Canyon share a number of components, including the eBoost brake technology being investigated by NHTSA (Photo courtesy of GM)
The third-generation Chevrolet Colorado and GMC Canyon are now part of the investigation because they use the same eBoost brake assist technology. NHTSA says EA26006 has been expanded to encompass all GM vehicles sharing this eBoost system. The GM vehicles identified by ODI are:
NHTSA is also including the 2024-2026 Honda Prologue and 2024-2026 Acura ZDX as peer vehicles because they were manufactured by GM through its joint venture with Honda and use the same eBoost system.
Owners should understand this is an investigation, not a recall. The Engineering Analysis is important precisely because it moves the case closer to a potential recall decision, but NHTSA has not yet determined that these vehicles contain a safety defect requiring one.
What Is eBoost Brake Assist?
Chevrolet Colorado ZR2 interior
Modern trucks such as the Chevrolet Colorado increasingly rely on electronically controlled systems that integrate braking with vehicle safety technology (Photo courtesy of Chevrolet)
Modern trucks are moving away from traditional vacuum brake boosters. Systems like GM’s eBoost use electronic controls and hydraulic pressure to provide braking assistance while integrating with modern safety systems.
The advantage is improved integration with features like stability control and advanced driver assistance systems. The downside is that more electronics create more potential failure points.
What Colorado and Canyon Owners Should Do
GMC Canyon AT4
GMC Canyon owners should pay attention to brake warning messages or a change in brake-pedal feel while the NHTSA investigation continues (Photo courtesy of GMC)
Owners should not panic, but they should pay attention to any brake warning lights, unusual pedal feel or changes in braking performance.
Any safety concern should be reported to NHTSA and discussed with a dealer. Pickup Truck +SUV Talk will continue following EA26006 as NHTSA determines whether the investigation results in a safety recall.
