Photo by Jon Tyson on Unsplash
A full-size pickup feels big until a loaded tractor-trailer pulls alongside. On I-35 through San Antonio or I-10 toward Houston, that happens every few minutes. Freight bound for Mexico, the Gulf ports and Dallas shares the same lanes as your daily driver.
Most truck drivers are skilled professionals, and most trips end without drama. When one goes wrong, though, the weight gap decides who gets hurt. If a crash does happen, a truck accident attorney can deal with the carrier and its insurer while you focus on recovery. The habits below aim to keep you from needing one.
Where Do Pickups and Semis Tangle Most Often?
Crash patterns between light trucks and big rigs tend to repeat. Knowing them helps you spot trouble early:
- Wide right turns. A semi swings left before turning right, and a pickup slips into the gap.
- Sudden slowdowns. Construction zones on I-35 can drop traffic from 70 to 20 in seconds.
- Lane changes into hidden zones. The truck driver checks a mirror that does not show you.
- Merges near interchanges. Short ramps force fast decisions with little room.
- Rear underride. A low pickup hood can slide under a trailer’s back end.
How Big Are a Semi’s Blind Spots?
Truck safety programs call these areas “No-Zones.” Federal guidance commonly describes four of them. The front zone runs about 20 feet ahead of the cab. The rear zone stretches roughly 30 feet behind the trailer.
The side zones are the ones pickups drift into. The left zone sits just behind the driver’s door. The right zone is larger and can cover two full lanes.
A simple test works on any interstate. If you cannot see the trucker’s face in their side mirror, they cannot see you. The Operation Safe Driver program run by the Commercial Vehicle Safety Alliance targets exactly these behaviors from both car and truck drivers.
What Does Texas Law Say About Spacing?
Texas sets spacing rules in Chapter 545 of the Transportation Code. Section 545.062 requires a driver following another vehicle to keep an “assured clear distance” to stop safely. That duty applies to you as much as to the trucker.
Photo by Nick Cheng on Unsplash
Alt text: car side mirror showing mountain range
The same section adds a rule for trucks outside towns. When conditions permit, a truck following another truck must leave room for a passing vehicle to enter safely. In practice, that gap is room for you, not an invitation to linger.
Passing has its own rules too. Pass on the left, then wait until you can see the whole cab in your mirror before moving back. Never cut in and brake, since a loaded rig cannot stop like your half-ton.
Does Your Pickup’s Tech Cover the Gaps?
Modern trucks carry blind-spot monitors, lane-keeping and adaptive cruise. These help, but each has limits worth knowing. A piece on pickup ADAS on highways makes the point that signaling early gives these systems time to react.
Watch for these weak spots:
- Blind-spot radar may not track a long trailer that keeps rolling past.
- Adaptive cruise can close a gap too fast when a semi slows on a grade.
- Rain, mud and road film can blind cameras and sensors without warning.
- Towing your own trailer stretches your stopping distance and your blind zones.
Treat alerts as a backup. Your mirrors and a head check stay the main tools.
Load matters as much as tech. A bed full of gravel or a camper on the hitch adds weight your brakes must handle. Leave a longer gap behind a semi when you are heavy, and start braking earlier on downgrades. A trucker watching a loaded pickup in the mirror cannot guess how quickly it will stop.
What Should You Record After a Crash With a Commercial Truck?
Truck crashes generate records that disappear fast. Engine data and electronic logs can be overwritten once the rig returns to service. If you can do so safely, collect these details at the scene:
- The USDOT number painted on the cab door
- The carrier name and the trailer number
- The driver’s name, license and insurance details
- Photos of all vehicles, skid marks and debris
- Your own dash cam footage, saved before it loops
- Names and numbers of anyone who stopped to help
Investigators reconstruct these crashes in detail. A breakdown of what investigators look for when a semi fails to stop shows how brakes, speed and logbooks all get checked.
Why Is a Truck Claim Harder Than a Car Claim?
A crash with another pickup usually involves one driver and one insurer. A commercial truck can bring in several parties at once. The driver, the carrier, a freight broker and a repair shop may each share blame.
Texas fault rules raise the stakes further. If you are found more than half responsible, you recover nothing. The clock for filing a lawsuit is short as well, at two years in most cases. Carriers often send their own investigators within hours, so early notes matter.
Stay Visible, Keep Records
Give big rigs space, avoid the No-Zones and pass with purpose. Keep a dash cam running and know which details to grab. Those two habits protect both your truck and your claim.
Frequently Asked Questions
How Far Back Should You Stay Behind a Semi?
Stay far enough back to see both of the truck’s side mirrors. Add extra space in rain or when towing. Texas law requires a distance that lets you stop safely.
Is It Safer to Pass a Truck On the Left?
Yes, the left-side blind zone is smaller than the right one. Pass steadily without lingering beside the trailer. Move back only when the whole cab shows in your mirror.
What Is a USDOT Number and Why Does It Matter?
It is the carrier’s federal registration number, painted on the truck. It identifies the company responsible for the vehicle. Photograph it at the scene.
Who Pays After a Crash With an 18-Wheeler In Texas?
Payment normally comes from the insurance behind whoever caused the wreck. That may be the driver’s carrier or another company in the chain. Any blame placed on you cuts the amount, and a majority share wipes it out.
