2023-2026 Chevrolet Colorado Known Problems: Emergency Braking, Seat Belt Fails, Coolant Leaks, and More
Aaron Turpen
Aaron Turpen
June 22, 2026
Chevy Colorado lemon bent frame
The Colorado is Chevrolet’s midsized pickup truck competing in a growing market of smaller truck options. First appearing in 2004, the Colorado entered its third generation in 2023. It’s sold steadily as a popular choice against rivals like the Toyota Tacoma, but the Chevrolet Colorado isn’t without its own known issues.
Major Recalls for the Colorado
2024 Chevy Colorado Desert Boss
Chevy Colorado Desert Boss is included in these issues (Photo courtesy Chevrolet)
This new generation of the Colorado has had a few official recalls, mostly for the 2023 model.
Automatic Emergency Braking (AEB) (Recall 23V116/A232424660): Affecting certain 2023 models, the front camera module can falsely detect an obstacle and cause the truck to brake or slow down unexpectedly.
Front Seat Belt Bolts (Recall 24V703000): Affecting 2023–2024 models, the left or right front seat belt buckle attachment bolts may have been improperly tightened at the factory.
Fuel Pump Lock Ring (Recall 24V-491 / N242451330): Affecting 2024 models, the lock ring securing the fuel pump to the tank may not have been fully engaged, potentially causing a fuel leak in a crash.
Colorado’s Technical Service Bulletins
2024 Chevrolet Colorado ZR2 Bison Suspension (Photo Courtesy of Chevrolet)
Technical service bulletins (TSBs) are service-related bulletins to dealerships and shop technicians regarding known issues and how to properly address them.
Coolant Leaks (TSB PIT6494): Many 2023–2026 Colorados experience dropping coolant levels or visible puddles. This is typically caused by degraded O-ring seals at the upper radiator inlet hose’s quick-connect fitting. General Motors has a documented repair that involves replacing the upper radiator hose.
Roof “Oil Canning” or Dents (TSB 6484171): For 2023-2024 models, the roof sheet metal can flex and buckle during automatic car washes, causing dents. GM provides a repair process where dealers drop the headliner and install a reinforcement crossbar inside the roof to stabilize the sheet metal. For vehicles manufactured after February 2025, this is factory-addressed.
Transmission Shifts & Clunking (TSB 23-NA-010): Some owners have experienced harsh downshifts, going into limp mode, or a noticeable clunking sound (especially in ZR2 leaf spring configurations). The TSB recommends software reflashes for the Transmission Control Module (TCM), valve body replacements, or installing rubber isolator pads in the rear leaf spring packs.
Front Hub / Wheel Bearing Noise (TSB 25-NA-218): A distinct clicking noise from the front wheel area is sometimes a reported symptom. Replacement of the front hub assembly and bolts on both sides is the fix.
Chevrolet Colorado Known Issues
2023 chevrolet colorado (6)
2023 Colorado engine bay (Photo by Aaron Turpen)
These are the most commonly cited known issues found commonly in owner’s forums, consumer chats, technician groups, and social media for the Colorado.
Transmission Shifting & Valve Body Failures: Some owners have experienced harsh shifting, codes, or in severe cases, transmission failure (valve body issues) requiring repair under the bumper-to-bumper warranty for the 8-speed automatic transmission.
Electronics & Missing Manuals: Several minor campaigns and recalls have been issued for vehicles missing electronic owner’s manuals or experiencing issues with USB receptacles/cellphone charging ports.
How To Check For Recalls On Your Truck
nhtsa recall search page
NHTSA Recall Search Page (Screen capture)
The easiest way to check for current recalls that may affect your Chevy Colorado is to visit the National Highway Transportation Safety Administration (NHTSA) Recalls page and enter your license plate or 17-digit vehicle identification number (VIN) to run a search. You can also do this at the GM Owner Center.
No replies yet
2,834 messages 4,724 likes
The Colorado is Chevrolet’s midsized pickup truck competing in a growing market of smaller truck options. First appearing in 2004, the Colorado entered its third generation in 2023. It’s sold steadily as a popular choice against rivals like the Toyota Tacoma, but the Chevrolet Colorado isn’t without its own known issues. Major Recalls for the Colorado This new generation of the Colorado has had a few official recalls, mostly for the 2023 model. Automatic Emergency Braking (AEB) (Recall 23V116/A232424660): Affecting certain 2023 models, the front camera module can falsely detect an obstacle and cause the truck to brake or slow down […] (read full article...)
