2023 GMC Canyon vs. Chevy Colorado spec-by-spec comparison
May 3, 2023
Elevation trim
General Motors redesigned both of its midsize trucks this year, and with a $7,700 price difference (base to base), a lot of people are wondering just how different these two trucks are. If you take a look at the 2023 GMC Canyon vs. Chevy Colorado spec-by-spec comparison (below), there are a couple of stand-out differences, but the two trucks are largely identical.
The engine
The biggest and most obvious difference is going to be the engine output. Though both trucks have the same 2.7-liter I-4 turbo, they are tuned differently. The GMC Canyon comes standard with the high-output version, whereas the Chevy Colorado offers three options. The top-tier option for the Colorado is the same as the base Canyon.
Other than that, the valvetrain, fuel delivery, transmission and gear ratios are identical.
2023 Chevy Colorado
Off-road specs
Another notable difference will be in the off-road numbers. The GMC Canyon at a base level will have 2 extra inches of ground clearance over the Chevy Colorado. Approach and breakover angles are also better for Canyon base to base.
Curiously, the Colorado ZR2 trim has slightly better numbers than the Canyon AT4X trim. You’d have though GM would have swapped that.
Capacities
Another interesting spec comparison comes when looking at the weights, towing and payloads. The GMC Canyon is actually a little lighter than the Chevy Colorado, which means its GVWR and payload are also less. Towing, interestingly, is mostly the same.
2023 GMC Canyon vs. Chevy Colorado complete specs
2023 GMC Canyon 2023 Chevy Colorado
Price range: $38,395 – $56,995 $30,695 – $48,295
Engine Type: 2.7L I-4 Turbo DOHC VVT DI with Active Fuel Management and Stop/Start 2.7L I-4 Turbo DOHC VVT DI with Active Fuel Management and Stop/Start
Bore & Stroke (in. / mm): 3.63 x 4.01 / 92.25 x 102 3.63 x 4.01 / 92.25 x 102
Valvetrain: Dual-overhead camshafts, four-valves per cylinder, tripower valvetrain with continuously variable valve timing, variable valve lift and Active Fuel Management Dual-overhead camshafts, four-valves per cylinder, tripower valvetrain with continuously variable valve timing, variable valve lift and Active Fuel Management
Fuel Delivery: Direct high-pressure fuel injection with Active Fuel Management Direct high-pressure fuel injection with Active Fuel Management
Horsepower: 310 Base: 237; Mid & High: 310
Torque (lb-ft / Nm @ rpm): 430 Base: 259; Mid: 390; High: 430
Transmission Type: Hydra-Matic 8L80 eight-speed automatic Hydra-Matic 8L80 Gen II eight-speed automatic
Gear Ratios (:1)
First: 4.5599999999999996 4.5599999999999996
Second: 2.97 2.97
Third: 2.08 2.08
Fourth: 1.69 1.69
Fifth: 1.27 1.27
Sixth: 1 1
Seventh: 0.85 0.85
Eighth: 0.65 0.65
Reverse: 3.82 3.82
Final Drive Ratio: 3.42 3.42
Front Suspension: 2WD and 4WD: independent coil-over-shock; twin-tube shocks; Multimatic DSSV dampers on AT4X 2WD and 4WD: independent coil-over-shock; twin-tube shocks; Multimatic DSSV dampers on ZR2
Rear Suspension: Solid axle with semi-elliptic two-stage multi-leaf springs; twin-tube shocks; Multimatic DSSV dampers on AT4X Solid axle with semi-elliptic two-stage multi-leaf springs; twin-tube shocks; Multimatic DSSV dampers on ZR2
Rear axle: Open differential (std. Elevation); Limited-slip differential (std. AT4 & Denali); Power-locking front and rear differentials (std. AT4X) Open differential (std. WT and LT); G80 limited-slip differential (std. Trail Boss & Z71); Power-locking front and rear differentials (std. ZR2)
Steering Type: Electric power-assisted rack-and-pinion Electric power-assisted rack-and-pinion
Brake Type: Power-assisted four-wheel discs with Duralife™ long-life brake rotors; standard ABS; hill descent control available (std. AT4 & AT4X) Power-assisted four-wheel discs with Duralife™ long-life brake rotors; standard ABS; hill descent control available (std. Trail Boss & Z71)
Brake Rotor Size (in / mm): 13.4 / 340 (front); 13.3 / 337 (rear) 13.4 / 340 (front); 13.3 / 337 (rear)
Wheel Size: 17 x 8-in. aluminum (std. AT4X); 18 x 8.5-in. aluminum (std. Elevation & AT4); 20 x 9-in. aluminum (std. Denali) 17 x 8-in. steel (std. WT); 17 x 8-in. aluminum (std. LT); 17 x 8-in. aluminum (std. ZR2); 18 x 8.5-in. aluminum (std. Trail Boss & Z71)
Tire Size: P265/65R18 all-terrain (Elevation & AT4); LT285/70R17 MT (AT4X); P275/60R20 all-terrain (Denali) P255/65R17 all-season (WT); P255/55R20 all-season (Z71); LT285/70R17 mud/terrain (ZR2); P265/65R18 all-terrain (Trail Boss & Z71)
Wheelbase (in. / mm): 131.4 / 3337 131.4 / 3337
Overall Length (in. / mm): 213.2 / 5416 – Elevation, AT4, AT4X, Denali; 217.9 / 5534 – AT4X Edition 1 Package 213 / 5411 – WT & LT & Z71; 213.2 / 5416 – Trail Boss; 212.7 / 5402 – ZR2
Overall Width w/ mirrors (in. / mm): 84.4 / 2144 84.4 / 2144
Overall Height (in. / mm): 79.8 / 2028 – Elevation, AT4; 81.6 / 2072 – AT4X; 81.7 / 2076 – AT4X Edition 1 Package; 80.4 / 2042 – Denali 78.8 / 2001 – WT & LT; 79.6 / 2021 – Z71; 79.9 / 2029 – Trail Boss; 81.9 / 2078 – ZR2
Track – front (in. / mm): 66.1 / 1680 – Elevation, AT4; 66.3 / 1684 – AT4X, AT4X Edition 1 Package; 66 / 1676 – Denali 62.8 / 1594 – WT, LT; 62.6 / 1590 – Z71; 66.2 / 1679 – Trail Boss; 66.3 / 1684 – ZR2
Track – rear (in. / mm): 66.1 / 1679 – Elevation, AT4; 66.3 / 1683 – AT4X, AT4X Edition 1 Package; 65.9 / 1675 – Denali 62.6 / 1590 – Z71; 62.8 / 1594 – WT, LT; 66.1 / 1679 – Trail Boss; 66.3 / 1684 – ZR2
Ground Clearance (in. / mm): 9.6 / 245 – Elevation, AT4; 10.7 / 271 – AT4X, AT4X Edition 1 Package; 10.5 / 267 – Denali 7.9 / 200 – WT, LT; 8.9 / 227 – Z71; 9.5 / 242 – Trail Boss; 10.7 / 272 – ZR2
Off-road Approach Angle (deg.): 33.3– Elevation, AT4, Denali; 36.9– AT4X; 32.8 AT4X Edition 1 Package 29.1 – Z71; 30.5 – Trail Boss; 38.3 – ZR2;
Off-road Departure Angle (deg.): 22.3– Elevation, AT4; 25– AT4X, AT4X Edition 1 Package; 22 – Denali 22.3 – Z71; 22.4 – Trail Boss; 25.1 – ZR2
Off-road Break-Over Angle (deg.): 20.9 – Elevation, AT4; 24.5– AT4X, AT4X Edition 1 Package; 20.8 – Denali 19.5 – Z71; 21 – Trail Boss; 24.6 – ZR2
Headroom (in. / mm): 40.3 / 1023 (front); 38.3 / 972 (rear) 40.3 / 1023 (front); 38.3 / 972 (rear)
Legroom (in. / mm): 45.2 / 1147 (front); 34.7 / 881 (rear) 45.2 /1147 (front); 34.7 / 881 (rear)
Shoulder Room (in. / mm): 57.4 / 1458 (front); 56.1 / 1426 (rear) 57.4 /1390 (front); 56.1 / 1426 (rear)
Hip Room (in. / mm): 54.7 / 1390 (front); 53.1 / 1348 (rear) 54.7 / 1390 (front); 53.1 / 1348 (rear)
Fuel tank capacity (approx.) 21.5 gal. / 81.4 liters 21.5 gal / 81.4 liters
Curb Weight (lb. / kg): 4430 / 2009 – Elevation 2WD; 4630 / 2100 – Elevation 4WD; 4670 / 2118 – AT4; 4970 / 2254 – AT4X; 4860 / 2204 – Denali; 5210 / 2363 – AT4X Edition 1 Package 4716 / 2139 – WT & LT; 4971 / 2255 – Trail Boss & Z71; 5298 / 2403 – ZR2
GVWR (lb. / kg)1: 6100 / 2767 – Elevation 2WD; 6250 / 2835 – Elevation 4WD, AT4, AT4X, AT4X Edition 1 Package, Denali 6250 / 2835 – WT & LT; 6250 / 2835 – Trail Boss & Z71; 6200 / 2812 – ZR2
Max Payload (lb. / kg)2: 1640 / 744 – Elevation 2WD; 1590 / 721 – Elevation 4WD; 1550 / 703 – AT4; 1250 / 567 – AT4X; 1360 / 617 – Denali; 1010 / 458 – AT4X Edition 1 Package 1684 / 764 – WT & LT; 1587 / 720 – Trail Boss & Z71; 1151 / 522 – ZR2
Max Trailering (lb. / kg)3: 7700 / 3493 – Elevation, AT4, Denali; 6000 / 2722 – AT4X; 5500 / 2495 – AT4X Edition 1 Package 7700 / 3493 – WT & LT (available); 7700 / 3493 – Trail Boss & Z71; 6000 / 2722 – ZR2
This just goes to show even though you have two identical platforms, you can trim them out differently with some interesting results. In the 2023 GMC Canyon vs. Chevy Colorado competition, the Canyon is meant to be more off-road ready – and it shows.
If you’re trying to decide between the two trucks and wanted to see the exact differences, hopefully the above chart will help.
The full review of the 2023 GMC Canyon will post on May 8, but you can read our first-drive review of the 2023 Chevy Colorado now.
