These 2025 full-size trucks recommend (or require) premium fuel
September 3, 2024
8 comments
2025 full-size trucks premium fuel
These 2025 full-size trucks need premium fuel for optimal performance. (Photo courtesy Ford Motor Company)
With more advanced engines on the road, the question on which 2025 full-size trucks recommend or require premium fuel is a growing topic. Here’s the list.
2025 Chevy Silverado 1500/GMC Sierra 1500 with 6.2L V-8
The Chevy Silverado 1500 and GMC Sierra are both offered in a 6.2-liter V-8 engine, putting out an impressive 420 horsepower and 460 pound-feet of torque. However, that’s with premium fuel that has an octane rating of 91.
The 2025 owner’s manual does state you can get away with 87 octane if 91 isn’t available. However, this “will result in reduced performance and drivability.”
2025 Ford F-150 EcoBooost
A perennial question for new owners is whether or not their EcoBoost engines require premium fuel. Turbocharged engines, years ago, required premium fuel since this fuel type burns cooler keeping the turbos cooler for better longevity.
Is this still the case? Well, that depends.
According to the latest Ford F-150 owner’s manual, you should use 87 octane in most cases. It adds:
“For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended. The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer.”
This octane recommendation applies to all Ford F-150 engine option,s including the high-output EcoBoost Raptor engine.
2025 Ram 1500 Hurricane engines
The 2025 Ram 1500 Hurricane 3.0-liter inline-6 engines are another odd ball when it comes to whether or not to use premium fuel. This is due to the two different engine outputs.
For the new Ram 1500, you can get either a standard-output or a high-output version.
The difference in performance is substantial with the standard output putting out 420 horsepower and 469 pound-feet of torque, while the high-output produces 540 horsepower and 521 pound-feet of torque.
There is also a difference in octane recommendations with the S/O recommending 87 octane while the H/O recommends 91 octane.
The Hurricane engine chief engineer did tell us you can run 87 octane in the H/O thanks to knock sensors built-in to the engine, however, you won’t get the same performance.
The bottom line on premium fuel in trucks
There are a lot of opinions when it comes to regular vs. premium fuel for engines. Our advice is to use whatever the manufacturer recommends — even if it hurts a little more about the pump.
Sure, you can get away with a tank here or there of the regular grade of gas, but you spent a lot of money for you truck. Do you really want to save a few bucks at the pump and get less performance?
2 comments
  • Let’s break this down. In my opinion, your regular old work horse of a pickup should run fine on 87 octane if not lower. All the boutique trucks can run on the higher stuff.
  • GM use to say premium “required” for the 6.2l I wonder why they changed it. There were folks on the GM Trucks forum that tested both fuels back to back and determined the fuel economy improvement from premium fuel for the 6.2 actually outweighs the extra cost and so using premium is actually cheaper.
2,819 messages 4,720 likes
Premium fuel is required or recommended in many new trucks. Do you see this as a good or bad thing?
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
I look at it as a bad thing. The benefit is too little if there is any benefit at all. A performance vehicle that is judged and purchased purely for said performance? Sure, makes sense.
Reply 3 likes
Avatar of TheDo114
TheDo114
Well-known member
776 messages 1,218 likes
Sucks because of the added cost and also availability of premium fuel in remote regions.
S
Saddle Tramp
Moderator
1,105 messages 1,227 likes
This is so bad. As far as I'm concerned pickup trucks should be able to run on 80 octane. Trucks are meant to work first and foremost even when in areas where the only fuel is garbage.
The boutique trucks can run on the good stuff. They're basically sports cars in spirit anyway but the regular pickups should be focused on durability and ownership costs.
Avatar of Hilux
Hilux
Well-known member
460 messages 774 likes
I don't care what the manual says, I am running the cheap regular gas, come and get me corporate goons.
Reply 3 likes
Shots fired!
Avatar of James-kd2cm
James-kd2cm
Well-known member
228 messages 413 likes
I understand the reasons for needing mid grade or premium… but I’d rather they all ran on regular fuel as well. My hemi is supposed to run on regular or mid grade… mid grade being recommended (to get max performance). I usually use mid grade but I’ve run regular on occasion when the price goes up…lol. I don’t crank out high mileage.
In the case if high performance trucks like the Raptor R, ZR2, TRX and RHO I can understand premium… these are halo vehicles reaching for top HP. I laugh when people want the high output HP on an off-road truck then complain about the mileage.
