Truck buyers are picky, and they should be. The right cab, bed length, axle ratio and tow package do not always show up on a local lot. The used market is the same story: the rust-free, one-owner truck you want is usually in Texas or Arizona, and you are usually somewhere else.
So more truck owners are buying from a distance, and sellers are shipping to buyers they never meet. Others are relocating for work, sending a truck to a second home or moving a project truck that does not run yet. In every case the question is the same. What does it cost to put a full-size pickup on a carrier, and why is the quote higher than it would be for a sedan?
Why trucks cost more
A car carrier sells two things: deck space and payload. A full-size pickup is greedy with both.
A crew cab with a standard bed is long enough to take the room of nearly two compact cars. It is also tall, which limits where it can sit on a double-deck trailer. And it is heavy. Every pound on the trailer counts against the carrier’s legal limit, so a heavy truck can mean one fewer vehicle on the load. The carrier makes up that lost slot in the price of yours.
The numbers
SGT Auto Transport’s current pricing data puts open-carrier transport for a standard car at $450 to about $2,000, depending on distance. A crew cab pickup runs $900 to $2,200 across the same range. Put another way, the truck surcharge is $175 to $625 over a car on the same route. Full-size SUVs sit in between, at $50 to $175 extra.
Chart: open transport price ranges across all distance bands, crew cab pickup vs. standard car. Source: SGT Auto Transport pricing data, 2026.
For a sense of what distance does to the bill, here are the base ranges for a standard vehicle on an open carrier. Add the truck surcharge on top.
| Distance | Standard vehicle price | Time on the truck |
| 100 to 499 miles | $450 to $800 | Up to 1 day |
| 500 to 999 miles | $725 to $1,150 | 1 to 2 days |
| 1,000 to 1,499 miles | $900 to $1,425 | 2 to 3 days |
| 1,500 to 1,999 miles | $1,075 to $1,625 | 3 to 4 days |
| 2,000 to 2,499 miles | $1,225 to $1,775 | 4 to 5 days |
| 2,500 to 2,999 miles | $1,325 to $1,900 | 5 to 7 days |
| 3,000 miles and up | $1,475 to $2,000 | 7 to 10 days |
Notice how the per-mile cost falls with distance. A short hop works out to $1.50 to $2.67 a mile. Coast to coast is $0.46 to $0.62. A truck 2,000 miles away is not four times as expensive to bring home as one 500 miles away. It is less than twice as much.
What moves a truck quote up or down
- Size and configuration. A regular cab short bed is easier freight than a crew cab long bed or a dually. Tell the transport company the exact configuration.
- Lifts, big tires and accessories. Anything that makes the truck taller, wider or heavier than stock affects where it can ride. Lift kits, oversized tires, light bars, ladder racks and campers must be declared at booking. A truck that shows up bigger than described may not fit the slot that was reserved for it.
- Running condition. A truck that cannot be driven onto the trailer has to be winched. Expect $150 to $250 more.
- Open or enclosed. Nearly all trucks ship open. Enclosed transport adds 21% to 39% and is mostly used for restored classics and show trucks.
- Timing. A guaranteed pickup date costs $150 to $400 extra. A flexible window is cheaper.
- Season and route. Summer is the busiest time. November and February are often 10% to 20% cheaper. Pickups in remote areas cost more than those near major highways.
Because so many variables are in play, averages only go so far. Running your own route and truck through a car shipping cost calculator takes about a minute and gives you a figure you can actually budget around before you commit to a truck in another state.
Drive it or ship it?
Trucks are comfortable on the highway, so driving one home is tempting. The catch is fuel. A full-size pickup on a 1,500-mile trip burns a lot more than a compact car would, and you still need a one-way flight, two hotel nights and meals. Add the miles on the odometer and a couple of days off work, and the gap between driving and shipping is often smaller than expected.
As a rule of thumb, a truck within a day’s drive is worth collecting yourself. Beyond that, get a transport quote and compare the two totals honestly.
How to prep a truck for the carrier
- Empty the bed. Loose cargo can shift or fly out on an open trailer. Tool boxes should be locked and bolted down, or removed.
- Secure or remove the tonneau cover. Soft covers can lift at highway speed. Latch hard covers and check the seals.
- Take off detachable accessories. Bike racks, cargo carriers, antennas and removable light bars travel better in the cab or stay home.
- Fold the mirrors. Tow mirrors add width. Fold or retract them.
- Run the fuel down. A quarter tank or less. Fuel is weight, and a truck tank holds a lot of it.
- Check the basics. Tires inflated, battery charged, no fluid leaks, parking brake working.
- Wash it and photograph it. Every side, the bed, the roof, the wheels and the odometer, in daylight.
- Keep personal items light. Up to 100 pounds of belongings can ride along. Leave valuables and paperwork out.
- Hand over one key. Keep the spare.
Pickup and delivery
A loaded car hauler is about 80 feet long, so it may not be able to reach a house on a narrow road or a tight cul-de-sac. In that case the driver will meet you at a nearby parking lot or wide street. Sort this out when you book.
At pickup, you or the seller walk around the truck with the driver and record any existing damage on the Bill of Lading. At delivery, do the same before you sign. If you find something new, write it on the document and photograph it while the driver is there. Anyone over 18 can stand in for you at either end.
Check the company first
Legitimate auto transport brokers and carriers are registered with the Federal Motor Carrier Safety Administration. Ask for the MC and USDOT numbers and look them up on the agency’s SAFER website. Brokers must carry a $75,000 surety bond. Be wary of large upfront deposits. A reputable company does not charge until a carrier has actually been assigned to your truck.
Shipping a pickup costs more than shipping a car, and now you know why: it is bigger, taller and heavier. The surcharge is real but modest, usually a few hundred dollars. Describe the truck accurately, strip the bed, book a flexible window, and the right truck from a thousand miles away becomes a realistic option.
