Unleash the Power: Top 9 Truck Performance Upgrades and Body Components
2021 SEMA
Chevy Beast Concept
Whether you’re looking to get a little more power out of your truck or just want it to look a bit better, there are a number of interesting body and performance upgrades out there that can help achieve these goals.
Here are some of the top ways to improve the performance and appearance of your truck.
1) Coilover kits
A coilover kit is one of the most popular ways to improve your truck’s performance and handling. The spring coils are adjustable, so you can fine-tune them to your specific vehicle. This makes it easy to get the perfect ride height and alignment, which helps improve cornering ability and acceleration.
While many people use these kits simply because they want their trucks to look better, there are actually serious benefits when it comes to driving performance as well, even when lifted!
2) Forged wheels
Forged wheels are stronger and lighter than cast wheels, which means they can take more abuse and last longer. They’re also more expensive to make, so forged wheels are typically reserved for higher-end vehicles.
But if you want to go even further with your truck’s performance upgrades, or if you plan on using it as an off-road vehicle, forged is always a better choice.
3) Exhaust systems
Aftermarket exhaust systems are an important part of a truck’s performance perks, as they can improve fuel economy and power figures. Exhaust systems can be expensive though, and can make a lot of noise.
4) HID headlights
HID headlights are a great upgrade if you want to improve your visibility at night and during inclement weather conditions. They’re also more energy efficient than traditional halogen bulbs, which means they’ll save you money over time and use less power.
HID headlights have several advantages over regular headlights:
● They’re brighter than standard halogen lights, so they can be seen from further away, especially in foggy or rainy conditions where visibility drops drastically. This makes them ideal for truck drivers who travel long distances on highways with low visibility.
● HID bulbs last longer than standard headlights, often upwards of 100K miles. That’s about three times longer on average!
5) LED lighting kits
LED lights are brighter, last longer, and use less energy than traditional halogen headlights and most HID bulbs. They can be installed in a variety of places on your truck including the grille, bumper and mirrors. LED’s also come in a myriad of colors, and last up to 50% longer than incandescent lamps according to the National Highway Traffic Safety Administration.
6) Air intake kits
An air intake kit can help your engine run more efficiently and improve horsepower and torque. A cooler engine typically lasts longer than one that runs hot, so an air intake kit can potentially help keep your truck running for longer, especially in the summer heat.
7) Suspension lift kits
A suspension lift kit is an easy and affordable way to improve the ride of your truck. It does so by raising the vehicle’s center of gravity, improving ground clearance, and allowing for larger wheels and tires. For those who plan on doing some serious off-roading, a suspension lift kit is essential. A typical suspension lift kit will consist of new springs and shocks that are designed specifically for that particular vehicle model.
By installing these components, you’ll be able to raise your truck to any desired height, with 4-6 inches being the norm. This increased height allows you to clear obstacles when off-road, and greatly aids in breakover clearance levels.
8) Differential cover and skid plate combo kits
If you’re looking for a way to protect your drivetrain’s differential, then a differential cover is an excellent choice. Differential covers often come with skid plates that can help protect your truck from rocks and debris when off-roading. Many differentials have built-in skid plates so that all components are covered!
9) Body armor and slider kits
This is a great way to protect the body of your truck from damage when off-roading, while keeping you safe in case a collision occurs.
These upgrades can help make your truck safer, more efficient and look great.
We hope this article has helped you decide which direction you wish to take your truck build. For no matter what kind of truck you choose, these nine aftermarket upgrades will always be useful!
