Yes, a half-ton pickup can handle a one-bedroom apartment move, but it rarely manages the job in a single trip. Full-size trucks like the Ford F-150 or Chevrolet Silverado 1500 can comfortably carry the weight of typical household furniture, so the real limitation is cargo space. A full-size pickup bed holds roughly 53 to 89 cubic feet at rail height, while a furnished one-bedroom usually fills a 10- to 12-foot rental truck. For a short local relocation with a free weekend, your pickup can realistically get it done, whereas a long-distance move calls for additional capacity.
Sizing up a one-bedroom apartment move
Moving guides usually measure a household by volume rather than by the number of rooms. A common rule of thumb is 150 to 200 cubic feet of truck space for every fully furnished room, and a typical one-bedroom apartment is often matched with a 12-foot rental truck that holds about 450 cubic feet. A minimally furnished apartment can come in lower, but a sofa, mattress, dresser, dining set and several dozen boxes accumulate surprisingly quickly.
Many people compare a DIY move with professional help before deciding. In southern Utah, one way to find local companies is an online business directory such as Names and Numbers, whose page of Movers in St. George, UT lists moving, truck rental and storage businesses with their phone numbers and service categories.
How much a half-ton pickup bed holds
Bed volume depends on the brand and the box length. Ford quotes 52.8 cubic feet for the F-150’s 5.5-foot bed, 62.3 cubic feet for the 6.5-foot bed and 77.4 cubic feet for the 8-foot bed. The current-generation Chevrolet Silverado 1500, sold since the 2019 model year, offers more room: about 63, 72 and 89 cubic feet for its short, standard and long boxes.
These measurements are taken to the top of the bed rails. Stacking cargo higher is possible, but it makes the load more difficult to secure and more vulnerable to wind. Wheel wells also reduce usable floor space: on the F-150, the distance between them is 50.6 inches, so a 60-inch-wide queen mattress won’t lie flat on the bed floor and will have to ride on top of the wells or on its side.
Payload: the half-ton limit that matters less than you’d expect
“Half-ton” is an outdated label, because modern trucks in this category carry considerably more than 1,000 pounds. For the 2026 F-150, Ford lists maximum payload ratings from 1,775 pounds with the 2.7L EcoBoost V6 up to 2,440 pounds with the 3.5L EcoBoost V6.
The actual rating for your specific truck is printed on the label in the driver’s door jamb, and it already accounts for your cab style, trim level and installed options. Payload becomes a genuine concern mainly with dense items such as boxed books, a solid-wood dresser or a washing machine, while a bed full of cushions, lamps and clothing will run out of room long before it reaches its weight capacity.
How many trips a one-bedroom move takes
To estimate the number of trips, divide the apartment’s total volume by the volume of your bed. A 450-cubic-foot apartment works out to approximately nine loads in a 5.5-foot F-150 bed, seven loads in the 6.5-foot box and five loads in a Silverado long box.
Efficient packing can reduce that number noticeably. On a 15-minute move across town, six or seven loads can fit into one long day of work. On a relocation across the state, however, every additional round trip adds hours of driving, so this approach quickly becomes impractical.
Planning a one-bedroom move with your pickup
A little preparation makes every load safer and more compact:
- Measure the largest furniture and the bed, since a sofa longer than the bed requires the tailgate down and additional straps.
- Disassemble whatever you can, because bed frames, table legs and shelving pack flat and stack neatly.
- Load heavy items first and push them against the front of the bed, so the weight stays forward and has no room to slide when you brake.
- Use uniform boxes, since identical cartons stack more tightly than a mixture of bins and bags.
- Protect furniture with moving blankets, which also shield your bed liner from scratches.
- Secure every load with ratchet straps attached to the bed’s tie-down points, then cover loose items with a tarp or cargo net.
Securing the load under Utah law
Utah Code 72-7-409 requires a load to be covered, confined or fastened so that nothing can escape the vehicle, and a 2025 law (HB 53) introduced stiffer penalties for unsecured loads. Inspect every strap at your first stop, because cargo tends to shift and settle during the first few miles.
When a pickup alone isn’t enough
The truck struggles on its own when the distance is long, the schedule is tight or nobody is available to help with lifting. Many half-ton pickups can tow a rented enclosed cargo trailer, which adds substantial space and keeps your belongings protected from the weather, although you should verify your truck’s towing rating and hitch equipment first. For staircases, a piano or a strict move-out deadline, a popular compromise is hiring a professional crew for the heavy pieces and transporting the boxes yourself.
Verdict: a half-ton pickup can handle a one-bedroom move over short distances
A half-ton pickup works best for a one-bedroom apartment move when the new residence is nearby, two people are available for lifting, and you can dedicate a full day to five to nine loads. Payload will rarely be the obstacle, but bed space almost always will be. If you have a short bed, a fully furnished apartment or a drive longer than an hour or two, plan on a trailer or a rented box truck for the bulk of your belongings, and reserve the pickup for boxes and fragile items you’d prefer to transport yourself.
