3 specialized Ford maintenance tips for concerned owners
May it be a Ford pickup truck, SUV, CUV, or something in between, all automobiles require a significant amount of financial investment. Being that we live in an age when buying a new truck borders on being bank account crippling, keeping what’s already in the garage functioning properly is more crucial than ever.
But if you want to keep your Ford in good shape, you’re going to need to exercise some due diligence. Sticking with routine maintenance checkups and being thorough about those service appointments is a must.
So to help ensure that your Ford receives the care it demands and deserves, we’ve provided some specialized maintenance procedures that can help you avoid common car care mistakes that many other automobile owners make. In the article below, you will discover a few top tips that can keep that Ford of yours running right for decades to come.
1. Watch out for warning signs
When you’re behind the wheel of a Ford, you can feel confident in knowing that you’re driving a well-built vehicle. But what you might be overlooking are those pesky little warning lights telling you that it’s time for a repair or routine servicing.
Even if it is something as small as windshield wiper failure, take your Ford to a certified A.S.E. mechanic and have it checked out. It’s always better to be safe than sorry.
Outside of wiper woes, here are some other warning signs you should be aware of:
● Oil pressure warning light – This light comes on when there’s an issue with the engine’s oil pressure. If you see this light, pull over and check the engine oil level immediately and refill as needed. No oil to be found? Call a tow truck and get that Ford oiling issue fixed ASAP!
● Coolant temperature warning light – This warning sign comes on when the engine is running too hot. Immediately pull over, turn off the engine, and phone for roadside assistance. Coolant fixes can be messy and dangerous, so time to hand those keys over to a pro.
2. Don’t skip service appointments
Service appointments may seem like unnecessary spending, but they are what keep that Ford running right over the long run. Make sure you choose a certified, reputable mechanic prior to scheduling any routine tune-ups, so you can rest assured in knowing that your vehicle is in safe hands.
Look for a Ford-certified mechanic who can guarantee all repairs as mentioned in the Ford manuals provided by the manufacturer. From there, feel free to schedule regular maintenance checkups as needed to keep that ride running properly.
By following this approach, you can detect any potential problems early on and address them before they cause any major problems.
3. Get regular oil changes
If you want to keep your Ford running like new, then you need to give it regular oil changes. As an automobile owner, it is your responsibility to keep track of oil change frequencies, which as we previously mentioned, are clearly stated in all Ford manuals. This is arguably the most important aspect of keeping a Ford’s engine functioning properly, so don’t hesitate to change that oil!
That being said, it is advisable to get an oil change every 5,000 miles or so, even when using pure synthetic oil. This will ensure that your engine is properly lubricated and running smoothly, and so that you won’t have to check your oil level regularly and top it off as necessary.
In closing
While you can always go to a Ford dealership for maintenance, a qualified mechanic can often get the work done for a fraction of the cost. However, if you know basic car maintenance, you might not even have to bother with dealing with a mechanic.
