2027 GM HD 6.6L gas V8: More power, better cooling and no dipstick
September 24, 2026
The updated 6.6-liter gas V8 on display at GM’s HD powertrain event.
The updated 6.6-liter gas V8 on display at GM’s HD powertrain event. (Video still: Tim Esterdahl)
With all the attention on GM’s new 8.3L Duramax, I did not want the gas engine to get lost in the shuffle. I spent time beside the updated 6.6L V8 at GM’s powertrain event and asked what changed for the 2027 Chevrolet Silverado HD and GMC Sierra HD. The answer includes more power, more cooling capacity and an oil-check change that will definitely get people talking.
First, keep this engine separate from the new 6.6L V8 coming to GM’s light-duty pickups. The HD engine is an enhanced version of the Gen 5 L8T family, as the engineer explained during our conversation. It produces 412 horsepower and 472 pound-feet of torque. Here is what I learned about the four main parts of the update.
The HD 6.6L gets a modest power increase
A close look at the new Turbo-Jet intake manifold.
A close look at the new Turbo-Jet intake manifold. (Video still: Tim Esterdahl)
Output rises from 401 to 412 horsepower and from 464 to 472 pound-feet of torque. Those are useful gains, although they are not the whole story of this update. GM says the engine has improved low-end pull and revised hardware designed around the work HD buyers actually do.
During our conversation, the engineer described the new Turbo-Jet intake manifold and its tuning for towing operation. The familiar name is a nice nod to Chevrolet history, but my interest is in what the intake does when this engine is working hard. The HD gas V8 remains paired with an Allison 10-speed automatic, with adaptive shift logic intended to keep the engine in its useful operating range.
Cooling changes matter when the trailer gets heavy
The front of the updated HD gas V8 during my technical walk-around.
The front of the updated HD gas V8 during my technical walk-around. (Video still: Tim Esterdahl)
The engineer spent a good portion of our discussion on heat management. He described a higher-flow water pump, revised oil passages and pan, and an engine-mounted oil cooler. He said water-pump flow is up about 7 percent and described 27 kilowatts of additional heat-rejection capability. Those interview details help explain why this is more than a horsepower announcement.
Towing puts an engine under a sustained load. My question is not just whether it can make its rated power for a moment, but whether it can stay comfortable doing the job on a long grade in hot weather. GM’s explanation focused on that sustained-work capability. I have not tested the updated engine with a trailer yet, so the real-world comparison will have to wait.
The dipstick gives way to an electronic oil reading
The updated oil pan and engine-mounted oil cooler on the HD gas V8.
The updated oil pan and engine-mounted oil cooler on the HD gas V8. (Video still: Tim Esterdahl)
I asked about the dipstick, and this updated gas V8 does not have one. GM’s release lists a digital oil-level display, and the engineer talked through the sensor-based approach during our walk-around. I understand the convenience argument, particularly when reaching into a large truck’s engine bay, but I also know plenty of owners like to pull a dipstick themselves.
That makes the difference between the two HD engines especially interesting. The new 8.3L Duramax has both a sensor and a physical dipstick. The updated 6.6L gas V8 takes the electronic route. I want buyers to know which setup they are getting instead of assuming every GM truck engine now checks its oil the same way.
What this means for Silverado HD and Sierra HD buyers
The HD gas V8 remains part of GM’s Gen 5 small-block family.
The HD gas V8 remains part of GM’s Gen 5 small-block family. (Video still: Tim Esterdahl)
GM says the enhanced 6.6L gas V8 is assembled at its Tonawanda Engine Plant in New York. The updated 2027 Silverado HD and Sierra HD are expected to begin arriving at U.S. dealers in late 2026. Pricing and more detailed product information will come in future announcements.
The trucks also receive electric power steering and electronic brake boost, so the driving changes extend beyond the engine. Buyers still need the rating for their exact configuration when choosing a tow vehicle. The 26,000-pound figure discussed in the video is gross combined weight, not a trailer towing rating. For me, this engine deserves a proper towing test: the power gains are easy to list, but cooling performance, transmission behavior and everyday usability will tell the more useful story.
