2024–2026 Toyota Tacoma Known Problems – Transmission, Engine, Small Gripes
March 12, 2026
2026 Toyota Tacoma Known Problems 1
The 2024-2026 Toyota Tacoma Known Problems list should help consumers shopping for a new midsize truck. (Photo courtesy Toyota)
If you are in the market for a new midsize truck, check out this list of 2024-2026 Toyota Tacoma known problems.
The redesigned fourth-generation Tacoma has drawn praise for improved comfort and capability, but owner reports and official records reveal a range of issues that have surfaced since its launch.
I break down the most-reported problems, ranked by prevalence and impact, as found on official NHTSA.gov recalls and other data, owner reports from forums, Facebook groups and my own reporting over the years.
Keep in mind this doesn’t mean every Tacoma owner has experienced any of these issues nor will you.
Transmission & Drivetrain Issues — Most Discussed Toyota Tacoma Known Problems
2026 Toyota Tacoma Known Problems 2
The 8-speed automatic transmission had been a hot topic with early issues. (Photo courtesy Toyota)
A number of owners of 2024 Tacoma models reported 8-speed automatic transmission problems very early on in their ownership experience as well as when off-roading.
Complaints filed with NHTSA indicate trucks suddenly jumping into neutral, being stuck in high gear, or experiencing power loss/sluggish response, sometimes within the first 1,000 miles.
Owners speculate this sounds like a low transmission oil issue, yet no transmission dipstick makes it impossible to validate.
We covered this issue when it became a popular topic on YouTube with people claiming it was a massive issue. At that time, we found 7 complaints in our article.
There is a Technical Service Bulletin addressing concerns for certain 2024 models listed on Tacomaworld.com. If one of those trucks affected had an issue, it should be resolved for free.
Searching again on this topic, two years later, I find the issues posted on forums are from 2024 with recent updates to those threads indicating no issues at all.
Another issue for owners is a transmission warning light when off-roading the truck in 4 HI. This light comes on to alert them the transmission is overheating. Speaking with Toyota on this issue, it typically occurs when owners are driving uphill at speed in 4 HI when they should be in 4 LO. Switching the truck to 4 LO, reduces heat on the torque convertor and makes the light go away. The issue is really more of a situation where the new engine produces so much more power than prior generations, owners simply aren’t used to switching it into 4 LO.
For 4 LO, you don’t worry about how fast you are going, you worry about the RPM gauge and keep it from redlining. The truth is 4 LO is a mostly misunderstood driving option for the average owner.
The bottom line, for me, is Toyota has set sales records for the number of Tacoma trucks sold with more than 270k last year alone. If this was a big issue, we should be hearing a LOT more about it.
Official Recalls — Brake and Display Systems
2026 Toyota Tacoma Known Problems 3
Just a few recalls for the 4th-generation Tacoma. (Photo courtesy Toyota)
Looking over the NHTSA.gov recall list, there have been three recalls for 2024 models:
  • Instrument Panel Failure
  • Rear Brake Hose May Leak
  • Incorrect Weight Capacity Label
Instrument Panel / Display Recall
A large Toyota recall affecting 591,377 vehicles — including some 2024 and 2025 Tacoma trucks — addresses instrument panel display failures that may prevent critical information (e.g., speed, warning lights) from appearing, posing a safety risk. Software updates or replacement displays are offered.
Brake Hose Recall
Toyota expanded a safety recall covering certain 2024–2025 Tacomas due to rear brake hoses that could be damaged by mud and debris, potentially causing brake fluid leaks and increased crash risk. Dealers are replacing hoses at no cost.
The 2025 Tacoma added an additional one with a driveshaft that may deform and break affecting 5,960 trucks.
There have been no recalls for the 2026 model year as of the time of this article.
Electronics, Infotainment & Connectivity
2026 Toyota Tacoma Known Problems 7
A myriad of electronic problems are frustrating owners. (Photo courtesy Toyota)
Owners across Facebook groups and forums report a suite of electrical and tech frustrations, including:
  • Infotainment glitches, especially with wireless Apple CarPlay/Android Auto dropping connections or failing to initialize.
  • Reports that the truck’s center display or instrument cluster does not always boot properly without a recall intervention.
These issues rarely leave a truck on the side of the road, but contribute to owner dissatisfaction of the truck.
Engine & Powertrain Feedback
2026 Toyota Tacoma Known Problems 4
While nothing has reported on for failures on the 2.4-liter turbocharged engine, people are suspicious. (Photo courtesy Toyota)
Some owners and mechanics share concerns on the 2.4-liter turbocharged engine and same displacement hybrid engine complexity or speculate on long-term reliability questions,
The concerns boil down to the materials used like aluminum, the plastic used for coolant couplings, thin/low tension rings, etc… The criticism is the engines are built for fuel economy and emissions goals and not for long-term durability.
One key area of debate, I found, is using a plastic coolant control valve instead of a traditional thermostat. This valve uses electric motors and gears to route coolant to cool down the engine more efficiently, however, it does use a plastic housing. Plastic, by itself, isn’t necessarily unique in automotive these days, it is just that people have concerns about durability.
For thin/low tension rings, Toyota has used them since 2016 to reduce friction and improve efficiency. People claim these rings cause oil consumption issues which will lead to long-term durability concerns. Toyota isn’t alone in using these rings with most midsize trucks and half-ton truck engines use similar rings. This is more of a it is what it is kind of thing.
Many mechanics and others don’t like how complex engines are like in the 2024-2026 Tacoma engines. The more complex, the more failure points you can have long-term.
It is worth stating there have been no widespread, documented recalls specific to engine hardware for the 2024–2026 models as of early 2026. Also, I failed to find any reports on engines failing at this time.
One commenter summed up these concerns as guilty by association rather than any real issues. Pretty much nailed it.
Fit/Finish & Ride Quality Gripes
2026 Toyota Tacoma Known Problems 5
There have been numerous reports on small issues for the Tacoma. (Photo courtesy Toyota)
Owners also mention more subjective quality items on social threads and community posts, such as:
  • Interior rattles and trim squeaks under certain conditions.
  • Minor NVH (noise, vibration, harshness) characteristics not aligning with some buyers’ expectations.
  • Fuel range estimates and 18.2 gallon gas tank size concerns — more of an ownership frustration than a mechanical fault.
These reports tend to be non-critical but common enough within discussions to be noteworthy.
Bottom Line
2026 Toyota Tacoma Known Problems 6
So far, so good for the 4th-generation Tacoma. (Photo courtesy Toyota)
What’s the take away on the 4th-generation Toyota Tacoma for long-term reliability then? So far, so good.
The initial concerns over the transmission have gone away, the engine hasn’t had nearly the same issues as it’s bigger brother Tundra and there are small issues for owners that can be addressed at the dealership as far as cabin rattles.
Sales have been great on the truck and many people love it.
No replies yet
2,819 messages 4,720 likes
If you are in the market for a new midsize truck, check out this list of 2024-2026 Toyota Tacoma known problems. The redesigned fourth-generation Tacoma has drawn praise for improved comfort and capability, but owner reports and official records reveal a range of issues that have surfaced since its launch. I break down the most-reported problems, ranked by prevalence and impact, as found on official NHTSA.gov recalls and other data, owner reports from forums, Facebook groups and my own reporting over the years. Keep in mind this doesn’t mean every Tacoma owner has experienced any of these issues nor will […] (read full article...)
