Why is Toyota Tundra Engine Failure Debris Cleaning Not Done At Casting Plant? Two Plants Get It Wrong?
December 17, 2025
5 comments
Toyota Tundra Engine Failure Debris Cleaning 1
Toyota fans have been wondering why not go to the source of the engine debris problem. (Screenshot by Tim Esterdahl)
A lot of people have been wondering why the Toyota Tundra engine failure recall debris cleaning isn’t being done when the engine is being cast. Why are engineers going to two different plants to try to chase down the problem instead?
Toyota Tundra Engine Failure Debris Cleaning 2
The 3rd-gen Toyota Tundra has been in the spotlight for all the wrong reasons lately. (Photo courtesy Toyota)
Before we get to the simple reason, let’s first make sure everyone is on the same page.
A detailed report was posted yesterday detailing Toyota’s efforts to fix ongoing issues with the 3.4-liter V6 engine catastrophic failures that are under recall. This is part of the second recall impacting 2023-2024 Toyota Tundra and includes some Lexus LX 600 and Lexus GX 550.
The report does not detail the hybrid engines and it does talk about some of the issues Toyota engineers found related to the first recall for 2022-2023 Toyota Tundra and Lexus LX 600 vehicles.
A key issue in the report is the fact Toyota says it is continuing to find “larger debris” after it has implemented various steps to improve its cleaning processes in two plants – Tahara, Japan and Huntsville, Alabama.
Why not the Tennessee casting plant?
Toyota Tundra Engine Failure Debris Cleaning 3
Engine blocks are casted, deburred and heated in an oven to reduce stress before shipped to engine plants to finish work on them. (Screenshot by Tim Esterdahl)
On the Tundras.com forum, a member asked why Toyota engineers weren’t going to the casting plant instead to sense this is where the engine block gets created in the first place.
The Toyota Jackson, Tennessee plant casts thousands of engine blocks, transmissions cases and housing each day and has created over 3 million such castings in 2024.
I reached out to Toyota’s plant communication manager to better understand how the casting plant plays a role in recall.
“We cast engine blocks at our plant in Jackson, TN,” said Leah Almeling, Manager, Toyota Corporate Communications Manufacturing. “The holes for the components (piston, crankshaft, etc.) are there when casting but machined at the engine plants.”
Engine plants machine more of the engine block
Toyota Tundra Engine Failure Debris Cleaning 4
This is an example of a finished engine from the Toyota Alabama plant. (Photo courtesy Toyota)
Years ago, I personally visited the Huntsville, Alabama plant and I vividly remember them drilling holes in engine blocks while using water to cool the cutting tools they were using.
Then, they would take this machined block and assemble all the various engine components into the block.
Along the way, this block, with the machining debris leftover from the cutting, would need to be cleaned and this is the lead factor leading to the recall according to Toyota.
They also think the main bearing robustness is also an issue.
How can two plants have the same problem?
Toyota Tundra Engine Failure Debris Cleaning 5
It doesn’t matter if the assembly line is in the U.S. or Japan, the process is the same for the automaker are both plants. (Screenshot by Tim Esterdahl)
People have wondered, then, how could two plants have the same problem? That seems a bit far fetched until you realize how process oriented Toyota is as a company.
I’ve been fortunate in my career to have visited many Toyota plants including the one in Tahara, Japan and the Huntsville, Alabama plant as well as the San Antonio, Texas plant where the Tundra is built. The assembly line process is the same no matter the location.
The reality is that there is a problem somewhere in their process for cleaning a machined block that is currently being addressed according to their own reports.
Talking with Jacob Brown, Toyota Mobility Manager also in charge of recall communications, he told me the Toyota production and quality control engineers are confident they have narrowed down what is going on and have addressed the problems.
The continual focus on improving the cleaning process combined with the more robust main bearing are seen as the overall solution to the catastrophic engine failure.
2,819 messages 4,720 likes
A lot of people have been wondering why the Toyota Tundra engine failure recall debris cleaning isn’t being done when the engine is being cast. Why are engineers going to two different plants to try to chase down the problem instead? Toyota Tundra engine failure recall debris cleaning Before we get to the simple reason, let’s first make sure everyone is on the same page. A detailed report was posted yesterday detailing Toyota’s efforts to fix ongoing issues with the 3.4-liter V6 engine catastrophic failures that are under recall. This is part of the second recall impacting 2023-2024 Toyota Tundra […] (read full article...)
Avatar of TheDo114
TheDo114
Well-known member
776 messages 1,218 likes
Thanks for the follow up! This is insightful and should hopefully be an easy fix.
R
Rotten.dalton
Active member
109 messages 223 likes
The ongoing question remains, is any 22+ Tundra safe? Until we get a new engine or a “fixed on xx/xx/xx” with real details on what and how they fixed, you can’t trust the new tundra or Toyota.
J
JTRASTEL
New member
2 messages 2 likes
I wouldn't think any 22 is safe. it seems intuitive that there is a likelihood of machining debris in the engine. And... without the improved main bearing.... a likelihood that debris will cause the bearing to fail. My hope is they get it resolved and give everyone affected a new engine. Which won't happen. But I think they get it fixed
Reply Like
J
JTRASTEL
New member
2 messages 2 likes
Lots of people speculating that Toyota must have known about these issues when testing the engines. I'm giving them the benefit of the doubt. I bet they were built without machining debris and the bearings held up. The change to the bearing is a response to the fact that they are not sure they have a complete handle on the debris issue and the improved bearing buys them time.
R
Rotten.dalton
Active member
Yes, I tend to agree with you, however, Toyota needs to be transparent about when and what they fixed, otherwise many will hold back due to lack of confidence in the tundra.
Reply Like
