Amping up the badass 2021 Ram 1500 TRX with Mopar
October 12, 2020
Mopar parts for the 2021 Ram 1500 TRX.
Mopar to offer more than 100 factory-engineered accessories for the 2021 Ram 1500 TRX. (Photo courtesy FCA)
Taking things to another level, Mopar has released a variety of new parts and accessories for the 2021 Ram 1500 TRX. These accessories will really help customize the 702 horsepower “apex predator.”
Mopar has been developing factory-engineered, thoroughly tested parts and accessories for years allowing customers to add these upgrades at the dealer while wrapping it into their loan.
These parts will also help it stand out in its fight against the Ford Raptor.
According to a press release, here are just a few of the Mopar performance parts and accessories with the part number and price for the 2021 Ram 1500 TRX.
RamBar (82215959AC | $1,195): Adding a rugged, sporty design while increasing the versatility of the Ram TRX, the RamBar accessory bar easily mounts to the truck bed using stake pockets and includes tie downs for in-bed storage. The robust tubular design features a powder-coat, matte-black finish and is specifically engineered to work with Mopar off-road 5-inch LED lights.
Off-road LED lights (82215274AC | $595): Available to mount on top of the RamBar, a set of 5-inch LED off-road lights – each shining at 4,800 lumens – provide exceptionally bright, fully illuminating light for off-road driving. The cast-aluminum housing ensures proper heat dissipation and long-term durability. Also included are two light covers with the Mopar logo, a wiring harness and switch.
Bed-mounted spare-tire carrier (82216108AA | $995): Manufactured with thick-gauge steel and high-strength welded tubular construction, the bed-mounted spare-tire carrier features a base layer of corrosion protection, a painted E-coat and a black-powder finish for durability. The fully integrated carrier securely holds up to a 37-inch spare tire/wheel in severe off-road conditions and can be removed easily if the customer needs to use the full truck bed for standard utility purposes.
Off-road rock rails (82216078AB | $1,195): Engineered to meet stringent protection, loading and durability requirements both on-road and off-road, the aluminum rock rail sections are attached using high-strength steel brackets. A black-powder coating provides corrosion protection and seamlessly blends with the vehicle aesthetics, allowing for easy entry and exit on the integrated step pads.
Off-road running boards (82215508AC | $995): Constructed of lightweight cast aluminum with a rugged spray-in bedliner and an anti-slip texture coating, exact-matched running boards fit tightly to the vehicle with no drilling necessary.
Bed step (82216278AC |$395): Load-rated for up to 350 pounds, the bed step features an articulating arm that lowers for easy access to the truck bed and retracts to a stored position with a gentle push, giving an “out of the way” look within the bumper.
Bed rails with adjustable tie downs (82215285AB | $250): Constructed of anodized aluminum, bed rails attach to the inside walls of the truck bed and feature adjustable cleats that slide along the rail system in order to secure cargo of various sizes. Rails can accommodate sliding toolboxes, sport-utility bars and a cargo-bed divider (all sold separately).
Beadlock-capable wheel rings (P5160250AA | $205): Constructed of tough forged aluminum with a silver finish, the beadlock wheel ring clamps the outer tire bead to the rim of the optional beadlock-capable wheel, enabling maximum traction when lower tire pressures are needed during off-roading.
All-weather floor mats (82216412AA | $165): Designed with a bucket-style approach to provide full coverage of the carpet in the foot wells, the black mats are made of heavy-duty rubber and feature a red Ram logo. Included are two front mats and one interlocking second-row runner that disconnects for easy removal.
Mopar says: “Unlike any other aftermarket offerings, (our) performance parts and accessories are backed by a full factory warranty. Strict standards and factory-exclusive data — information not available to the aftermarket — are used to seamlessly integrate Mopar parts and accessories to deliver proper fit, finish and quality right down to the color, grain and appearance of each product.”
The bottom line on the Mopar TRX accessories
Mopar has really done an exceptional job of being not only first to the market with performance and appearance upgrades, but also has the advantage of working with the FCA brands directly. Plus, like they point out, their parts are throughly tested and come with a full factory warranty. Mopar is simply hard to beat when it comes to FCA vehicle aftermarket add ons.
Related Posts:
4 details you might have missed on the Ram 1500 TRX
Ram 1500 TRX vs Ford F-150 Raptor by the specs
Raptor fighter? 2021 Ram 1500 TRX is big, powerful and awesome
