A 2026 GMC Sierra 1500 owner says rain leaked into the cab at roughly 4,000 miles. If that sounds familiar, it should: GM has issued multiple service bulletins on rear-window leaks, and a proposed class action concerns owners of older Silverado and Sierra pickups. That case does not include the 2026 Sierra, and it does not tell us what caused this truck’s leak.
What the 4,000-mile Sierra owner reported
According to Torque News’ report by Brian Hensley, Quenton Haynes posted about water dripping behind the center of his rear window after heavy rain. He put the mileage at about 4,000 and identified the truck as a 2026 Sierra 1500.
The outlet reported a later update in which Haynes said GMC identified a seam and recommended High Tech Sealer. That is the owner’s account of the diagnosis, not a statement supplied directly to Pickup Truck + SUV Talk by GM. The report did not include his repair order or establish that the repair had permanently stopped the leak.
That missing diagnosis matters. Water near the third brake light does not, by itself, establish which seal or component has failed.
GM’s newer bulletin says to seal, not replace
The September 2024 version of GM bulletin 24-NA-103, hosted by NHTSA, identifies pinholes in the rear-glass urethane adhesive as a possible entry point. Its application table includes certain 2022–2025 Chevy Silverado and GMC Sierra pickups, including HD models, equipped with the A48 power sliding rear window.
For that particular condition, GM tells technicians: “Do Not replace the rear glass for this concern.” The procedure involves removing the rear roof spoiler, cleaning and thoroughly drying the area above the window, then sealing across the top. It also specifies replacement spoiler fasteners and at least 24 hours before a car wash.
The original June 2024 version stopped at 2024. The September revision added 2025. Those dated versions do not list 2026, so they should not be treated as a diagnosis of Haynes’ truck.
Separately, GM issued service update N262579650 on November 9, 2026, addressing a potential rear sliding back-glass leak on eight specifically listed U.S. VINs of 2026 Silverado 1500 and Sierra 1500 trucks. That narrow update is not a model-wide recall. Haynes’ VIN has not been established here, so we cannot say whether his Sierra is included. Owners should have their dealer check their exact VIN against current service information.
Twelve revisions do not mean twelve failed fixes
The older 18-NA-383 bulletin, dated March 2023, addresses specified 2019 new-model and 2020 half-ton trucks and 2020 HD models with power sliding rear windows. It directs technicians to confirm cracks in the plastic upper rail, rather than confuse them with a primary urethane-seal leak or water entering at spoiler attachments.
That distinction changes the repair. The document calls for removing and resealing the window for a primary urethane-seal leak. For the rail-crack concern, it describes a sealing procedure and says to replace the sliding-window assembly if the truck returns with the same concern after that repair.
Its revision history reaches version 13, with 12 changes after the original release. Those changes include labor time, material allowances, model years, VIN limits, fastener information and a sealer-supplier change. Calling them 12 separate failed fixes goes beyond what the document shows.
This has happened before
The older-truck lawsuit provides historical context for the latest owner report, not evidence of the cause of this 2026 truck’s leak. In the original complaint filed June 1, 2026, Filiberto Loza Gonzalez sought to represent California purchasers and lessees of specified 2019–2020 Silverado and Sierra half-tons and 2020 HD pickups. He alleged that his 2019 Sierra developed a rear-cab leak at 57,134 miles and that he paid more than $1,000 for repairs after GM declined coverage.
Those are the plaintiff’s allegations, not a court finding that every listed truck is defective. The proposed group described in that complaint does not include Haynes’ 2026 Sierra. MotorBiscuit reports that GM has sought dismissal; this story does not treat the case as resolved.
The documents discussed here are manufacturer service bulletins and a civil complaint, not a rear-window safety recall announcement or a NHTSA defect-investigation finding. A bulletin posted on NHTSA’s website remains a GM service communication. It also does not promise every owner a free repair; coverage depends on the vehicle and applicable warranty.
For a wet truck, the practical question is what failed and how the shop verified it. Keep photos and repair orders, ask for the diagnosed entry point in writing, and have the dealer explain coverage before authorizing work. For other issues, see our GMC Sierra 1500 known-problems guide.
