2021-2026 GMC Sierra 1500 Known Problems: Engine Failures, Lifters, Transmission Issues and Recalls
May 22, 2026
GMC Sierra 1500 Known Problems 7
A 2024 GMC Sierra 1500 being loaded up on a tow truck. (Photo courtesy of Auto Evolution)
The 2021-2026 GMC Sierra 1500 known problems list details engine failures, transmission concerns and recalls raises reliability questions for used and new truck buyers.
6.2L V8 Engine Recall and Failure
GMC Sierra 1500 Known Problems 5
Many trucks with the 6.2L V8 have had to get new engines. (Photo courtesy GMC)
At the time of this post, this is currently the hottest topic surrounding the GMC Sierra 1500.
Currently, there is a recall impacting 600,000 2021–2024 GMC Sierra 1500, Chevy Silverado 1500, Chevy Tahoe, GMC Yukon and Cadillac Escalade vehicles equipped with the 6.2L V8. These engines can completely fail due to “connecting rods and crankshafts with debris in oil passages or out-of-specification parts” according to NHTSA.gov documents.
Federal investigators have expanded a probe on this recall twice now looking at older models and now a new probe is looking at models that have had their engines replaced.
5.3L V8 Engine Lifter Failure
GMC Sierra 1500 Known Problems 4
The 5.3L V8 engine has also had its share of issues. (Photo courtesy GMC)
Another topic that comes up from time to time is lifter failure on the 5.3L V8 engine
These lifters push on the pushrods to open the intake and exhaust valves in the engine. If they fail, you can loud ticking noises, the engine will misfire and you’ll have power loss.
This seems to go in batches with people posting about it for a few months then nothing for a while. I’ve personally spoken with a variety of dealerships and mechanics on it. Some rarely see it and chalk it up to not doing proper maintenance and others say it is a rampant issue.
At the forefront of the issue is the idea the cylinder deactivation system is causing the lifters to prematurely fail due to excessive use. The current 5.3L V8 uses a Dynamic Fuel Management (DFM) system (2019+) that replaced the Active Fuel Management system aka V8 mode to 4 cylinder mode.
The DFM system can shut down cylinders more rapidly and can have the truck run one just one cylinder at a time when you may be cruising downhill without a load. There is no indicator light on the dash.
Whether it is true or false that this is directly related to lifter failure is up for debate (trucks built during COVID without DFM had lifter failure as well), there are aftermarket solutions to disable these systems.
3.0L Duramax Diesel Thrust Bearing Issue and Coolant Control Valve
GMC Sierra 1500 Known Problems 2
The 3.0L Duramax diesel had a long run of good reliability until recently. (Photo courtesy GMC)
Another engine issue for GM has been recent and not so recently affected the 3.0L Duramax diesel engine. This is the fuel economy diesel returning mid-20s and even into the 30 MPG range for full-size trucks.
First, last October, I broke the news of a thrust bearing issue causing complete engine failure. This was just starting to happen in dealerships and we were seeing dealership technicians talking about it online. GM issued a service bulletin to test the engine after an owner asked for the test to be done. No recall. Many engines were replaced and few have failed since then.
Second, coolant control valve failures were pretty common for owners of 2021-2023 Sierra 1500s with this engine. This caused check-engine lights and the possibility of engine overheating. GM issued a special coverage (N252508340) for 2023 models only and provided free replacements for that part for up to 15 years/150,000 miles.
Why only 2023? Your guess is as good as mine.
Lastly, not really a known problem, but more of a known maintenance item is replacing the “wet” oil pump belt in the rear of the engine at 200,000 miles. This belt is considered wet because it circulates in oil. The issue is you’ll need to remove the transmission to get to the belt. It is really best done at a dealership and isn’t a cheap replacement item.
8- and 10-Speed Transmission Woes
GMC Sierra 1500 Known Problems 3
Besides the engine issues, transmission problems have been plaguing some of the trucks. (Photo courtesy GMC)
GM transmission woes go back for years now. They seemingly have had issues for as long as I can remember and the 8-speed was especially troublesome.
Here’s the deal. The 2023 Sierra 1500 has the older 8-speed transmission that customers say has harsh shifts from 1-2, delayed engagements from park to drive and shudders. There’s a class-action lawsuit on that one.
Some customers have swapped out the transmission fluid to Mobil 1 synthetic and they say that’s fixed a lot of those issues.
The 2024 Sierra 1500, only available on the 2.7L Turbomax 4 cylinder engine, has an updated 8-speed transmission that’s more believed to be more refined and revised versus the 2023 model. I haven’t heard nearly the complaints with the 2024 model like I did with the 2023 and older.
Then, let’s talk about the 10-speed transmission. This was co-developed with Ford and has had its share of problems including a rear-wheel lockup issue last year leading to either customers getting a software update or a new valve body design (aka the brains of the transmission) being replaced for 2020-2022 diesel trucks and SUVs. That doesn’t apply to this story, but still makes people nervous.
The timing of this recall was especially bad since GM and Allison decided to call off their branding partnership on the 1500, 2500 and 3500 models at the end of 2025 with dealerships pulling down advertising by the spring of 2026. People associated the problems with the 10-speed to the ending of the brand partnership.
Going back to 2019, GM had Allison badges on trucks, but the transmissions weren’t built by Allison. It was a distinction the media reported on, but many consumers didn’t get the memo.
On February 5, 2026, GM announced it had signed a new brand deal with Allison Transmission to put their badges back on 2026 GM HD trucks.
GM and Allison continue to partner on medium-duty trucks like the 4500, 5500 and 6500. So, take that how you will.
Ultimately, what do you do? Take the truck for a test drive and see what you think of the shifting. The 2023 and newer trucks should have the newer valve body.
Electrical, Brake and Lighting Recalls Add to the List
GMC Sierra 1500 Known Problems 8
Electronic issues have also cropped for some owners. (Photo courtesy GMC)
Several recalls unrelated to the powertrain also impact these trucks. A large recall affecting 2023 Sierra 1500 models involves software that may fail to illuminate a warning light when brake fluid is low, increasing crash risk.
Lighting issues have also surfaced, including daytime running lights that may not turn off properly at night, creating glare for other drivers. While these may seem minor compared to engine failures, they contribute to the overall reliability picture.
2021-2026 GMC Sierra 1500 known problems additional issues: Airbags, Tailgates
GMC Sierra 1500 Known Problems 1
A few other notable issues for the GMC Sierra. (Photo courtesy GMC)
Other reported problems include roof-rail airbag inflator defects and power tailgates that may open unexpectedly due to water intrusion in the switch addressed by a recall. These issues are less common but still notable from a safety standpoint.
For 2026 models, long-term reliability data is still limited. Most known issues stem from 2021-2025 trucks, meaning buyers are largely relying on earlier model-year trends to gauge reliability.
Does this mean every 2021-2026 GMC Sierra 1500 will suffer from these problems? Nope. These are just things to be aware of when you are out shopping for a used or new truck.
