GM 6.2L V8 Engine Issues Worsen: Post Remedy Engine Failures Lead to ODI Recall Query
Cory Casciato
Cory Casciato
January 21, 2026
6 comments
The affected vehicles cover a broad range of GM vehicles. (Photo courtesy General Motors)
GM 6.2L V8 Engine faces more scrutiny as NHTSA opens investigation into original recall’s potentially inadequate remedies.
GM’s ongoing issues with its widely-used 6.2L V8 Engine keep getting worse. As we reported in October, the already critical recall was being expanded to include even more vehicles than originally reported. Now, to compound the issue, the NHTSA‘s Office of Defect Investigation has opened a recall query due to numerous reports of the engine failure defect occurring on vehicles that had already received the recommended remedy.
As we covered in October, the recall is a major one, affecting as many as 600K owners, and the issue itself is a serious defect. To quote our original report:
At the heart of the issue are potential flaws in the L87’s internal components. Federal documents and owner complaints describe scenarios in which connecting rods and crankshafts fail due to debris in oil passages or out-of-specification parts. These failures can occur suddenly, often destroying the engine and rendering the vehicle inoperable.
The original recall specified remedies including an engine inspection and potential replacement, among less serious remedies including using a different oil weight. Unfortunately, the data received since suggests the fixes are inadequate, and the issue is still occurring in vehicles that have been recalled and supposedly had the defect addressed and repaired.
The NHTSA’s ODI Resume document details 36 VOQ (Vehicle Owner Questionnaire) reports of engine failure of vehicles subject to the original recall, after the vehicles had received the recommended fix. In light of this data, the ODI opened the query to assess the adequacy of the remedy. Presumably this could, and likely will, lead to additional recalls of the affected vehicles for a new, more effective remedy.
It’s an alarming issue for the company and drivers of the affected vehicles. Loss of engine power, the primary risk from this issue, is highly dangerous at highway speeds, and the hassle of yet another recall for a supposedly fixed issue (especially in such a critical component) is likely to upset many owners. Considering the issue affects as many as 600K owners, this is bad news on a major scale.
2,822 messages 4,723 likes
GM 6.2L V8 Engine faces more scrutiny as NHTSA opens investigation into original recall’s potentially inadequate remedies. GM’s ongoing issues with its widely-used 6.2L V8 Engine keep getting worse. As we reported in October, the already critical recall was being expanded to include even more vehicles than originally reported. Now, to compound the issue, the NHTSA‘s Office of Defect Investigation has opened a recall query due to numerous reports of the engine failure defect occurring on vehicles that had already received the recommended remedy. As we covered in October, the recall is a major one, affecting as many as 600K […] (read full article...)
Avatar of TheDo114
TheDo114
Well-known member
778 messages 1,218 likes
Thanks for the report, I think it's one of the reasons why Toyota is not saying much and not rushing to say it's fixed. Having your engine failed is bad, having you engine keep failing after you say it's fixed is worse.
Avatar of Fightnfire
Fightnfire
Moderator
1,259 messages 2,162 likes
Didn't Toyota issue a recall saying they had addressed and fixed the issue with updated processes at the facilities for cleaning the debris out of the engine...and then not respond as engines produced after the debris cleaning processes went into place kept grenading for two+ years? Not to mention the hybrids with the exact same issue are completely ignored.
Avatar of TheDo114
TheDo114
Well-known member
It’s time to be pedantic about semantic, they said should and not that it was.
I still agree about the hybrids not being included being bullshit and that the warranty on the replace engine is only a year/12 000 miles.
We will know when Toyota has truly fixed it when they will give a proper warranty on the replacement engine.
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
Sure, but how many failed after receiving a whole new engine? The crappy part for GM is if the new oil viscosity doesn't "fix" enough of them, that's a whole lot of new engines.....
Reply Like
Fightnfire
Moderator
As a pct of total truck/SUV sales across GM..not really.
R
Rotten.dalton
Active member
109 messages 223 likes
Happier all the time I walked away from my 23 tundra. I’m running 2 vehicles with their new turbo 4. Hoping it’s a good one but wont really know for a long time. My daughter has 46k miles on her 24 taco. No issues.
Reply Like
