Does the Chevy Traverse’s 2.5L Turbo and 8-Speed Deserve GM’s Bad Rap?
November 25, 2026
Front view of a 2027 Chevrolet Traverse Z71
Does the Chevy Traverse’s 2.5-liter turbo and eight-speed deserve the bad reputation that follows some GM truck engines and transmissions? The 2025 and 2026 owner reports we reviewed point to some serious transmission problems, particularly on 2025 models. But they don’t show a pattern of widespread internal failure in the 2.5-liter engine. That’s not a clean bill of health. It’s a reason to judge this powertrain on its own record.
The Traverse uses the 328-hp LK0 turbo four-cylinder and MF8 eight-speed automatic. The redesigned 2024 Traverse introduced this pairing, and Chevrolet still lists it for 2027, its fourth model year. That’s not four years of long-term reliability data. For this complaint review, we focused on 2025 and 2026 and left out 2024 altogether. For the driving impressions, see Jill Ciminillo’s 2025 Chevy Traverse review. How it feels on the road is a different question from whether it holds up.
What 2025 Traverse owners reported about the eight-speed
Side profile of a 2027 Chevrolet Traverse Z71
A 2027 Chevy Traverse Z71. The owner reports discussed here are about earlier model years.
Several publicly reproduced NHTSA complaints describe early leaks or loss of drive. In report 11671070, an owner said the Traverse lost both Drive and Reverse at roughly 4,000 miles and that the dealer found loose transmission pump bolts. Another owner (11638069) reported a leak and a similar dealer diagnosis. In report 11636785, an owner described losing usable gears at around 1,700 miles and said the dealer recommended an entire transmission. We couldn’t independently verify that replacement was completed.
There’s more here than a handful of vague complaints about shifting. In bulletin 25-NA-001, GM identifies under-tightened transmission pump bolts as a possible source of fluid leaking near the torque converter housing. For a vehicle with that leak and a transmission build code from 24 160 through 24 311, a technician removes the transmission, checks the bolts and replaces them if loose. That’s documented repair guidance for a specific issue, not a recall or a recommendation to replace every gearbox.
A cold-weather stall can come from the transmission
Driver’s seat and cockpit of a 2027 Chevrolet Traverse Z71
The driver’s seat and cockpit of the 2027 Chevy Traverse Z71.
GM’s separate March 2026 PIP6102A describes a Traverse that stalls on its first shift into Drive or Reverse below freezing after remote start or at least five minutes of idling. For that symptom, with no diagnostic codes and the bulletin’s conditions verified, GM tells the dealer to replace the torque converter. The bulletin covers both model years reviewed here. Even though the engine stops, this guidance points to a suspected transmission component, not an internal engine failure.
The 2026 complaint records we reviewed include reports of delayed engagement, an AWD warning and a lurch. They don’t establish the same pump-bolt pattern or a confirmed complete transmission failure in those cases. The 2026 models also haven’t been in service as long, so the difference in reports does not establish a lower failure rate.
What the 2.5-liter engine reports actually show
2.5-liter turbocharged four-cylinder in a Chevrolet Traverse
The 2.5-liter turbocharged four-cylinder in the 2027 Chevy Traverse Z71.
One 2026 owner complaint, ODI 11725251 is more serious than a rough shift or a warning light. The owner said the engine quit at about 65 mph, wouldn’t restart and the dealer reported piston-to-valve contact and recommended an engine replacement. There’s no independent diagnostic paperwork in the public report, and it doesn’t show that a replacement was completed. We didn’t find a second comparable dealer-reported internal diagnosis in the records we reviewed.
GM did direct dealers to replace engines in a separate service update, N252540910. That update identified four specific dealer-stock 2026 vehicles across the Traverse, Buick Enclave and GMC Acadia, including one Traverse. It addressed a quality concern before customer delivery. It isn’t evidence of a widespread owner failure, and the documents don’t connect it to the highway incident.
What to check before buying a Traverse
2027 Chevrolet Traverse Z71 with its hood open
The hood open on the 2027 Chevy Traverse Z71.
GM reported 148,278 U.S. Traverse deliveries in calendar 2025 and 120,171 through September 2026, or 268,449 combined. That’s sales context only. These calendar-year totals aren’t a count of the two exact model years on the road, and NHTSA complaints are voluntary reports, not GM warranty claims. A single filing can carry multiple category labels. Dividing the reports by deliveries wouldn’t tell you your odds of having a problem.
If you’re shopping for a 2025 Traverse, ask a Chevy dealer to check the VIN for GM Customer Satisfaction Program N242473580. It’s separate from the pump-bolt bulletin. For eligible vehicles, GM’s notice says the dealer will replace the turbine shaft seal at no charge through December 31, 2026, regardless of mileage or ownership. If the seal is damaged or missing, the repair includes a new torque converter.
On a used Traverse, ask for the VIN and repair orders, not just a clean vehicle-history report. See how it goes into Drive and Reverse from a cold start. If engagement is delayed or there’s a warning, stop and have it diagnosed. Ask an independent shop to look for transmission-fluid leaks, and have a GM dealer check the VIN for applicable service updates and prior repairs. You can also check for open safety recalls with NHTSA’s VIN lookup. The documented eight-speed problems are worth checking. The records we reviewed don’t justify writing off every Traverse 2.5-liter engine.
