6.6L Duramax Tick: When GM Says to Check the Lifters
November 24, 2026
Silver Chevrolet Silverado 3500 HD Duramax with a Cameo fifth-wheel camper
Chevy Silverado 3500 Duramax towing one long camper (Photo by Tim Esterdahl)
A 6.6L Duramax tick can be normal, but General Motors has given dealers two clues to look for when they trace the sound to the valvetrain. The November service bulletin applies to 2017–2026 Chevy Silverado 2500HD and 3500HD and GMC Sierra 2500HD and 3500HD pickups equipped with the 6.6-liter L5P turbo-diesel V8.
The GM bulletin, PIP6142, was reported by GM-Trucks.com. It is diagnostic guidance, not a recall. It does not tell dealers to replace lifters on every truck that ticks or say how often the issue occurs.
What GM wants dealers to check
Front three-quarter view of a Chevy Silverado HD
A Chevy Silverado HD. The new service bulletin is specific to trucks with the L5P diesel. (Photo courtesy Chevrolet)
The bulletin starts with a tick a technician has already traced to the valvetrain. If a valve-lifter bridge has come off during a valve adjustment, GM says to stop and measure how far the valve opens. If that measurement comes back below spec, a worn camshaft is one possibility the technician should investigate.
The second clue is visible after adjustment. GM says the adjuster nuts should sit at roughly the same height. A nut that sits noticeably higher than the rest can point to a failing lifter, but it is a clue to investigate, not a diagnosis by itself. The bulletin does not specify a blanket replacement or extend warranty coverage.
A normal Duramax tick is a different thing
Front view of a 2026 GMC Sierra 2500 HD
The 2026 GMC Sierra 2500HD is among the model years listed in the bulletin when equipped with the L5P diesel. (Photo courtesy GMC)
GM has already described a normal diesel tick in bulletin 16-NA-372. That sound can be noticeable at idle, especially just behind the driver-side front wheel and early in the oil-change interval. GM says that particular noise does not affect durability and does not call for a repair. PIP6142 deals with a different situation: a tick a technician has isolated to the valvetrain.
If the sound is new or has changed, record when it happens and share that with your dealer along with bulletin PIP6142. The bulletin does not list the 2027 HDs. The model and year list is a starting point for diagnosis, not evidence your truck has a bad lifter. And the L5P bulletin is separate from the Duramax oil-cooler issue and our coverage of 2027 half-ton gasoline V8s.
Latest Recall Coverage
