2022-2024 Ram 1500 Recall: 82K ABS Module Software Error
Bianca Bailey
Bianca Bailey
November 28, 2026
a blue Ram 1500 negotiating a rough dirt track.
2024 Ram 1500 (Photo courtesy of Stellantis)
A recall of 82,843 Ram 1500 trucks for ABS modules that may fail due to a software error.
Chrysler (FCA US, LLC) is recalling certain 2022-2024 Ram 1500 Classic pickup trucks. The anti-lock brake (ABS) module software may misread inputs from the brake pedal and pedal sensor, which can result in improper brake light illumination, unintentional vehicle movement, or a loss of driver assist features, such as electronic stability control, AutoPark, and forward collision warning.
NHTSA ID Number: 26V756
Components: EXTERIOR LIGHTING, SERVICE BRAKES, HYDRAULIC, ELECTRONIC STABILITY CONTROL (ESC)
Potential Number of Units Affected: 82,843
Descriptive Information
Some 2022-2024 MY RAM 1500 Classic trucks may have been built with an Anti-lock Braking System (“ABS”) controller which does not correctly adapt to normal brake pedal drift over time.
The suspect period began on September 12, 2022, when ABS modules with suspect software started to be used in vehicle production, through the end of model production on October 2, 2024.
The vehicle population was determined by vehicle assembly traceability records.
Similar vehicles not included in this recall were built with an ABS Module which correctly adapts to normal brake pedal drift over time.
A suspect ABS module contains software that causes the Brake Pedal Position Sensor (“BPPS”) and brake pedal to not correctly adapt to normal brake pedal drift over time.
A BPPS and brake pedal that do not correctly adapt may cause the brake lights to illuminate without application of the brake pedal, or the truck to be shifted from PARK without application of the brake pedal and, eventually, a loss of driver assist features (including Electronic Stability Control (“ESC”), AutoPark, and Forward Collision Warning (“FCW”)), which may increase the risk of crash.
Description of the cause:
None stated.
None prior to failure. Customer may notice a loss of cruise control, a service brake system message, or warning lights such as ESC, FCW, AutoPark, and Traction Control. Exterior observers may notice brake lights illuminated without brake application.
Chronology
On February 5, 2026, the National Highway Traffic Safety Administration (“NHTSA”) made FCA US LLC (“FCA US”) Technical Safety and Regulatory Compliance (“TSRC”) aware of 7 Vehicle Owner Questionnaires (“VOQs”) reporting brake lights staying on and a loss of Electronic Stability Control.
Between February 2026 and March 2026, FCA US TSRC contacted the fleet which filed the VOQs in an attempt to inspect the complaint vehicles.
In March 2026, FCA US Engineering initiated a vehicle flagging campaign to identify and inspect vehicles in the field with similar complaints.
Between March 2026 and July 2026, FCA US TSRC, FCA US Engineering, and the supplier analyzed returned parts and conducted root cause analysis in vehicles identified by the vehicle flagging project.
Between March 2026 and October 2026, FCA US TSRC met with FCA US Engineering to review the issue, understand all potential failure modes, and to determine the suspect population.
On September 24, 2026, the FCA US TSRC organization opened an investigation into some 2022 through 2024 model year RAM 1500 Classic vehicles which may have been built with a suspect ABS module containing software that causes the BPPS and brake pedal to not correctly adapt to normal brake pedal drift over time.
As of October 21, 2026, FCA US is aware of 12 customer assistance records, 6001 warranty claims, 48 field reports, and 5310 other service records potentially relating to this issue for all markets with dates of receipt ranging from May 18, 2023 to September 29, 2026.
As of October 21, 2026, FCA US is aware of one accident without injury potentially related to this issue for all markets.
On November 12, 2026, FCA US determined, through the Vehicle Regulations Committee, that a safety defect exists in certain vehicles.
Remedy
Description of Remedy
Remedy Type: Software
FCA US will conduct a voluntary safety recall on all affected vehicles to reprogram the ABS Module to correctly adapt for normal brake pedal drift over time.
The remedy is a software flash that will correct the brake pedal adaptation algorithm.
FCA US will notify dealers on or about 11/26/2026 and begin notifying owners on or about 1/14/2027.
