7 in ’27: 7 Things You Need to Know About the 2027 Ford F-150
Cory Fourniquet
Cory Fourniquet
September 15, 2026
A red 2027 Ford F-150 Lariat showcases the updated full-size pickup’s refreshed styling. (Photo Courtesy of Ford)
The 2027 Ford F-150 arrives with a mix of new technology, revised engines, lower-cost off-road packages, fresh styling, and the first F-150 Carhartt. The biggest news is BlueCruise with Towing, which finally gives Ford an answer to Chevrolet and GMC trucks equipped with Super Cruise.
Ford F-Series has been America’s truck sales leader for 49 years, according to manufacturer-reported retail deliveries. The 2027 Ford F-150 XL Regular Cab with 2WD starts at $37,790 before the $2,795 destination and delivery charge, bringing the delivered starting price to $40,585. Staying on top does not require reinventing the F-150 every year. It requires protecting the choices buyers already value while fixing gaps in the lineup. For 2027, Ford appears to be doing both. Here are the seven updates that matter most.
1. The 2027 Ford F-150 adds BlueCruise with Towing
The 2027 Ford F-150 King Ranch uses BlueCruise with Towing for hands-free, eyes-on highway driving with a compatible trailer. (Photo Courtesy of Ford)
The headline addition is BlueCruise with Towing. It allows hands-free, eyes-on highway driving while pulling a compatible trailer, something GM’s Super Cruise had previously offered without a direct Ford rival. The system works on more than 130,000 miles of prequalified divided highways that Ford calls Blue Zones. When properly configured, a 2027 Ford F-150 can use it while towing up to 10,000 pounds, when properly equipped.
Ford engineers did much more than flip a switch and let the existing system operate with a trailer attached. A trailer adds weight, length, wind resistance, and another pivot point behind the truck. Different trailer shapes, loads, and weight distribution can change how the combination accelerates, brakes, responds to crosswinds, and centers itself in a lane. Ford says it tested thousands of real-world miles across high elevations, tight curves, and high-wind plains, then used simulation to expand the number of truck-and-trailer combinations it could evaluate.
Drivers must create a trailer profile with accurate dimensions before using the feature. BlueCruise also watches for trailer sway and can slow the truck, limit its speed, or ask the driver to take the wheel if the movement continues. It will not operate if the truck detects too much combined weight or an active tire-pressure warning. Towing speed is capped at 75 mph, and hands-free lane changes and In-Lane Repositioning are disabled while a trailer is connected.
BlueCruise with Towing will be available on every BlueCruise-equipped 2027 Ford F-150, from XLT and Tremor through Lariat, King Ranch, and Platinum. There is no separate feature charge beyond the required active BlueCruise plan or trial. It still requires an attentive driver watching the road, and availability depends on trailer type, size, weight, loading, and truck configuration. Reaching the full 10,000-pound limit also requires the Tow/Haul Package and optional Max Tow Axle.
2. The 2027 Ford F-150 brings V8 power back to more trims
The 2027 Ford F-150 Lariat is among the trims available with the returning 5.0-liter V8, rated at 400 horsepower and 410 lb-ft of torque. (Photo Courtesy of Ford)
Ford is bringing the 5.0-liter V8 back to King Ranch and Platinum for the first time since 2023. That makes the naturally aspirated engine available from the work-focused XL through the luxury-oriented Platinum within the regular F-150 trim ladder. It produces 400 horsepower and 410 lb-ft of torque and can tow up to 12,800 pounds when properly equipped.
The return matters because Ford is preserving engine choice while its rivals are reminding buyers that the V8 still has a place in a full-size pickup. Ram has revived the HEMI, while the redesigned 2027 Chevrolet Silverado and 2027 GMC Sierra are launching with two brand-new V8 engines. Ford still sells turbocharged V6 engines and a full hybrid, but it is not forcing every traditional truck buyer to follow the same path. For shoppers who want the sound, response, and familiarity of a naturally aspirated V8, the 2027 lineup offers more ways to get one.
3. The 2027 Ford F-150 gets a new base EcoBoost engine
The 2027 Ford F-150 XLT gains a new standard 3.0-liter EcoBoost V6 producing 325 horsepower and 400 lb-ft of torque. (Photo Courtesy of Ford)
The 2.7-liter EcoBoost V6 is being replaced by a new 3.0-liter EcoBoost V6 as the standard F-150 engine. This engine is essentially a bored-out version of the 2.7-liter engine, with peak output remaining at 325 horsepower and 400 lb-ft of torque. This change is about better driving dynamics, not about producing a larger number for the spec sheet. Ford says the new engine reaches its pulling power differently and delivers roughly 10% to 11% more torque in the part of the rev range drivers use most often.
That should make the entry F-150 feel stronger in ordinary driving, including pulling away from a stop, merging into traffic, or moving with cargo in the bed. The 3.0-liter EcoBoost can tow up to 8,400 pounds in a properly equipped rear-wheel-drive Regular Cab with the 6.5-foot bed. That configuration also has a maximum payload rating of 1,755 pounds. Buyers who need the F-150’s highest tow rating will still need the 3.5-liter EcoBoost, but the base truck should not feel like it received a base-level engine.
4. Entry-level Tremor and Raptor choices reduce the price of entry
The lower-cost 2027 Ford F-150 Tremor retains its core off-road hardware while giving up several interior convenience features. (Photo Courtesy of Cory Fourniquet)
Ford is adding new entry-level Tremor and Raptor choices for buyers who care more about off-road hardware than a long list of comfort features. The entry-level Tremor is priced at approximately $62,400, about $5,300 less than the 2026 entry point. The entry-level Raptor is priced at approximately $77,800, about $4,000 less than the 2026 entry point. Both retain the tough hardware and capability that define Ford’s off-road trucks.
The entry-level Tremor uses an STX-based interior with an STX steering wheel, manual air conditioning, fixed rear glass, and a six-speaker audio system. Heated front seats, off-road running boards, the power-sliding rear window, dual-zone climate control, and the eight-speaker B&O system are removed. The important off-road equipment remains, making this the Tremor for someone willing to give up convenience features to save about $5,300. Think of it as Ford’s answer to the Chevy Silverado Custom Trail Boss.
The entry-level Raptor applies the same thinking to Ford’s high-performance desert truck. It drops the head-up display, fog lamps, 2-kW Pro Power Onboard system, Mobile Office Package, power passenger seat, under-seat storage, and several other cabin upgrades. The power-adjustable steering column becomes a manual tilt column, while the 14-speaker B&O system gives way to an eight-speaker setup. Ford says the high-performance off-road hardware and capability that define the Raptor remain intact, now with an entry point about $4,000 lower than before.
5. The first F-150 Carhartt arrives
The 2027 Ford F-150 and Super Duty Carhartt models feature workwear-inspired graphics, badging and interior details. (Photo Courtesy of Ford)
The first Ford F-150 Carhartt builds on a 4WD XLT SuperCrew with the 302A equipment group and gives the popular mid-level trim a workwear-inspired identity. Exterior changes include unique 20-inch wheels, Carhartt fender vents and badging, lower rocker and tailgate graphics, Lobo headlamps, a Tremor hood, a modified grille, dual exhaust, Tremor running boards, and a Carhartt-branded spray-in bedliner.
Inside, the package adds themed seats with construction lines and triple stitching inspired by Carhartt workwear. The door panels, center-console lid, and steering wheel receive accent stitching, while the all-weather floor mats use a pattern inspired by the bottom of a Carhartt tool bag. Those are the small details that keep this from feeling like a truck with a clothing-company badge stuck to the fender.
The Carhartt Package costs $4,195. Ford lists the truck at $62,660 before the $2,795 destination and delivery charge, bringing its delivered starting price to $65,455 before taxes, title, and other fees. Orders are open now, with deliveries scheduled to begin in early 2027.
6. Four trims get a fresher face
The 2027 Ford F-150 XLT receives a new grille and wheel design as part of Ford’s freshened styling for four trims. (Photo Courtesy of Ford)
Ford is giving the XLT, Lariat, King Ranch, and Platinum new grille and wheel designs for 2027. The changes do not amount to a complete redesign, but they update the trims many retail customers will see first when they walk through a dealership.
That restrained approach makes sense for a truck with such a broad customer base. Ford says buyers asked for a modern spin on a familiar look, so the company changed the parts that quickly identify each trim without disrupting the F-150’s established shape or work-ready layout. The result should make the 2027 trucks easier to distinguish without making the outgoing models look instantly old.
7. PowerBoost and Pro Power Onboard are not going away
A 2027 Ford F-150 Lariat uses Pro Power Onboard to supply power for tools, campsites or properly connected emergency home backup. (Photo Courtesy of Cory Fourniquet)
The 3.5-liter PowerBoost full hybrid and Pro Power Onboard are not new for 2027, but their continued availability is worth calling out. The hybrid produces 430 horsepower and a lineup-leading 570 lb-ft of torque. Buyers can also equip it with up to 7.2 kW of Pro Power Onboard, turning the truck into a factory-integrated mobile generator for tools, campsites, tailgates, or properly connected emergency power at home.
That combination remains a strong Ford advantage among gas-powered half-ton pickups. Chevrolet, GMC, and Ram offer compelling engines and in-bed power outlets, but none currently matches the PowerBoost combination of full-hybrid torque and up to 7.2 kW of onboard generation at this scale. Ford could have used the 2027 update to narrow the lineup. Instead, it kept one of the F-150’s most useful differentiators.
The rest of the powertrain range remains broad, too. The 3.5-liter EcoBoost makes 400 horsepower and 500 lb-ft of torque while supporting the F-150’s maximum 13,500-pound tow rating when properly configured. Between that engine, the new 3.0-liter EcoBoost, the returning 5.0-liter V8, and PowerBoost, Ford is giving buyers four distinct answers to the question of what should power a full-size truck.
The 2027 Ford F-150 protects its strengths while fixing its gaps
The 2027 Ford F-150 Carhartt is one of several new additions expanding the truck’s technology, engine and styling choices. (Photo Courtesy of Ford)
The 2027 Ford F-150 is not a clean-sheet redesign, and it does not need to be. Ford focused on the gaps buyers were most likely to notice. BlueCruise can finally be used while towing, the V8 is available on the luxury trims again, the standard engine promises stronger everyday torque, and the Tremor and Raptor gain lower-cost entry points.
At the same time, Ford did not abandon the pieces that already separate the F-150 from other gas-powered half-ton pickups. PowerBoost and the 7.2-kW Pro Power Onboard system remain available, the 3.5-liter EcoBoost keeps its 13,500-pound maximum tow rating, and buyers still have one of the broadest powertrain menus in the class. That mix of new capability and preserved choice is the real story of the 2027 truck.
No replies yet
2,819 messages 4,718 likes
The 2027 Ford F-150 gains BlueCruise with Towing, a new base EcoBoost engine, wider V8 availability, lower-cost Tremor and Raptor packages, fresh styling, and a first-ever Carhartt model. (read full article...)
Reply Like
