2024-2026 Lexus GX Problems: Engine Recall, Harsh Shifts and Hood Flutter
Aaron Turpen
Aaron Turpen
September 20, 2026
2024 Lexus GX550 (Photo by Aaron Turpen)
The 2024 model year marked the third generation of the Lexus GX. The U.S.-market GX 550 grew larger and replaced the previous GX 460’s V-8 with a 349-hp, twin-turbocharged 3.4-liter V-6 and a 10-speed automatic transmission. The redesign brought more capability, but it also has issues buyers should investigate.
This guide covers the U.S.-market 2024–2026 GX. Recall filings and Lexus service bulletins document specific defects and repair procedures. Owner reports offer additional context, but do not establish how often a problem occurs. Not every issue below applies to every model year or vehicle.
Engine & Transmission Issues
2025 Lexus GX
2025 Lexus GX (Photo by Aaron Turpen)
The engine recall and transmission bulletin below address different concerns. Check the vehicle identification number (VIN) and have a Lexus dealer confirm which campaigns and repairs apply.
Engine damage and stalling (25V-767): Certain 2024 GX 550s are included in this engine recall. Machining debris left during manufacturing can damage crankshaft main bearings, leading to knocking, rough running, failure to start or stalling. The remedy uses inspection software to evaluate bearing condition, with engine replacement when the inspection cannot confirm the bearing will be free from abnormal wear related to the defect. Recall repairs are free.
Harsh downshifts: Lexus bulletin L-SB-0042-25 covers a harsh second-to-first downshift when slowing to a stop in certain 2024–2025 GX 550s. The procedure calls for an engine-control software update after confirming the condition. It does not call for replacing the control module.
Major Recalls for the GX
2024 Lexus GX interior
2024 Lexus GX interior (Photo by Aaron Turpen)
Other recalls include the following examples. This is not an exhaustive list, so a VIN lookup is essential.
Instrument display (26V-341): Certain 2024–2025 GX vehicles can have portions of the 12.3-inch instrument display remain blank at startup, hiding required information. Toyota’s recall announcement calls for a free software update.
Load-capacity labels (26V-179): Certain 2024–2025 GX vehicles have inaccurate load-carrying capacity modification labels. Incorrect information can lead to overloading. The recall remedy is a corrected label.
Lexus GX Technical Service Bulletins
2024 Lexus GX cargo space
2024 Lexus GX cargo space (Photo by Aaron Turpen)
A technical service bulletin (TSB) gives technicians diagnostic or repair instructions. It is not automatically a safety recall or a promise of a free repair. Coverage depends on the vehicle, condition and applicable warranty.
Brake squeal: Lexus bulletin L-SB-0053-25 addresses front brake squeal on certain 2024–2026 GX 550s. Ask a dealer to confirm applicability and follow the current repair procedure rather than assuming every brake noise has the same cause.
Hood flutter: Bulletin L-SB-0013-25 addresses hood flutter on certain 2024 GX 550s at speeds above 25 mph. The repair uses specified foam and dampening material. Have a technician inspect visible hood movement; do not assume it is harmless without diagnosis.
GX Known Problems
2025 Lexus GX in the snow
2025 Lexus GX in the snow (Photo by Aaron Turpen)
Owner discussions also raise concerns about hood movement and fuel economy. These reports are useful questions to bring to a test drive or service visit, not a measure of failure rates.
Persistent hood movement: If the condition remains after a repair, return to the dealer and document when it occurs. The existence of a bulletin does not mean every complaint has the same cause.
Fuel economy: Actual mileage can differ from EPA estimates with speed, weather, terrain, towing and tire choice. Treat the window-sticker numbers as estimates rather than a guarantee, and compare several tanks before drawing conclusions.
How To Check For Recalls On Your Lexus
NHTSA Recall Search page
Check the National Highway Traffic Safety Administration’s recall database using your VIN, or use the Lexus recall lookup. A dealer can confirm repair completion and applicable service bulletins. Older recalls can still require attention if the repair was never performed.
