2027 Chevy Silverado 3500 HD Pricing: Is It Cheaper Than Ford and Ram?
November 20, 2026
Red 2027 Chevrolet Silverado 3500 HD dually pulling a loaded gooseneck trailer at a drag strip
The 2027 Chevrolet Silverado 3500 HD and loaded trailer used for the closed-course towing demonstration. (Photo: DW Burnett, courtesy Chevrolet)
Is the 2027 Chevy Silverado 3500 HD cheaper than a Ford F-350 or Ram 3500? The answer depends on the engine. In this crew-cab, long-bed comparison, a gas Ford XL lists for $255 less than the Chevy WT. With the diesel added, the Chevy works out $840 cheaper than the Ford and comes in below the Ram estimates, too.
GM-Trucks reported the new Silverado 3500 HD configurator prices. We matched the three entry trims as closely as possible: 2027 model year, crew cab, eight-foot bed, four-wheel drive and single rear wheels. The figures include destination, but not tax, registration, dealer fees, discounts or unrelated optional equipment. They compare published prices and documented engine charges, not binding order quotes.
2027 Silverado 3500 HD price by trim
Red 2027 Chevy Silverado 3500 HD towing on a closed course
A 2027 Silverado 3500 HD at Chevy’s closed-course towing demonstration. (Video still: Pickup Truck + SUV Talk)
The $51,195 advertised entry point after freight buys a regular-cab work truck, not the crew cab priced here. Chevrolet lists $48,400 before destination; GM-Trucks found $2,795 for freight and an $11,400 charge for the 8.3-liter Duramax. Here’s the crew-cab price ladder, including single-rear-wheel diesel estimates calculated by adding that engine charge.
TrimGas SRWDiesel SRW*Gas duallyDiesel dually
WT$57,695$69,095$58,895$70,295
LT$61,895$73,295$63,895$75,295
LTZ$69,195$80,595$71,195$82,595
High Country$79,695$91,095$81,395$92,795
Crew cab, eight-foot bed and 4WD. Includes destination. *Diesel SRW column calculated from GM-Trucks’ reported gas prices and engine surcharge. See Chevy Build & Price for a current order.
Gas: Ford is $255 cheaper than Chevy
Ford Super Duty F-450 XL shown for illustration
Ford Super Duty file photo. This is an F-450, not the F-350 priced in the table. (Photo: Ford)
Olathe Ford’s ordering page puts the four-wheel-drive, long-bed XL at $54,645 before freight. For the matching Ram Tradesman, a dealer model catalog lists $55,425 and J.D. Power’s model data lists $56,090. Using the $2,795 freight on the Ram sticker puts both reference prices above the Chevy. Check a fresh order sheet before treating either Ram number as today’s price.
2027 work trimGas engineMSRP with freightDifference vs. Chevy
Ford F-350 XL7.3L V8$57,440$255 less
Chevy Silverado 3500 HD WT6.6L V8$57,695Reference
Ram 3500 Tradesman6.4L Hemi V8$58,220–$58,885$525–$1,190 more
Crew cab, eight-foot bed, 4WD, single rear wheels. Ram range reflects differing published base-price snapshots, not a dealer discount.
Diesel: the Duramax flips the result
2027 Chevrolet Silverado HD High Country towing a fifth-wheel camper
A preproduction 2027 Silverado HD tows a fifth-wheel camper. The prices below compare entry trims, not the High Country shown. (Photo: Chevrolet)
Chevy’s diesel upcharge is $1,095 less than Ford’s and $1,595 less than Ram’s. The Ford long-bed window sticker shows the High Output option and $2,795 destination on an XLT; Ford also lists that engine for the 2027 XL. The Ram Tradesman window sticker confirms the Cummins charge and $2,795 destination on a shorter-bed truck. We used only those charge lines, not the optioned sticker totals.
2027 work trimDiesel engineDiesel addEstimated MSRP with freightDifference vs. Chevy
Chevy Silverado 3500 HD WT8.3L Duramax V8$11,400$69,095Reference
Ford F-350 XL6.7L Power Stroke High Output V8$12,495$69,935$840 more
Ram 3500 Tradesman6.7L Cummins High Output I6$12,995$71,215–$71,880$2,120–$2,785 more
Same crew cab, eight-foot bed, 4WD and single rear wheels. Base plus diesel option and freight, excluding other options. These are calculated comparisons, not complete window stickers.
What matters when you order one
Loaded trailer from the 2027 Chevy Silverado 3500 HD demonstration
Compare towing and payload ratings for the exact build. This trailer was loaded for Chevy’s demonstration, not a rating for every one-ton pickup. (Photo: Pickup Truck + SUV Talk)
The gas price gap between Chevy and Ford is small enough for a single option to reverse it. On diesel, the smaller Duramax surcharge gives Chevy a more meaningful head start. A dually, a fifth-wheel prep package or your preferred axle ratio can change the bill and the truck’s ratings. Ask the dealer for a build sheet that includes freight and any required packages, and compare that number before considering discounts.
