2027 Toyota Tundra: Did They Fix the Engine, Where is the V8?
July 22, 2026
2027 Toyota Tundra Changes 7
The Trailhunter trims joins the Tundra lineup (Photo courtesy Toyota)
The 2027 Toyota Tundra changes generated plenty of questions from viewers, ranging from the troubled twin-turbocharged engine to the redesigned grille and the continued absence of a V8.
Toyota revealed a substantial collection of updates for 2027, including revised styling, Toyota Safety Sense 4.0, a new multimedia system, factory recovery hooks and an available 2.4-kW inverter. After reviewing the comments on our video, these were the five questions viewers asked most often.
1. Did Toyota Fix the Tundra Engine?
2027 Toyota Tundra
A new 2027 Toyota Tundra Trailhunter joins the lineup (Photo courtesy Toyota)
This was easily the most common question, and the answer requires some explanation.
Toyota has not introduced a new engine for the 2027 Tundra. The truck continues to use the V35A-FTS twin-turbocharged 3.4-liter V6, available as a conventional gas engine or as part of the i-FORCE MAX hybrid powertrain.
The engine failures affecting certain 2022-2024 Tundra trucks were traced to machining debris left inside the engine during manufacturing. Toyota determined that debris could become trapped in the No. 1 crankshaft main bearing, causing abnormal wear and potentially leading to engine knocking, rough running, a no-start condition, loss of power or complete engine failure.
Toyota eventually introduced an improved No. 1 main bearing and made additional manufacturing changes intended to address the problem. The most recent recall documents indicate engines produced after those changes are outside the affected production period.
In other words, Toyota believes it has identified and corrected the manufacturing problem. However, the 2027 announcement did not include a redesigned engine or an entirely new powertrain.
We have extensively covered Toyota’s investigation, including how the company identified the No. 1 main bearing as the source of the failures. We also reported on Toyota’s latest recall remedy, which uses dealer diagnostic software and vehicle operating data to determine whether an affected engine requires replacement.
The short answer is that Toyota says the manufacturing defect has been addressed, but buyers will have to decide whether enough time has passed to rebuild their confidence.
2. Is the Toyota Tundra V8 Coming Back?
2027 Toyota Tundra Changes 5
Sorry, the V8 is not coming back (Photo courtesy Toyota)
No, the V8 is not returning for the 2027 Toyota Tundra.
This was one of the strongest reactions in the comments. One viewer wrote, “V8 not coming back… OK, neither am I,” earning more than 60 likes. Several others said they would reconsider the Tundra only if Toyota restored the naturally aspirated V8.
That is not happening, at least for 2027.
The standard twin-turbocharged V6 produces 389 horsepower and 479 pound-feet of torque in most configurations. The available i-FORCE MAX hybrid increases output to 437 horsepower and 583 pound-feet of torque.
Those figures easily surpass the output of the old 5.7-liter V8, which produced 381 horsepower and 401 pound-feet of torque. However, power figures are not the only consideration. Many longtime owners still prefer the V8’s sound, simplicity, driving character and established reliability record.
Toyota remains committed to its turbocharged gas and hybrid powertrains, and nothing in the 2027 announcement suggests the company is reconsidering that strategy.
3. Did Toyota Change the Tundra Grille?
BThe 2027 Toyota Tundra loses the grille “mustache” used on the 2022-2026 trucks (Photo courtesy TundraDude34)
Yes. Toyota redesigned the front end of the 2027 Tundra.
The current Tundra’s grille has been one of its most polarizing styling features. Several viewers celebrated the disappearance of what owners frequently call the truck’s “mustache,” referring to the body-colored trim that extends beneath the headlights and around the grille.
For 2027, Toyota gave the front end a cleaner and more traditional shape. The grille has a stronger vertical orientation, while the surrounding trim no longer creates the same mustache-like appearance.
The redesigned front end also includes a revised lower bumper, rectangular fog lights and new hexagonal grille patterns. Those patterns will vary by trim, helping distinguish work-oriented, luxury and off-road versions of the truck.
Toyota did not completely reinvent the Tundra’s styling, but the changes make the front end appear cleaner, less bulky and better integrated.
4. Did Toyota Fix the Remote-Start Shutoff?
2027 Toyota Tundra Changes 3
New hybrid models will finally get more power in the bed (Photo courtesy Toyota)
Yes. The 2027 Tundra should remain running when the driver opens the door after using remote start.
Current Tundra owners have repeatedly complained about the engine shutting off as soon as a door is opened. The driver must then enter the truck and restart the engine, defeating much of the convenience of remote start.
The 2027 Tundra receives Toyota’s latest electrical architecture, a new-generation Toyota Audio Multimedia system and Toyota Safety Sense 4.0. Together, those updates bring the Tundra in line with newer Toyota products that allow a remote-started vehicle to remain running when the driver opens the door.
The driver will still need to have the key and complete the normal vehicle takeover process before driving away. The important difference is that the engine should no longer shut off simply because the door was opened.
This sounds like a relatively small software change, but it addresses one of the most persistent everyday frustrations reported by Toyota owners.
5. Did Toyota Add Front Recovery Hooks?
2027 Toyota Tundra Changes 2
Tow hooks are now on the 2027 Tundra (Photo courtesy Toyota)
Yes, although they will not be standard on every 2027 Tundra.
Viewer reaction to this change was particularly strong. One commenter said front recovery hooks should be included on every off-road vehicle, while another expressed disbelief that Toyota was finally installing them.
Toyota says front recovery hooks will be available on select 2027 Tundra configurations. They are also included with the new SR5-based Trailhunter package.
The Trailhunter package adds:
  • Front recovery hooks
  • Old Man Emu upgraded suspension
  • Michelin LTX Trail tires
  • Additional underbody protection
  • Multi-Terrain Select
  • Crawl Control
  • A locking rear differential
  • Bronze-colored wheels
Front recovery points have been a conspicuous omission on many third-generation Tundra configurations, especially for a truck marketed heavily around off-road capability. Factory-engineered hooks provide owners with a proper recovery location without requiring an aftermarket bumper or improvised attachment point.
Toyota will release complete trim and equipment details closer to the truck’s arrival, so we do not yet know every configuration that will offer the hooks.
What Has Toyota Not Addressed?
2027 Toyota Tundra Changes 6
The 2027 Toyota Tundra Trailhunter styling (Photo courtesy Toyota)
Viewers also asked whether Toyota corrected several other owner complaints, including cracking plastic panels around the front seats, squeaky brakes, tailgate problems and excessive wind noise.
Toyota did not specifically address those complaints in its initial 2027 announcement. That does not necessarily mean no production changes were made, but the company has not announced redesigned seat trim or confirmed fixes for those other concerns.
Complete specifications, pricing and additional equipment information are expected in fall 2026.
