2027 Toyota Tundra Changes Deliver the Upgrades Owners Have Been Waiting For
July 21, 2026
10 comments
2027 Toyota Tundra
A new 2027 Toyota Tundra Trailhunter joins the lineup (Photo courtesy Toyota)
The 2027 Toyota Tundra changes include updated styling, a new Trailhunter package, a standard 14-inch multimedia screen, a built-in drive recorder, Toyota Safety Sense 4.0 and, perhaps most importantly, an available 2.4-kW inverter for i-FORCE MAX trucks.
Yes, Toyota appears to have been listening.
This is more than a routine collection of new colors and minor trim adjustments. Toyota has addressed several of the most requested Tundra improvements, particularly inside the cabin and in the bed. The result should be a more functional truck with better technology, greater trail capability and meaningful improvements for owners who use their Tundra for work, camping and everyday driving.
Full specifications and pricing will arrive in fall 2026, but Toyota has already revealed the major updates.
2027 Toyota Tundra gets updated styling
2027 Toyota Tundra Changes 6
The 2027 Toyota Tundra Trailhunter styling (Photo courtesy Toyota)
Toyota has redesigned the front of the 2027 Tundra with a sharper, more purposeful appearance.
The updated design was developed by Toyota Motor North America teams, including CALTY Design Research in Ann Arbor, Michigan. Toyota says the new front-end treatment uses crisp, square geometry and a stronger vertical orientation to communicate power and capability.
The front end retains the Tundra’s broad stance while incorporating a revised lower bumper, rectangular fog lights and new hexagonal grille patterns that vary by trim. Toyota says the different grille treatments will help distinguish the personalities of its work-oriented, premium and off-road models.
An upgraded grille-mounted LED light bar provides brighter output, while RIGID fog lights and front recovery hooks will be available on select configurations.
The result is recognizably Tundra, but with a cleaner and more modern face.
New Tundra Trailhunter package expands the off-road lineup
2027 Toyota Tundra Changes 7
The Trailhunter trims joins the Tundra lineup (Photo courtesy Toyota)
Toyota is also introducing a new Trailhunter package based on the SR5 grade.
This factory-built overlanding package includes:
  • Michelin LTX Trail 265/70R18 tires
  • Old Man Emu upgraded suspension
  • Front recovery hooks
  • Additional underbody protection
  • Multi-Terrain Select
  • Crawl Control
  • Locking rear differential
  • Bronze-colored wheels
  • Exclusive Trailhunter badges
Toyota says the SR5-based package is intended to make an adventure-ready Tundra available at a more accessible price point.
That positioning gives buyers another way to build an off-road Tundra without necessarily stepping into one of the lineup’s most expensive trims. It should appeal to owners who want genuine trail hardware, factory integration and an overlanding-ready foundation.
Toyota will continue to offer the TRD Pro, along with SR, SR5, Limited, Platinum, 1794 Edition and Capstone grades.
Standard 14-inch screen and built-in dash camera
2027 Toyota Tundra Changes 8
No more smaller screen, the 14″ screen is standard (Photo courtesy Toyota)
The cabin receives one of the 2027 Tundra’s most important upgrades: Toyota’s latest Audio Multimedia system.
Every 2027 Tundra will now come standard with a 14-inch screen. The new system uses a more intuitive, smartphone-like interface with customizable widgets and a new “home” button (!). Yes, that includes the kind of straightforward home functionality that makes it easier to move through the system without hunting through menus.
Toyota also says its embedded Voice Assistant will respond more quickly to “Hey Toyota” commands. The system integrates AT&T 5G connectivity, subject to network availability.
The headline feature, however, might be the standard built-in Drive Recorder Dash Cam. This was introduced on the RAV4 and it works seamlessly.
When enabled, the system uses the truck’s exterior cameras to record 20-second clips. Recordings can be initiated manually or triggered automatically by certain events. Depending on the truck’s equipment, the system can use the front and rear cameras or the Panoramic View Monitor cameras.
A properly integrated factory dash camera eliminates the need to mount a separate camera, route power cables around the windshield and manage another application or memory card. This is exactly the type of technology that makes a truck easier to live with.
Digital Key receives expanded functionality
2027 Toyota Tundra Changes 2
A digital key joins the list of upgrades (Photo courtesy Toyota)
The 2027 Tundra will also offer enhanced Digital Key functionality with an active Remote Connect trial or subscription. Yeah, yeah… it is a feature for those with less gray in their beards, but it is pretty cool, stay with me here.
Owners will be able to manage the Digital Key through the native wallet application on a compatible Apple, Google or Samsung device. That includes locking, unlocking, starting and operating the supported vehicle.
Digital Key access can be shared with as many as five additional drivers, with permissions managed directly through the digital wallet.
Toyota says near-field communication can continue providing vehicle access for a limited time even if the connected device’s battery is depleted. That should make the phone-based key more practical and reduce concerns about being locked out by a dead phone.
Toyota has not yet detailed every Remote Connect or remote-start behavior change in this Tundra announcement. We will update that information once the complete specifications and operating details are available.
A 2.4-kW inverter transforms the i-FORCE MAX
2027 Toyota Tundra Changes 3
New hybrid models will finally get more power in the bed (Photo courtesy Toyota)
The other major announcement is the availability of a 2.4-kW inverter on Tundra models equipped with the i-FORCE MAX hybrid powertrain.
This is a substantial improvement and one that I was very, VERY critical of when the third-generation was announced considering the recent sales success of the Ford Powerboost’s on-board power system.
The inverter can provide electricity for tools, camping equipment and recreational gear. That gives owners another way to use the hybrid system beyond producing additional torque and acceleration.
For contractors, it can provide power for equipment at a job site. For campers, it can run lights, appliances and other gear without requiring a separate portable generator. It can also provide useful emergency power when electricity is unavailable.
A high-output inverter is exactly the kind of feature that makes an electrified truck powertrain more valuable. It turns the truck into a mobile power source and gives buyers a practical reason to select the i-FORCE MAX beyond its performance.
Toyota has not yet specified outlet locations, operating restrictions or whether the inverter can provide its complete output while the truck is parked. Those details are expected with the full 2027 specifications this fall.
Toyota Safety Sense 4.0 becomes standard
2027 Toyota Tundra Changes 4
Toyota sense 4.0 coming to the Tundra is a HUGE deal (Photo courtesy Toyota)
Every 2027 Tundra will come with Toyota Safety Sense 4.0 and this is HUGE for those who tow.
The latest version of Toyota’s active safety suite includes updated hardware and detection capabilities. Its listed features include:
  • Pre-Collision System with Pedestrian Detection
  • Full-Speed Dynamic Radar Cruise Control
  • Lane Departure Alert with Steering Assist
  • Automatic High Beams
  • Lane Tracing Assist
  • Road Sign Assist
  • Proactive Driving Assist
Why towing? It senses and turns off the back-up sensors when you back-up to a trailer. Yeah, holy cow. What a damn god send.
it also means remote start stays running even after you open a door. Another big deal/frustration for Toyota owners.
Gas and hybrid powertrains continue
2027 Toyota Tundra Changes 5
Sorry, the V8 is not coming back (Photo courtesy Toyota)
Toyota confirms the 2027 Tundra will remain available with gas and hybrid powertrains. No surprise there. Sorry V8 hopefuls.
The gas-powered twin-turbocharged V-6 will continue . The available i-FORCE MAX hybrid adds more torque and responsiveness, along with access to the newly announced 2.4-kW inverter.
Yes, the recalls over the engine issues are done. After 15 years of covering the truck, I’ve written my thoughts on it and I’m done covering the topic and it is time to move on and you should too. What is done, is done. Like it, love it, disagree or even hate it, it doesn’t matter. Time moves on.
The 2027 Tundra update checks the boxes
2027 Toyota Tundra Changes 9
The 2027 Toyota Tundra checks the boxes it needed to check (Photo courtesy Toyota)
Toyota has focused the 2027 Tundra update on changes owners will actually notice.
The redesigned front end gives the truck a fresher appearance. The SR5-based Trailhunter package creates a more accessible path into factory-backed overlanding. The standard 14-inch screen and built-in drive recorder improve the everyday ownership experience. Toyota Safety Sense 4.0 brings the company’s newest safety technology to the lineup.
Yet the available 2.4-kW inverter could be the most consequential improvement. It gives the i-FORCE MAX system another practical purpose and makes the hybrid Tundra considerably more useful at campsites, job sites and anywhere portable power is needed.
Pricing, complete specifications and additional details about the 2027 Toyota Tundra will be announced in fall 2026.
But based on what Toyota has revealed so far, this update delivers many of the features Tundra owners, or past owners like myself, have been waiting for. I’m excited, are you?
2,853 messages 4,756 likes
The 2027 Toyota Tundra changes include updated styling, a new Trailhunter package, a standard 14-inch multimedia screen, a built-in drive recorder, Toyota Safety Sense 4.0 and, perhaps most importantly, an available 2.4-kW inverter for i-FORCE MAX trucks. Yes, Toyota appears to have been listening. This is more than a routine collection of new colors and minor trim adjustments. Toyota has addressed several of the most requested Tundra improvements, particularly inside the cabin and in the bed. The result should be a more functional truck with better technology, greater trail capability and meaningful improvements for owners who use their Tundra for work, […] (read full article...)
M
Milly Goat
New member
2 messages 1 like
Sorry bro. What people want is to be able to believe in the engine. Not the case for several years now and I am afraid to tell you this but you sound like a bit of a shill for Toyota. Moreso, recently Toyota lowered the reliablitly bar even further when they came out and said that even if metal shavings are found in the oil filter, they won't replace the engine unless it has met their "use criteria" (ie been driven while towing trailers, etc.). That is pretty darn weak. People are still pulling oil filters off of 2026 models and finding filings in the oil filters! Toyota also refused to cover engine replacement for the hybrid models because of an NSHTA loophole. Great confidence builder Toyota. If no major changes have been made (aside from the main bearing fix) to the crappy V6 twin turbo, which is well known for grinding itself to metal filings, then I won't buy it and I will continue to post bad things about the Tundra online. Change the engine arrangement and also come back with a V8. Come on Toyota. Pull your head out of the sand. You have had 6 years of humiliation on the full-size truck market. Take a lesson from Ford's Coyote motor. Sheesh!!
Avatar of Hilux
Hilux
Well-known member
473 messages 788 likes
Another yawn inducing mediocre snooze fest Toyota truck, from the kings of mediocrity, it sells simply because it has Toyota on the tailgate.
On another note, wasn't Ram saying 40% of buyers wouldn't even consider a truck without a v8 a short time ago, Toyota must not care gaining a potential 40% increase in sales.
Toyota sees no v8 hears no v8 and speaks only in v6, Toyota will be a also ran against GM, Ford and Ram.
As to the Toyota PR crutch of they can't justify a V8 because its basically only a North American product, GM, Ford and Ram v8 full size trucks are primarily only a North American only product and they seem to get by just fine with V8s.
R
Rotten.dalton
Active member
109 messages 223 likes
I don’t think reporting on the tundra press release objectively makes Tim a shill by any stretch of the imagination. He’s an automotive journalist covering the facts of the updated Tundra. Rehashing the engine fiasco in every story mostly read by people who know all about it, isn’t adding much value to the information. I do agree that this generation Tundra is lost to those who know and cannot trust this engine, new bearing or not. We just won’t know whether the fix is a fix for years and that’s too much of a risk to take considering the oppressive cost of fixing or replacing this engine out of warranty.
Reply 3 likes
Avatar of Hilux
Hilux
Well-known member
I don't put stock into any auto reviewer if they get a vehicle from the manufacturer to review, they have no ability to independently review a vehicle that is supplied by a manufacturer, we need a "Project Farm" type of reviewer that either buys a vehicle or more than likely rents one through Turo or some rental lot.
If I got vehicles from the manufacturer to review I would be surely black listed within a week.
How do you mean? Why does reporting on the news automatically make someone a shill?
Avatar of TheDo114
TheDo114
Well-known member
779 messages 1,219 likes
Happy to see the 4.0 update and what that means for the remote start. The 2.4kw inverter is also a nice change and the tow hooks. Nice mild refresh, but it will be hard to please people on the internet. This truck and it's engine are basically ruined.
... hard to please people on the internet.
Story of my work life. LOL
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
That's the problem today, if anyone says anything positive, they're bought and paid for. On the other side, if they say anything negative, they don't know what they're talking about because obviously it is the greatest thing ever!
Avatar of TheDo114
TheDo114
Well-known member
For negative, there’s also the crowd that thinks that whoever posted it finally saw the light. It’s annoying.
t
tomfun41
New member
1 messages 0 likes
It does not matter if the 2026 or 2027 Tundra are better. Toyota has completely ignored hybrid owners. No one should ever trust Toyota again after they ignore hybrid Tundra engine issues. At this point I would trust a Chinese car over a Toyota.
Reply Like
