Second Toyota Tundra Engine Recall Postponed Again Because Company Incredibly Still Doesn’t Really Have a Fix After 4 Years
Michael Strong
Michael Strong
May 1, 2026
13 comments
2024 Toyota Tundra known problems
Toyota’s reputation for quality continues taking hits as the automaker has for the second time in four years forced owners of more than 125,000 late model Toyota Tundras and Lexus GX and LX SUVs to wait for a solution to the Toyota Tundra engine recall debacle.
Longtime Toyota Tundra engine recall problem
Toyota Tundra Engine Failure Debris Cleaning 2
The 3rd-gen Toyota Tundra has been in the spotlight for all the wrong reasons. (Photo courtesy Toyota)
This can get a bit confusing, so stay with us here.
Toyota has now issued two recalls involving its V35A engine, a 3.4-liter twin-turbo V6 used in 2022-2024 Tundra and Lexus LX 600 models as well as the 2024 Lexus GX 550.
The first recall was for 2022-2023 model year Toyota Tundra and Lexus LX 600 models. That remedy was to replace the engine.
Next, another recall was issued that expanded the first recall to include 2024 model year Toyota Tundra and Lexus GX 550 vehicles.
The problem stems from a faulty production process that leaves machining debris inside the engine. This debris may prevent the vehicle’s crankshaft from rotating while running. The debris build-up, according to Toyota, can cause the main bearing to fail, and the vehicle may stop while driving, increasing the risk of a crash, according to filings with the National Highway Traffic Safety Administration.
More than 125K vehicles with the engine
The 2024 Lexus GX is part of the second recall involving more than 125,000 vehicles with 3.4-liter twin-turbo V6 engines that might stop working. (Photo courtesy of Lexus)
The initial recall issued in May 2024 involved 102,092 vehicles. The latter order in November 2025 bumped that number up to 126,691 vehicles with the vast majority — 113,079 — being Tundra full-size pickups.
The number of affected vehicles has risen as production on each of the three continued after the initial recall. The problem becomes worse over time as more and more debris adheres to the parts within the engine. Ultimately, owners may hear the engine knocking or running rough. They also might also fail to start or stall while driving. It’s unclear if there have been any crashes, injuries or deaths related to the problem.
Owners frustrated by lack of remedy
The 2022 Tundra accounts for more than 113,000 of the 126,000 vehicles being recalled to deal with problems related to debris in the engine. (Photo courtesy of Toyota)
With most recalls, the process is simple. The problem is identified, a solution is developed, owners are notified, and repairs are made at no cost to the owner. However, Toyota’s been unable to find an solution to the problem despite two recalls and four years.
As part of the first recall in 2024, dealers were instructed to replace the engine assembly; however, that failed to adequately resolve the problem according to NHTSA.gov documents from Toyota. Compounding the problem of not having an actual remedy for the problem, Toyota is unable to provide an accurate estimate of just how many of the vehicles with the specific engine may actually be affected.
Company searching for solution
Owners have run into a variety of problems with the affected vehicles, including sluggish response, running rough, and stalling. (Photo courtesy of Toyota)
Aside from still working to resolve the issue, the company informed dealers about the ongoing problem Nov. 6, 2025, then notified owners of the affected vehicles in December about the problem and the lack of a solution.
There was a sliver of a hope for owners when Toyota stated it had made changes to the main bearing #1 in October, 2025.
“For the Tahara plant, data from the recovered engines, study about the bearing robustness, and the field performance data indicate that an increased level of this type of debris is present in engines produced between recall 24V-381 and the implementation of the improvement to the #1 main bearing,” according to a chronology report on this post.
“The remedy is currently under development. Once the repair is available, repairs will be performed free of charge. Interim letters notifying owners of the safety risk were mailed December 16, 2025,” Toyota wrote in a NHTSA filing.
“Additional letters will be sent once the final remedy is available, anticipated July or August 2026. Owners may contact Toyota’s customer service at 1-800-331-4331. Toyota’s numbers for this recall are 25TB14 and 25TA14. Lexus’ numbers for this recall are 25LB07 and 25LA07. This recall expands previous NHTSA recall number 24V381.”
Initially, this filing stated a final remedy would be available in April, 2026.
Owners want engines replaced
Some owners are so frustrated they’re pushing to have the engines in their vehicles replaced instead of waiting on a repair. (Photo courtesy of Lexus)
NHTSA’s received hundreds of complaints about the problem from owners, all recounting experiences dealing with at least one of the issues the problem is expected to cause.
“While driving, I noticed that the vehicle seemed sluggish. Shortly after, I experienced grinding and knocking,” one owner in Bayville, New Jersey told NHTSA. “The engine then stalled when I came to a traffic light.
“Fearing for my safety, I was able to get the engine to re-start to be able to pull off the road into a parking lot. At this point, the engine was barely running and making a ton of noise. There were no warning lights prior or after the incident took place.”
Scores of owners have endured similar experiences and are demanding Toyota replace the engines entirely, but the company hasn’t indicated that is a possibility at this point. As of Oct. 29, 2025, based on “a diligent review of records,” Toyota says, the best engineering judgement is there are 303 Toyota Field Technical Reports and 2,604 warranty claims on the engines in the subject vehicles.
Lastly, hybrid Tundra owners are also wondering what’s going on with their engines that aren’t part of the recall even though the engine components are seemingly identical to the gasoline-only engines.
2,852 messages 4,754 likes
Toyota’s reputation for quality continues taking hits as the automaker has for the second time in four years forced owners of more than 125,000 late model Toyota Tundras and Lexus GX and LX SUVs to wait for a solution to the Toyota Tundra engine recall debacle. Longtime Toyota Tundra engine recall problem This can get a bit confusing, so stay with us here. Toyota has now issued two recalls involving its V35A engine, a 3.4-liter twin-turbo V6 used in 2022-2024 Tundra and Lexus LX 600 models as well as the 2024 Lexus GX 550. The first recall was for 2022-2023 […] (read full article...)
Reply 3 likes
Avatar of Hilux
Hilux
Well-known member
473 messages 788 likes
I see one thing, actually two things on your video, the bearings you are holding up dont have any anti spin tabs on them, most bearings I have seen have tabs on them to prevent spinning the bearings.
Thanks. I assumed I was missing something.
Reply Like
Avatar of Hilux
Hilux
Well-known member
Here are some main bearings for a 2020 Toyota Tundra 5.7, these bearings have the anti spin tabs on them, I am not sure what Toyotas reasoning for not having them in the new Tundra engine.
Reply Like
R
Rotten.dalton
Active member
109 messages 223 likes
It’s really sad to see Toyota stuck in this quagmire of their own making. They have to make it right without replacing engines forever. I think a prorated buyback is in order. [your mileage]% of 200k miles = buyback value of what you paid or some formula that favors the buyer.
H
Hevy J
New member
1 messages 0 likes
2 things I agree with not having the anti spin tabs on the mains they need to be there. Also the tolerances is way to tight and the oil galleys need to be opened up so we can run heavier oil. Ow20 is like water and with a twin turbo application at 5k on the oil with the turbo heat cycles the oil is junk. Forget 10k service intervals 1k,3k 5k and the 5k from then on out is what I’m doing on my 24 sr5 trd 4x4 night shade.
Reply Like
Avatar of Fightnfire
Fightnfire
Moderator
1,259 messages 2,162 likes
I really wish this would get more traction.
From my perspective, it has gotten a lot of traction in ways you probably don't see.
In the past 6 days:
77k website views - most read story in past 90 days
94k views - Facebook vertical video
98.9k views - Instagram vertical video
24.7k views - TikTok
31k views - YouTube
3,477 views on MSN article
I'm going to run the vertical video on YouTube on Sunday and link to the full video in hopes of spiking the views. I'm not sure why there is such a disparity between the platforms for views, but that's the way it has been going for the past few months. This website has been on fire while YouTube just hasn't.
Reply Like
Fightnfire
Moderator
In the past 6 days:
31k views - YouTube
That's good, I didn't necessarily mean from you, just in a general sense. I feel like Toyota has been straight up deceptive about the whole thing. They announce a fix, sales spike, then extend the recall. (discreetly change part numbers on various bearing parts) Then they announce another fix, sales spike, and each time they include more trucks. Now, they say they aren't really sure what's causing the problem.
One things for certain... it isn't just debris. When legitimate mechanice pointed that out they were roasted. Time has proven them very right.
Reply 3 likes
It is interesting that on the various truck forums, there is a lot of sense from people they are over it. It is just old news to them. Until Toyota announces something new or different, people just aren't that interested.
R
Rotten.dalton
Active member
And yet, every time I check FB Tundra feed it’s always someone asking about buying a tundra who hasn’t heard of the problem or someone with Christmas lights for a dashboard on a tundra they bought a few months back asking the group if they know what could have happened. Keep getting the word out….
Reply 3 likes
