Westin Unveils A Powered Retractable Tonneau Cover Built for Convenience and a 500-Pound Payload
Larry Printz
Larry Printz
April 17, 2026
Westin Automotive’s power retractable tonneau cover (photo courtesy of Westin Automotive)
In the increasingly crowded market for truck accessories, Westin Automotive is betting that convenience, not just durability, will win over both contractors and everyday truck owners.
Westin Automotive’s power retractable tonneau cover and canister. (Photo courtesy of Westin Automotive)
The company has introduced a power retractable tonneau cover that reflects a broader shift in the category: turning what was once a purely utilitarian add-on into a piece of tech-enabled equipment. At its core is a heavy-duty electric motor that allows the cover to open and close quickly with the push of a button, a feature that signals how even the most rugged corners of the automotive aftermarket are being reshaped by automation.
MORE THAN CONVENIENCE
That said, Weston’s retractable tonneau cover isn’t just about ease.
Ttonneau cover shuts quickly to keep out mositure and dust. (Photo courtesy of Westin Automotive)
When closed, the cover is designed to create a tight seal against water and dirt, while supporting up to 500 pounds of evenly distributed weight, enough to turn the truck bed into a secondary cargo platform rather than simply a storage space lid.
“We built the Power Retractable Tonneau Cover to be tough as nails but still easy to live with every day,” said Tony Savasta, the company’s vice president of marketing, describing a product that aims to balance industrial-grade strength with consumer-friendly design. He noted that the company focused not only on load capacity but also on preserving usable bed space, engineering a compact 7.5 in deep x 11 in high canister that minimizes bed intrusion.
WHAT YOU CAN EXPECT
The retractable tonneau cover arrives with a set of features that underscore how expectations in the segment have evolved. A wireless key-fob allows drivers to operate the cover remotely, while a manual override ensures access if the vehicle loses power. Safety sensors are built in to prevent accidental pinching, and the system is designed for relatively straightforward installation using vehicle-specific hardware.
We must admit, it does look good. (Photo courtesy of Westin Automotive)
Equally important is retractable tonneau cover’s tighter tolerances, which are designed to keep out dust and moisture, a persistent challenge for truck owners who rely on their vehicles for work in a wide range of conditions. Meanwhile, the cover’s matte black finish ensures that this tonneau cover is an aesthetic enhancement as well as a functional one. Westin is positioning its power retractable tonneau cover as a broadly compatible engineering upgrade, one designed to fit a wide range of truck models from 2015 onward, thanks to its vehicle-specific mounting brackets and hardware.
Savasta framed the launch as part of a broader effort to bring more sophisticated tools to truck owners.
“We’re all about bringing tough, smart gear to the people who actually use their trucks,” he said, adding that the product raises the bar not just for security, but for style and integrated technology.
