New Ford F-150 3.0L ‘Nano’ V6 Coming for Next-Gen Truck?
Brian Medford
Brian Medford
April 28, 2026
Ford F-150 3.0L 1
A Ford F-150 3.0L ‘Nano’ V6 replacing the 2.7L? (Photo courtesy Ford Motor Company)
With the new redesign of the Ford F-150 pushed back to 2028, there is plenty of time to play the “what if” game when it comes to engine choices. The folks over at F150Ecoboost.net are pondering if the 3.0L “Nano” V6 used across Ford’s SUV lineup, Bronco Raptor and Ford Ranger Raptor. While the 2.7L V6 is already on the current-gen F-150 engine list, could they give that the boot and go with a 2028 Ford F-150 3.0L engine.
Engine Comparisons
Ford F-150 3.0L 2
Bigger is always better in the truck world. (Photo courtesy Ford Motor Company)
The current generation F-150 basically has three engine sizes: 2.7L V6, 3.5L V6 and 5.0L V8. We’re leaving out the F-150 Raptor engines for simplicity. That’s a nice “good, better, best” engine lineup for buyers to choose the powerplant that matches their needs. Here’s how the current engine lineup stacks up to a possible 3.0L option. We’re guessing if Ford went the 3.0L “Nano” route they would choose the engine already found in the U.S. domestic Ranger Raptor, so we based our engine specs accordingly.
Engine2.7L EcoBoost V63.5L EcoBoost V65.0L V83.0L EcoBoost V6
Horsepower (SAE net)325 @ 5,000 RPM400 @ 6,000 RPM400 @ 6,000 RPM405 @ 5,500 RPM
Torque (lb-ft)400 @ 3,000 RPM500 @ 3,100 RPM410 @ 4,250 RPM430 @ 3,500 RPM
By the numbers the 3.0L gives V8 power and torque, but not quite as much torque as the 3.5L. For power output alone the 3.0L makes a pretty convincing argument.
Will the 3.0L EcoBoost Fit?
Ford F-150 3.0L 3
Will the engine fit? (Photo courtesy Ford Motor Company)
We know very little about the underhood space of the next F-150, but we can make a few educated guesses. The 5.0L V8 is likely to stick around due to its popularity and isn’t likely to see any major updates that would change its external dimensions. If the V8 is the largest engine under the hood, then technically anything the same size or larger should fit too.
Finding exact engine measurements is a little tricky, but we pulled together some numbers from Ford part catalogs that seemed plausible. Here’s how the engines measure up size wise:
Length26.02″26.58″31.50″27.68”
Width30.75″ 28.33″31.38″29.72″
Height27.8″29.86″30.71″30.94″
Weight (lb.)409417453409
As you can see the 3.0L V6 fits within the V8 floor space and only needs a touch more head room. Weight is pretty much the same as the 2.7L, which is no surprise since Ford only upped the bore and stroke to make the larger 3.0L displacement. So fitting the 3.0L V6 in the new F-150 shouldn’t be a problem.
What Would Be the Advantage?
Ford F-150 3.0L 6
The Ranger Raptor uses this engine. (Photo courtesy Ford Motor Company)
If the 3.0L V6 would fit, what would be the advantage of it over the current engine offerings? First of all it brings more power, something truck buyers always appreciate. Thanks to stronger internal components and the slight displacement bump, the 3.0L could bring a little more real-world hauling and towing confidence. It is already designed to handle higher boost pressure and more punishing heat loads, so sliding the 3.0L under the hood of a full-size truck isn’t a stretch.
There could also be a marketing aspect to the engine lineup. GM’s baseline truck engine is a 2.7L turbo-4 that has proven considerably robust. Toyota’s Tundra brings a 3.4L twin-turbo V6 and Ram is still getting use out of the 3.6L PentaStar engine. Bringing the F-150 base engine into the 3.0L displacement realm would put it ahead of GM’s offering and starts nipping at the heels of Toyota and RAM. Then there is the “new” factor that drives excitement around a vehicle launch. The more “new” things they can announce, the better the talking points on the sales floor.
But There Are Downsides
Ford F-150 3.0L 4
Ford already has the 3.5L V6, would the 3.0L V6 be too close to the same? (Photo courtesy Ford Motor Company)
There could be a few reasons why Ford hasn’t already slid the 3.0L into the current generation F-150. We’re going out on a limb and assume that it also costs more to build the 3.0L thanks to the upgraded internals and more demanding supporting parts (like turbos and cooling system). There may also be slight differences in engine operation parameters that simply aren’t worth ironing out until the model full refresh. Considering how complex a modern vehicle drivetrain can be, one change can have a ripple effect through multiple systems.
There is also the elephant in the room: the 3.5L EcoBoost. Why would buyers pick the 3.0L when the 3.5L is within striking distance of horsepower but more usable torque at lower RPM? There are a gazillion 3.5L EcoBoost engines out there, which makes parts plentiful and repairs well understood. Yes there are plenty of 2.7L engines out there too, but the sheer footprint of the 3.5L cannot be denied.
Magic 8 Ball Says… Maybe?
Ford F-150 3.0L 5
Will they do it? That’s the big question. (Photo courtesy Ford Motor Company)
Ford has likely already locked in the engine options for the 2028 F-150, so we will have to wait until an official announcement or an information leak to see if this rumor is true. Only Ford can decide if the 2.7L is enough for their next generation truck buyers or will they want to turn up the wick a little.
No replies yet
2,853 messages 4,756 likes
With the new redesign of the Ford F-150 pushed back to 2028, there is plenty of time to play the “what if” game when it comes to engine choices. The folks over at F150Ecoboost.net are pondering if the 3.0L “Nano” V6 used across Ford’s SUV lineup, Bronco Raptor and Ford Ranger Raptor. While the 2.7L V6 is already on the current-gen F-150 engine list, could they give that the boot and go with a 2028 Ford F-150 3.0L engine. Engine Comparisons The current generation F-150 basically has three engine sizes: 2.7L V6, 3.5L V6 and 5.0L V8. We’re leaving out […] (read full article...)
