GM Defines “Normal” Oil Consumption for Trucks as Owners Say Huh? 1 Quart/2k Miles
April 27, 2026
18 comments
Oil Consumption for Trucks 1
GM says 1 quart of oil for every 2,000 miles is acceptable. (Photo courtesy Chevrolet)
General Motors has issued updated guidance outlining what it considers acceptable normal oil consumption for trucks, sparking renewed debate among owners who say the thresholds make zero sense.
GM Sets Official Oil Consumption for Trucks Standards
Oil Consumption for Trucks 3
The oil consumption applies to SUVs as well. (Photo courtesy Chevrolet)
According to General Motors, as reported by GM-trucks.com, all internal combustion engines consume some oil as part of normal operation. The automaker now defines acceptable oil consumption for light-duty trucks and passenger vehicles at one quart every 2,000 miles under standard driving conditions.
For heavy-duty trucks with a gross vehicle weight above 8,600 pounds, the measurement shifts to fuel usage rather than mileage. In those cases, GM considers one quart per 100 gallons of fuel burned to be within normal limits.
Why Engines Burn Oil in the First Place
Oil Consumption for Trucks 4
Engines have used oil as part of their design for years according to GM. (Photo courtesy Chevrolet)
GM explains that oil consumption is a natural byproduct of engine design. As pistons move within the cylinder, they leave behind a thin film of oil for lubrication. A portion of that oil is burned during combustion, leading to gradual consumption over time.
While this explanation aligns with long-standing engineering principles, the key issue for owners remains how much oil loss is considered acceptable in modern engines.
Owner Backlash Grows Over “Normal” Limits
Oil Consumption for Trucks 2
Owners don’t buy it. They say new engines shouldn’t use a drop of oil. (Photo courtesy Chevrolet)
The company’s benchmark of one quart every 2,000 miles has drawn criticism from truck owners and enthusiasts. Many argue that modern engines, built with tighter tolerances and advanced materials, should not consume that much oil between standard oil change intervals.
Some owners believe the guidelines are designed to limit warranty claims rather than reflect real-world expectations, especially for newer trucks still under factory coverage.
Engine-Specific Trends Raise Additional Concerns
Oil Consumption for Trucks 5
Is using engine oil a concern for you? (Photo courtesy Chevrolet)
Owner reports suggest oil consumption varies by engine. Turbocharged four-cylinder engines, like GM’s 2.7L, often show higher consumption during break-in periods before stabilizing.
Meanwhile, V8 engines equipped with cylinder deactivation systems have drawn scrutiny, with some owners linking oil consumption to potential lifter failures. Higher-end engines, such as the 6.2L V8, are often monitored through oil analysis to better understand wear and fuel dilution rather than relying solely on dipstick readings.
Heavy-duty gasoline engines also show variability, with owners working to distinguish between oil burned under heavy loads and oil lost through leaks.
Warranty Process Requires Strict Testing
Oil Consumption for Trucks 6
Is this a big issue or an eh? (Photo courtesy Chevrolet)
For owners seeking warranty repairs, GM requires a formal oil consumption test before approving engine work. Dealerships must first rule out external leaks, driving habits, towing use, and other contributing factors.
GM Bulletins #01-06-01-011 and #03-06-01-023 require technicians to rule out a laundry list of outside factors before approving an engine teardown. Here is what they are looking for:
  • Leaks: Inspecting oil pans, engine covers, and the engine oil cooler for external loss.
  • Waiting to Check: The oil level must not be checked for at least 15 minutes after shutting off the engine to allow oil to properly drain back into the pan.
  • Towing and Heavy Usage: Hooking up a trailer or hauling heavy payload will drastically increase oil burn.
  • High RPM Driving: Continuous high-speed or high RPM driving will naturally increase consumption.
  • PTO Operation: Running a Power Take-Off will increase both fuel and oil usage.
  • Oil Dilution: In colder weather, condensation from short trips might not evaporate out of the oil. This can artificially raise the oil level on the dipstick. After a long trip when that condensation finally evaporates, it can give the false impression of a sudden, massive oil loss.
If the issue persists, technicians initiate a controlled test that tracks oil levels over the course of 100 gallons of fuel consumption. Only after completing this process will GM determine whether the engine qualifies for repair or replacement under warranty.
Towing, Driving Habits Play a Major Role
Oil Consumption for Trucks 7
Oil consumption can be worse if you are towing. (Photo courtesy Chevrolet)
GM emphasizes that operating conditions significantly impact oil consumption. Towing, hauling heavy loads, high-speed driving, and extended engine operation all increase oil usage.
The company also notes that short trips in cold weather can temporarily mask oil consumption due to condensation buildup, which later evaporates and may appear as sudden oil loss.
As GM formalizes its stance, the divide between factory standards and owner expectations continues to widen, particularly among truck buyers who demand durability and long-term reliability from their vehicles.
What About Other Brands?
Oil Consumption for Trucks 8
Other brands like Toyota have a standard for engine oil usage. (Photo courtesy Toyota)
Is this just a GM thing or do other brands also have a normal oil consumption standard?
Doing some online research, it turns out that all brands have an acceptable oil usage, however, it varies.
Ram has the 1 quart per 2,000 miles, Ford states 1 quarter per 3,000 miles specifically for the 5.0L V8 Coyote engine with sources stating the EcoBoost is between 1,000-3,000 miles and Toyota is at 1 quart for every 1,200 miles for the Tundra.
2,806 messages 4,715 likes
General Motors has issued updated guidance outlining what it considers acceptable normal oil consumption for trucks, sparking renewed debate among owners who say the thresholds make zero sense. GM Sets Official Oil Consumption for Trucks Standards According to General Motors, as reported by GM-trucks.com, all internal combustion engines consume some oil as part of normal operation. The automaker now defines acceptable oil consumption for light-duty trucks and passenger vehicles at one quart every 2,000 miles under standard driving conditions. For heavy-duty trucks with a gross vehicle weight above 8,600 pounds, the measurement shifts to fuel usage rather than mileage. In […] (read full article...)
Reply Like
Avatar of Fightnfire
Fightnfire
Moderator
1,258 messages 2,161 likes
I don't love it. My truck consumes a quart over approximately half the oil change cycle, it always has. I don't like that it consumes oil. I find it annoying that some trucks do, and some don't. I know Ford also has consumption issues, more so in the 5.0 than the ecoboost, but as far as I know they don't publish any sort of statement. If they did, everyone would be on their ass too. They use to have a similar, or even worse, plublication for the coyote but I think stopped publishing it in 2020ish and now don't acknowledge it just dealing with it on a case by case basis....but will also call it normal consumption.
I have close to 4k towing miles with my 29' travel trailer. So it spends a little more than 5% of the time towing.
Avatar of Hilux
Hilux
Well-known member
459 messages 773 likes
My 2004 Silverado 4.3 v6 uses about a quart every 3500 miles.
D
Dusdaddy
Well-known member
1,387 messages 2,059 likes
I get engines burn oil, but it seems much more common with GM. I have heard of Fords and Rams doing it but nowhere near as often. I wonder if it is just as common or it really happens more often in GM. And if so, why.
I doubt GM engines are consuming more oil than other brands. That just doesn’t seem right. But, hey maybe they do!
Reply Like
Fightnfire
Moderator
That's a good question you could look into
Reply Like
I wonder if there is actual data or just speculation.
Reply Like
D
Dusdaddy
Well-known member
I think GM was the first to call miles as low as 2K normal so maybe that's where it came from? I do know my cousin fought with Ford on a new truck over it. He was adamant it was not normal to add a quart between changes, but Ford argued it was. He ended up trading it in and the next truck, same year/engine, needed nothing added between changes. But that was over ten years ago.
Avatar of TheDo114
TheDo114
Well-known member
775 messages 1,218 likes
Toyota is claiming a quart every 1200 miles! I would sell my truck if it consumed that much oil.
Fightnfire
Moderator
Ford says a QT at 3k miles is normal, above that they have a TSB that doesn't seem to really address the issue. They tried to addressing it with many noting no change after the TSB. Then all TSB's and publications went away, probably because of pending lawsuits.
This is a few years back from the tsb standpoint I think the lawsuits are hitting now.
Yeah, I found that same lawsuit. I do find it odd it is the 5.0L and not the EcoBoost. I mean turbocharged engines always get the bad rap, so I assumed it was them.
