Trump Gives Automakers Tariff Relief, Imposes New Tariffs on Trucks and Buses
October 20, 2025
7 comments
Trucks like this Ram 4500 will be hit by the new tariff, however, the tariff relief should be a much bigger savings. (Photo courtesy Ram Trucks)
The Trump administration is rolling back tariffs on automakers while also formally imposing new tariffs on imported trucks, buses and other medium- and heavy-duty trucks.
Under a proclamation signed October 17, President Trump approved a 25 percent tariff on imported medium- and heavy-duty trucks and parts, along with a 10 percent duty on buses, beginning November 1, senior administration officials confirmed in an Autonews.com story.
The truck and bus tariff story is being updated as we learn more here.
At the same time, Trump extended through 2030 an existing tariff offset program that provides cost relief for automakers assembling vehicles domestically.
Automakers Tariff Relief Extended Through 2030
The Ford F-150 is assembled in the U.S. and it should qualify for the tariff relief program. (Photo courtesy Detroit News)
The administration first introduced the tariff offset in April, shortly after imposing 25 percent duties on imported vehicles. Automakers can now continue to apply for an offset worth 3.75 percent of the total sticker price of vehicles assembled in the U.S. through April 30, 2030. President Trump’s term ends in January, 2029.
The program was originally set to decline to 2.5 percent in 2026 before being phased out entirely by 2027.
The extension represents a significant victory for automakers and suppliers who argued they needed more time to expand domestic production capacity for vehicles and parts.
According to administration officials, the 3.75 percent offset roughly matches the tariff burden a manufacturer would face if 15 percent of a vehicle’s value were sourced from imported components subject to a 25 percent duty,
How Does The Tariff Relief Actually Work And Who Benefits?
Who wins or loses with the tariff relief? Its too complicated to figure out. (Photo courtesy the Journal Gazette)
Stephanie Brinley, Principal Automotive Analyst for S&P Global, said “like everything, it is complicated.”
“The offset – according to the administration—works something like this: If an automaker were to reach 85% US (or USMCA-compliant) sourcing for US production, the offset would effectively reduce its tariff bill to near zero, using this 3.75% method.”
As it stands, USMCA components are still tariff free and this has been a hot topic especially with the sheer volume of parts and especially replacement parts coming from Mexico. It is considered the largest importer of parts to the U.S. making up 42.86% of all imported automotive parts. This translates into over $81 billion out of the $197 billion dollars worth of imported parts into the U.S. each year.
For the impact of this tariff relief on automakers, Brinley said “all automakers have some non-USMCA compliant content, some more than others. Depending on where that non-USMCA parts are coming from, the tariff can be 25%, 15% or 10%; China is higher.”
By offsetting the tariff, it will help take some of the “sting out of the cost of that content,” however, it still will have some impact.
As it stands there is no break down on how it will impact each OEM and how many parts are in each vehicle. It would take years to research each individual component.
Engine Production Offset in Development
Engines like this one built at the Stellantis Dundee Michigan plant would be exempt from tariffs and be part of the tariff offset program. (Photo courtesy Stellantis)
Trump also instructed the Commerce Department to create a comparable tariff offset program for engines built in the United States. The offset would equal 3.75 percent of the aggregate value of U.S.-assembled engines and is expected to run concurrently with the vehicle parts program, though no start date has been announced.
The new engine offset aims to support automakers and suppliers investing in domestic powertrain production — a key step in the administration’s broader effort to bolster U.S. manufacturing and reduce reliance on imported components.
Tariffs Reduced for Aluminum and Steel Import
Aluminum and steel tariffs are being reduced as well. (Photo courtesy Wikipedia)
In a further move to help automakers, the executive order directs the Commerce Department to reduce steel and aluminum tariffs by up to 50 percent for qualifying Canadian and Mexican producers.
The reductions apply to metals used by automakers and could lower tariff rates to as little as 25 percent. To qualify, the steel or aluminum must:
  • Be produced in Canada or Mexico,
  • Comply with North American free trade rules, and
  • Be smelted and cast (for aluminum) or melted and poured (for steel) in either country.
The tariff reductions are capped at quantities equal to newly committed U.S. production capacity, as determined by the Commerce Department.
Currently, most steel and aluminum imports — including derivative products — are subject to 50 percent duties.
This could be a life saver for Ford and others who are dealing with the effects after a recent fire closed down a major supplier of aluminum. Analysts had expected the fire to cost Ford $1 billion dollars.
A Broader Push for U.S. Manufacturing
The Belvidere Assembly plant will be reopening in the next few years to build the Jeep Cherokee and Jeep Compass and is seen as a win for U.S. manufacturing coming back. (Photo courtesy Wards Auto)
The mix of tariff relief and targeted duties underscores Trump’s ongoing strategy to realign global trade and strengthen domestic industry.
While automakers have welcomed the extended relief as a means to stabilize costs, the new tariffs on trucks and buses signal that the administration remains committed to using trade policy as a tool to push production back onto U.S. soil.
The U.S. Supreme Court has said it will hear oral arguments in early November on the legality of the tariffs after lower courts have ruled them illegal.
2,819 messages 4,718 likes
The Trump administration is rolling back tariffs on automakers while also formally imposing new tariffs on imported trucks, buses and other medium- and heavy-duty trucks. Under a proclamation signed October 17, President Trump approved a 25 percent tariff on imported medium- and heavy-duty trucks and parts, along with a 10 percent duty on buses, beginning November 1, senior administration officials confirmed in an Autonews.com story. The truck and bus tariff story is being updated as we learn more here. At the same time, Trump extended through 2030 an existing tariff offset program that provides cost relief for automakers assembling vehicles […] (read full article...)
Avatar of James-kd2cm
James-kd2cm
Well-known member
228 messages 413 likes
Tariffs seem to change week to week while inflation remains high.
Honestly, I can’t make sense of this news. Either I read it as Trump backed down completely OR he chose to pick his battles. Can’t figure this one out.
I also can’t figure out how much impact the truck tariffs will have. I was pretty shocked to learn we import trucks built in … Finland of all places,
I keep seeing news releases state Finland as one of 5 countries yet I can’t find any facts to back it up the more I dig into it. The White House document doesn’t state any country. It does state parts from India and Brazil along with Mexico and Canada will be excluded. They also don’t state about the tariff offset. This is maddening to try to report on!
S
Saddle Tramp
Moderator
1,105 messages 1,227 likes
I read that the Tariff situation is so complicated that companies are building cars in Japan because it's cheaper to build it there and pay one Tariff instead of building it here and paying the Tariffs on aluminum, steel, and all the components shipped in.
It seems to me people are wondering why even bother reporting on the news. IMO, it needs to be covered. If you are a fleet buyer or a new truck buyer, wouldn't you want to know what is going to happen with prices including parts prices? I sure would.
For example, I'm planning on buying either a new Ford or a new GM full-size truck next year. My news coverage suggests either one of those should be a new model. If the Ford is more expensive due to tariffs on aluminum and has less content like the 2026 model, then I'll be buying a GM truck. I'll get more truck for my money. That's why I'm covering this news. I could care less about the politics of it. This is about business.
Reply 3 likes
S
Saddle Tramp
Moderator
Reporting the news is essential. The worst things happen when people actively avoid looking.
James-kd2cm
Well-known member
Ain’t that the truth!!
