Navigating Construction Season: Safety Around Infrastructure Projects
road construction
Photo by Pixabay
Driving through places of active roadwork can be stressful even for the most experienced drivers. Changing lanes, narrowed roads, flashing lights, and heavy machinery all require additional care. During construction season, it is imperative to drive safely around infrastructure projects to avoid accidents and injuries to road workers.
Why Work Zone Safety Matters
Among the risky areas on the road are construction zones. The U.S. Bureau of Transportation Statistics reports that work zone crashes injure thousands and kill hundreds of people each year. These crashes affect both road crews and motorists alike. The National Highway Traffic Safety Administration notes that rear-end crashes are common, usually caused by drivers failing to adjust their speed or following too closely.
According to the National Work Zone Safety Information Clearinghouse, abrupt braking, changing lanes, and distraction are major factors that pose risks in such zones. All the signs, cones, and flashing lights are carefully placed to help you navigate a temporary but hazardous area safely.
Key Safety Tips for Drivers
Slow Down and Follow Posted Limits
Speed limits in work zones are not recommendations—they’re designed to protect workers and give drivers time to react. Many states double fines for speeding in these areas. In North Carolina, violators will see a minimum of a $250 fine for breaking the speed limit in a construction zone. Reducing your speed by even 10 mph can help prevent sudden stops and serious accidents.
Watch for Flaggers and Warning Signs
Flaggers are trained professionals to regulate traffic. Always obey their hand signals and the instructions posted. The Federal Highway Administration stresses that ignoring a flagger’s command is just as unsafe—and illegal—as running a stoplight. Since the signs in work zones are changed regularly, you might have to take new routes or directions on a daily basis.
Maintain a Safe Following Distance
Tailgating in a construction area can be fatal. Reduced speed implies that you should maintain some space between you and the car in front of you. Experts at recommend a three-second gap, especially in rainy or night driving. Space allows you time to react in case of a stop in traffic or an equipment encroachment to the road.
Merge Early and Cooperatively
When traffic jams up, do not be tempted to accelerate and squeeze in at the last moment. Merging early ensures the flow of traffic is maintained, and it also minimizes bottlenecks. There are states that promote “zipper merge,” which involves the use of both lanes up to the point of merge and then the drivers take turns. This is a process that the Minnesota Department of Transportation has found to minimize congestion and the road rage incidence.
Plan Ahead and Staying Patient
Delays on the road can be irritating, but road rage can contribute to road accidents and fatalities. Before heading out, check your state’s Department of Transportation website for construction schedules and possible detours. Leaving a few minutes earlier would reduce stress and the urge to drive at high speed. It is important to remember that construction delays are short-term, but the outcomes are safer bridges, smoother highways and stronger infrastructure to last several generations.
The Future of Work Zone Safety
Technology is increasingly helping to reduce risks on the road. Smart work zones have become common in many states, which have sensors, real-time traffic information, and digital message boards that alert motorists about traffic jams or road closures ahead. The Federal Highway Administration observes that these innovations have the potential to reduce rear-end collisions by up to 30 percent. These systems will continue to improve driver awareness and response time as vehicles become more connected and automated.
