Ram recall: 142k trucks recalled for high beam malfunction
2024 ram 2500
2024 ram 2500
Chrysler (FCA US, LLC) is recalling certain 2023 Ram 1500 Classic, Ram 3500 Classic, 3500 Cab Chassis, 2023-2024 Ram 2500, 4500/5500 Cab Chassis, and Ram 3500 vehicles. For this Ram recall, the steering column control module may cause the high beams to activate when the turn signal is used or activate the turn signal when the high beams are used. In addition, the turn signal self-canceling feature may not function properly. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 108, “Lamps, Reflective Devices, and Associated Equipment.”
[Related content: Ram recall: 250k HD trucks recalled for transmission fluid leak]
Turn signals and/or high beams that do not function as intended may cause confusion or reduced visibility to other road users, increasing the risk of a crash.
Dealers will inspect and, if necessary, replace the steering column control module, free of charge. Owner notification letters are expected to be mailed January 17, 2024. Owners may contact FCA US, LLC customer service at 1-800-853-1403. FCA US, LLC’s number for this recall is B2A.
If you own a 2023 Ram 1500 Classic, Ram 3500 Classic, 3500 Cab Chassis, 2023-2024 Ram 2500, 4500/5500 Cab Chassis or Ram 3500, be sure to consult the NHTSA recalls portion of the website and type in the specific VIN of your truck to see if this current Ram recall applies to your vehicle.
Ram recall information:
NHTSA Campaign Number: 23V799000
Manufacturer Chrysler (FCA US, LLC)
Components STEERING, EXTERIOR LIGHTING
Potential Number of Units Affected 142,150
Editor’s note: This information was copied directly from the NHTSA website. If you have questions or concerns about this Ram recall, please contact Stellantis North America (formerly known as FCA US, LLC) directly.
