Getting your truck ready for a road trip
2023 Ram HD Rebel
Are you thinking about taking a road trip in your truck in the near future? If so, you need to make sure that your pickup is ready for the journey.
Even though you are probably focused on where you are going to go and what you are going to do, you have to make sure that your rig can get you there.
Here are a few steps you need to follow to make sure your pickup truck is ready for the voyage ahead. So take a look, and do not hesitate to reach out to a professional if you require help preparing your pickup truck for a lengthy drive.
1. Check your oil and tires
First, you need to check the vehicle’s oil and its tires. Oil is the lifeblood of your engine. So if you allow your oil to get too low, fuel efficiency levels will suffer, and the motor itself will struggle. Without enough oil, your engine will have a greater chance of overheating, or worse… Make sure you check those oil levels, and even if your pickup truck isn’t due for an oil change for another month, go ahead and get it done ahead of that big road trip.
You also need to take a close look at the rubber rolling beneath that rig. Rotate your tires to help improve gas mileage and handling, and make sure they still have enough tread left on them to justify a road trip in the first place.
2. Test the battery
Next, go ahead and test that battery. On average, you can expect to get between three and five years of use out of an average truck battery. So if your battery is getting close to the end of its life expectancy, and a road trip is on the horizon, it might be time to play it safe and get a new one.
At the very least, you should test your battery to make sure it can still hold a charge and is not compromised in any way. That way, you don’t have to worry about having to jump your pickup truck on the side of the road.
3. Invest in a tonneau cover
If you are going on a road trip in a pickup truck, chances are there’s going to be some pretty valuable equipment in the bed out back.
A tonneau cover protects everything that is exposed on the rear end of a pickup truck, making it harder for someone to steal cargo out of your rig’s bed. The trick is finding a cover that will not only deter thieves, but also protect against inclement weather. Consider taking a look at a few options to figure out which one is best for your needs. If you happen to be a fan of the venerable F-Series, you can invest in a Ford F-150 tonneau cover for your truck.
4. Protect that interior
Do not forget to protect the interior of your pickup truck, for it too can take a beating during a road trip. There are a few ways you can go about this. For example, you might want to purchase a set of covers for your seats. That way, you can reduce the chances of your interior getting stained by someone spilling a drink, muddy or wet pants, and other forms of filth. All-season custom floor mats, and a sturdy expandable garbage bag are never a bad investment either.
5. Organize your truck’s cargo bed
Finally, do not forget to organize the cargo bed of your pickup truck. You do not want your gear to roll around in the back or come crashing forward during a sudden stop. You might want to purchase a toolbox that can be installed directly into the cargo bed. Bedside cargo carriers are another option, as they leave more space in the center of the bed for lengthier items.
At the very least, invest in some high strength bungee cords and ratchet tie-downs to keep that gear where it belongs: In the back of your pickup truck bed. There are also different dividers and organizers you can use that are tailor-made around specific platforms, so consider taking a look at a few options to decide what is best for your needs.
Get ready for the next trip
Clearly, you have to think carefully about your upcoming journey, and what your pickup truck’s strengths, weaknesses, and needs might be.
Your pickup truck needs to be ready to roll at a moment’s notice, and to minimize your chances of having to deal with a repair on the side of the road some form of maintenance must be implemented.
So before you head out, make sure you schedule an appointment with your local auto service shop. Get your pickup truck tuned up, and make sure you have all the accessories you need for a comfortable and successful journey. If you take the time to get your pickup truck ready now, you can put yourself in a position where the next trip is even more enjoyable and successful than the first.
