You’ve loaded a Ford F-150 for a towing weekend, checked the tires, and packed the recovery gear. Then a California Highway Patrol officer asks for the registration card during a traffic stop, and the glove box turns into a stack of old receipts, expired insurance cards, and manuals.
Moments like this are why truck paperwork deserves more thought than most owners give it. Only a short list needs to travel in a personal-use pickup, while a few less-obvious references can save time when a tire goes flat, your phone dies, or another authorized driver takes the truck several hours from home.
1. Current registration card
The answer to “what documents should I keep in my car?” is shorter than most glove boxes suggest. Start with the current registration card.
California treats a valid card plus the proper plate stickers as evidence of current registration, as the California Department of Motor Vehicles (DMV) explains in its registration guidance.
Keep the card readable and easy to reach. Use a thin document sleeve to protect it from dust, damp camping gear, and repeated handling without taking over the glove box.
Remove the expired card when the new one arrives. Leaving two versions side by side creates unnecessary confusion during a traffic stop or roadside check.
What should you do if the registration card or plate sticker is missing?
California provides replacement procedures for registration cards and year stickers that are lost, stolen, damaged, or illegible. One useful detail is easy to miss because ordering an online replacement year sticker through the state also includes a new registration card.
Pickup owners who need a replacement registration card can restore the document tied to the current registration without treating the issue as a renewal.
Replacement and renewal solve different problems. Replacing a card or sticker restores a missing or damaged credential, while renewal extends the registration period.
2. Proof of insurance
California requires evidence of insurance to remain in the vehicle and be available when required. Drivers can review the state’s insurance requirements for the situations when proof must be shown.
Keep the current proof within reach and remove expired versions. Your driver’s license is different because it should stay with you rather than permanently inside the truck.
Offline access deserves some thought too. Keep the insurer’s policy number on your roadside reference sheet instead of assuming the mobile app will always load when you need it.
3. One-page truck reference card
Most glove boxes are missing the document that can be most useful when something goes wrong.
Create one small card with vehicle-specific information rather than emergency contacts. Include the vehicle identification number, license plate number, factory tire size, and recommended cold tire pressure.
Add the location of the wheel-lock key if your truck uses one. Note where the jack and spare-tire tools are stored too. Someone borrowing the truck may know how to change a tire and still waste valuable time searching for equipment hidden behind or beneath the rear seat.
Copy the recommended tire pressure from the Tire and Loading Information label. The National Highway Traffic Safety Administration (NHTSA) tire guidance points drivers to the vehicle label or owner’s manual rather than the maximum pressure molded into the tire.
Modified pickups can add overall vehicle height after a lift, camper installation, or roof-rack setup. That number becomes surprisingly useful when a parking garage or low-clearance sign appears ahead.
4. Roadside and accident information
Emergency contacts belong on a separate sheet because they serve a different purpose from the truck reference card.
Keep the insurance claims number, policy number, roadside-assistance line, and one emergency contact available offline. Include a short collision checklist so another driver knows what information to collect after a crash.
Useful prompts can cover the other vehicle’s plate number and insurance information. Contact details and scene photos should also be recorded when it is safe.
Keep a pen with the sheet. The idea sounds almost embarrassingly simple until you need to exchange information with 3% battery, a cracked phone screen, or no reliable cellular service.
5. Owner’s manual or quick-reference information
Modern pickups often have searchable manuals online or inside the automaker’s app, so the full printed manual doesn’t always deserve half the glove box.
Keep the physical manual if you actually use it. Otherwise, save the official digital version for offline access and note the sections most useful on the road.
Jack instructions and spare-tire access deserve priority. Fuse information and warning-light explanations can also save time when something unfamiliar appears.
Someone borrowing the pickup should be able to reach the same information without needing your phone, password, or memory.
6. Trip-specific documents
Daily driving doesn’t require every paper connected to every future trip. Add temporary documents only when the trip calls for them.
For example, a towing weekend may involve paperwork for a separately registered trailer. Camping trips may call for a reservation confirmation, access pass, or parking permit.
Keep only the records relevant to that trip, then remove them once they no longer serve a purpose. Requirements vary by state and destination. Check the rules before leaving, then clear out old permits when the trip ends.
Which vehicle documents should stay somewhere safer?
Original titles should stay out of the pickup during routine use. Store the title somewhere secure with purchase records, loan or lease paperwork, and other sensitive ownership files.
Long-term service invoices and warranty documents can stay at home or in secure digital storage. Keep copies easy to reference when repair or warranty work comes up, but there is little benefit in leaving the full history inside the cab.
Road-use records should stay within reach, while ownership records stay protected.
Protect paperwork from real truck use
Pickup interiors can be harder on paper than a typical commuter car. Worksite dust enters the cab, wet camping gear lands behind the seat, and receipts migrate between storage compartments.
Shared trucks create another weak point. When a spouse or adult child moves the registration to a different compartment, the next driver may have no idea where it went.
Use one protective sleeve and one permanent location. Keep both away from drink holders and loose tools, then check the sleeve whenever registration or insurance changes.
Check these documents before a long drive or towing weekend
Mechanical prep usually receives most of the attention before a road trip. Spend one minute on the paperwork too.
- Confirm the registration card is current and readable.
- Check that insurance proof is current and easy to reach.
- Inspect the plate sticker for damage or poor legibility.
- Update the truck reference card if vehicle details changed.
- Check the roadside sheet for current phone and policy numbers.
- Pack trip-specific paperwork only when it applies.
Pickup Truck + SUV Talk already covers personal truck towing basics in detail. Here, the focus stays on paperwork that can slow down a trip when nobody knows where it is.
Verify your truck paperwork before the next long drive
Useful truck preparation includes more than tools and mechanical checks. Keep registration, insurance proof, and key vehicle details current and easy to reach. Roadside information should also stay available when your phone or signal fails.
Before the next road trip or towing weekend, clear out expired paperwork and check each document for damage or missing details. A few minutes in the driveway can prevent a much longer delay hours from home.
