2022–2026 Ford Maverick known problems: Shifts into neutral, no-starts and heater recalls
Aaron Turpen
Aaron Turpen
November 20, 2026
Blue 2025 Ford Maverick XLT Hybrid AWD
The Ford Maverick continues to lead the compact pickup race. A 2025 XLT Hybrid AWD is shown. (Photo by Andy Lilienthal)
The Ford Maverick name used to belong to a compact car. Since the 2022 model year, it’s been on a compact pickup that shares its underpinnings with Ford’s small SUVs. If you’re shopping for one, the known problems worth checking include unexpected shifts into neutral, hybrid no-starts and block heater recalls.
The Maverick features both conventional gasoline and hybrid powertrain options. The 2.0-liter EcoBoost engine is paired with an eight-speed automatic transmission, while the 2.5-liter hybrid uses an electronically controlled continuously variable transmission (eCVT).
Several of the powertrain issues below concern early 2022 and 2023 trucks. Ford has also recalled certain Mavericks in every model year from 2022 through 2026. Check the VIN to see what applies to a specific truck.
Engine and transmission issues
Engine compartment of a Ford Maverick
A look at the engine (Photo by Andy Lilienthal)
These recalls and service bulletins cover the Maverick’s engine, transmission and hybrid components.
12-volt positive battery cable terminal (26V-724): Ford recalled 8,650 model-year 2022 Maverick hybrids. The cable terminal can detach, preventing the truck from starting or causing a loss of propulsion, lights, power steering or braking assistance.
EGR valve failure (26V-122): On certain 2025 Mavericks with the 2.0-liter EcoBoost, the exhaust gas recirculation valve can fail and cause a loss of drive power.
Unexpected shift into neutral (25V-881, 25V-133 and 24V-330): On certain 2022–2024 Maverick hybrids, powertrain control software can force the transmission into neutral while driving. Some trucks need another software update even if they were previously serviced.
Integrated park module failure (25V-863): On certain 2025 and 2026 Maverick hybrids, the transmission may not fully engage Park. The truck can roll if the parking brake isn’t applied. Ford’s remedy is a software update.
Hybrid engine failure and fire risk (23V-380): On certain 2022 and 2023 Maverick hybrids, an engine failure can release oil or fuel vapor into the engine compartment and cause a fire. This recall expanded and replaced 22V-484, which called for physical changes to the underbody shield and grille shutters. Some trucks that received an incorrect repair were recalled again under 25V-345.
Hybrid No-Crank / No-Start (TSB 22-2340): Addresses a no-start or no-crank condition on 2022 hybrid models built before May 14, 2022, caused by a loose battery cable solder connection. Replacement of wiring assembly required.
AWD driveline shudder (SSM 52051): Some 2022 and 2023 AWD Mavericks can chatter or shudder during low-speed turns. Ford points to possible contamination of rear drive unit fluid and gives dealers a procedure to check it.
Engine Exhaust Heat Exchanger Malfunction (SSM 51921): A malfunction indicator light (MIL)/engine light with codes P2C22, P237C, and/or P237D in certain 2022 and 2023 Maverick Hybrid models. The warning lights and codes are typically caused by water intrusion in the exhaust heat exchanger.
Other Ford Maverick recalls
2025 ford maverick lobo by jill ciminillo 3
2025 Ford Maverick Lobo (Photo by Jill Ciminillo)
These are other safety recalls that can affect the Maverick. Campaigns apply to specific trucks, not every vehicle in the model years listed.
Improperly tightened fasteners (26V-550): A software error marked some assembly-plant repairs complete even though a fastener may not have been tightened correctly. Depending on the VIN, the 10 affected 2026 Mavericks each had one potentially loose fastener. Ford lists these examples:
  • Door latch
  • Air deflector
  • Luggage rack tie-down
  • Instrument panel bracket
  • Seat belt pretensioner
Front lower control arm ball joint separation (26V-340): On certain 2022–2026 Mavericks, a front ball joint can separate from the steering knuckle. Ford issued a Do Not Drive advisory for affected VINs. Contact a Ford dealer to arrange an inspection where the truck is parked or have it towed.
Occupant Classification Sensor (26V-201): Certain 2025–2026 Maverick models may have an occupant classification sensor with a defective bladder port. The defect can prevent the system from correctly determining passenger occupancy, potentially disabling the front passenger airbag and increasing the risk of injury in a crash.
Roof Opening Panel Glass Detachment (26V-157): A few 2025–2026 Maverick models could have only a partial urethane adhesion on the rooftop glass panel, creating a risk of detachment while driving.
Trailer brake controller fault (26V-104): On certain 2022–2026 Mavericks, a communication fault can disable the trailer’s brake lights or turn signals. Trucks with the High-series module can also lose trailer braking. The remedy is a software update.
Instrument Panel Cover Separation (25V-884): On certain 2025 and 2026 Mavericks, an improperly bonded instrument panel cover can separate when the passenger airbag deploys.
Block heater fire risk (25V-685): On certain 2022–2024 Mavericks, the engine block heater can crack, leak coolant and short-circuit while plugged in. A separate campaign, 26V-239, covers eight additional 2025 Mavericks in an expansion of 25V-343. Follow Ford’s instructions for the affected VIN and don’t plug the block heater in before repair.
Incorrect Rearview Camera Software (25V-442): This recall affects certain 2022–2024 Mavericks, among other Ford vehicles. A software problem can cause the rearview camera to display a blank image or continue displaying an image after the vehicle has shifted out of Reverse. This is separate from the earlier 24V-684 camera recall (below).
Airbag Indicator Light Loose (25V-350): Some 2025 Maverick models may have a loose or dislodged passenger airbag status indicator light in the dashboard. This can prevent occupants from seeing whether the passenger airbag is disabled.
Incorrect Software Fix 12 V Battery (25V-158): 2022–2023 Maverick models which underwent a software fix to remedy low battery charge detection may have had the incorrect software installed. The incorrectly performed prior software fix on recalls 24V-267 and 24V-590 could fail to detect low 12-volt battery charge, risking stall or loss of accessories.
Freeze/Blank Backup Camera Display (24V-684): A software glitch in some 2022–2024 models can cause the backup camera image to freeze or display a blank screen.
BCM/PCM Failure To Detect Low Charge State in 12-volt Battery (24V-590, 24V-267): The body and powertrain control modules in some 2022 Maverick Hybrid trucks may fail to detect a drop or change in the 12-volt battery’s state of charge. An undetected low 12-volt battery can cause a loss of electrical accessories (such as hazard lights) or result in a sudden loss of drive power while driving, increasing the risk of a crash. Maverick models repaired under these recalls may require additional updates via 25V-158 above.
BCM Rear Taillamp Shutoff (24V-293): Body Control Module (BCM) calibration may inadvertently deactivate one or both rear taillights on some 2022–2024 Maverick models.
Instrument Cluster Illumination (24V-140): Instrument panel illumination may fail upon startup, reducing visibility of gauges and warning lights in some 2022–2023 model year Maverick Hybrids.
Turn Signal Lamp Failure Detection (23V-848): Some 2022–2024 model year Maverick trucks may have a failure of the Body Control Module software to alert the driver via fast-flashing indicators when a rear turn signal bulb burns out.
Maverick technical service bulletins
2024 Ford Maverick (Photo courtesy of Ford)
A technical service bulletin (TSB) or Special Service Message (SSM) helps technicians diagnose or repair a problem. It isn’t a safety recall and doesn’t necessarily mean the repair is free.
Grabby brakes and low-speed shudder (TSB 25-2364): Some 2022 and 2023 Maverick hybrids built on or before April 11, 2023, can grab or shudder while braking at 15 mph or less. Ford directs dealers to update powertrain and related brake and hybrid control software. This bulletin supersedes 23-2248.
12-volt battery drain (SSM 54785): Ford addresses battery drain on certain 2022–2024 Maverick hybrids with air-conditioning and anti-lock brake control module software updates.
12-volt Battery Drain (SSM 53801): This Special Service Message covers software issues in the Air Conditioning Control Module (ACCM) on select 2022–2025 model year hybrids built on or before February 17, 2025, which can lead to a 12-volt battery drain.
Ford Maverick problems owners report
2025 ford maverick xlt 12
2025 Ford Maverick XLT (Photo by Tim Esterdahl)
Owners also report the following issues in forums and on social media. These reports tell you what to look for, not how often a problem occurs.
Deep Sleep Mode & Dead Batteries: A frequent complaint, particularly among Hybrid models, although owners of EcoBoost models have also reported battery-related complaints. This triggers “Deep Sleep” mode, which disables keyless entry, app connectivity, interior screens, and can prevent the truck from starting. While some TSBs have attempted to address this issue, especially in hybrid models, many owners still list it as a problem.
Interior Materials & NVH (Noise, Vibration, Harshness): Owners frequently note early-onset cabin rattles, squeaks, and cheap hard plastics. Some also report noticeable wind and road noise at highway speeds.
Infotainment & Connectivity Glitches: Some owners report that Ford’s SYNC system freezes, responds slowly or drops Apple CarPlay or Android Auto connections.
How to check for recalls on your truck
nhtsa recall search page
The easiest way to check for current recalls that may affect your Maverick is to visit the National Highway Traffic Safety Administration’s Recalls page and enter your license plate or 17-digit vehicle identification number (VIN). A Ford dealer can also check your VIN, open campaigns and repair history. Follow the instructions for your specific vehicle; a model-year listing alone does not establish that your truck is affected.
