How Visual Environments Shape the Visitor Experience at Car Events
Chicago Auto Show
People tend to choose an area for viewing before reading a word. This is the first time when visual design captures people’s attention and can help them recognize the brand, and provide a clear envelope of the car at a car event. Everything from color to contrast, image size, lighting to layout impacts people’s attention span.
The purpose is not to fill up all the spaces. It’s for establishing a visual hierarchy. The vehicle should be easily visible and graphics and signs should explain why. Studies of visual attention have revealed that individuals do not attend to all components of a scene equally, stimuli of smaller size, lower contrast and located away from the central focal point may attract less attention than others.
Create a Strong Visual Identity Across the Event Space
The event space should be as close to the brand as possible without being overstimulated for the viewer by the specifics. That begins with the use of readily identifiable brand elements, such as color, brand logo, type, images and graphic shapes. Studies on distinctive brand assets have demonstrated that frequent cues to a brand can assist in the identification and differentiation of a brand.
Color should be given special attention. A brand should stick to its brand colors and not add colors that don’t match its image. The logo should be visible in all locations but should not be over-embellished. In the case of repetition, it has to be done with a lack of visual nuisance, which means without overloading the brain.
Larger pictures can also set the atmosphere of the room. If the product in question is a new electric vehicle, for instance, it could feature photographs of the car in a clean urban environment. Different Visual Approach requirements may be needed for a performance model. The image should be informative and compliment the product, not distract from it.
There are several things that would make up a practical visual system:
  • One brand colour set of 100% is available.
  • Consistent type styles
  • An image style that is defined.
  • Repeatable graphic shapes
  • Clear rules for use of logos.
  • Consistent lighting
When these elements come together, the visitor can navigate from the entry point to vehicle, product information and meeting point without feeling one is a part of another brand.
Use Fabric Graphics to Shape the Physical Environment
Large printed surfaces can change how an event space feels without adding heavy structures. This is where seg fabric graphics can have a useful role. Silicone Edge Graphics, commonly called SEG graphics, use fabric panels with a silicone strip sewn into the edge. The strip fits into a frame channel, which holds the graphic in place and creates a smooth face across the display. This system is widely used for exhibition walls, backlit displays, and other large-format visual structures.
For automotive events, the main benefit is control over large visual areas. A graphic wall can create a clean background behind a vehicle, separate one product zone from another, or provide space for a large brand image without covering the car itself.
The image choice matters as much as the fabric. A high-resolution vehicle photograph can support the real vehicle on display, while a simple brand graphic can create a strong background with less visual competition. Large-format artwork should be prepared at the specifications required by the printer and display system so that text and important image details remain clear at the intended viewing distance.
Backlit fabric systems add another option. Light passes through the printed material, which can make selected graphics more visible in a busy exhibition hall. However, brightness should remain controlled. If the wall is much brighter than the vehicle, attention can shift away from the product.
Fabric graphics can also support changes between events. A modular frame may allow graphics to be replaced while the frame remains in use. This can help brands adapt the same basic display system for different vehicle models, campaigns, or booth sizes.
The best use of these graphics is simple: shape the space, support the brand, and keep the vehicle as the main subject. A graphic wall should provide context, not become the product itself.
Design the Visitor Path With Visual Cues
Plans for visitors’ paths to move around the display may be helpful, so that visitors can be guided through the display without the need for constant staff guidance. The path should first show a clear first view of the product, and then guide the visitor to the product features, demonstrations and conversation areas. This order can be established with the help of visual cues.
In the first place, position the primary vehicle and brand message so that visitors can view them when they are coming in from the main approach. Then create cues to direct towards the next helpful space with signs, floor layout, lighting or large graphics. The cues don’t have to be elaborate. May suffice with a clear heading, above a demonstration area.
The physical walking path should also allow for room for people to stop and “look”. This is particularly relevant if multiple cars are being viewed by multiple visitors.
The sequence to be followed should be:
  • First sight: car and make
  • Product area: main features
  • Hands on explanation: demo zone
  • Meetup point: in-depth discussion
Additionally, good visual planning helps to decrease confusion. People can avoid stepping on the path if they do not want to pass through it.
Use Visuals to Explain Automotive Products
Features of a vehicle that are hard to understand from the outside. Visual content can help bridge that gap with a picture, demonstrating a system or the location of a particular feature or how that feature aids the driver.
Include simple diagrams, short videos, product images and clear labels near the feature that they explain. For instance, a display dedicated to electric vehicles could feature the place of key battery components, or an explanation of how to charge an EV. A brief video might be a way to explain to a driver-assistance display how to detect another vehicle or react to roadways.
The best visual content provides solutions to 3 simple questions:
  1. What is the characteristic?
  2. How does it work?
  3. What does it do for you?
Attach technical information to the tangible product. A screen on the other side of the room might be correct, but the visitor must make the link to the vehicle.
Digital content is also a good option when it is not feasible or safe to demonstrate a feature. But the screen should do the work of the car and not vice versa. The physical product is the most important reference point.
This is similar to the findings of research on visual information design that indicates that well structured visual displays are more effective in helping people understand complex information than poorly structured content.
Use Color, Light, and Contrast to Shape Attention
Color, light, and contrast help establish visual priority. A bright area naturally competes for attention, so lighting should highlight the vehicle rather than distract from it.
Use brand colors consistently across major surfaces, signs, and graphic elements. Keep strong contrast between text and its background so visitors can read key information from a normal viewing distance.
Lighting should reveal important vehicle details without producing glare on glass, paint, or digital screens. A simple approach is to give the vehicle the strongest visual priority and use lower-intensity elements around it.
Contrast can also separate zones. A darker background may help a light-colored vehicle stand out, while a lighter wall can provide a clean setting for a dark model. The right choice depends on the vehicle, brand system, and venue lighting conditions.
