Do Traffic Warnings Go On Your Record: A Need-To-Know Guide
which police officers can stop you on a tn highway
While most people reading this have likely never gotten into deeply serious issues with law enforcement, it doesn’t mean we don’t all have the same familiar sensation. You are driving down the road, in mid-conversation or belting out your favorite playlist, when blue and red hues start encroaching into your periphery.
The feeling of anguish fills your stomach, and within seconds you are starting to wonder if you have any drugs or firearms in the car – and you’ve never owned either. The officer steps out, presses his thumb into the trunk of your car, and within minutes you realize you’ve been let off with a warning and feel relief wash over you as you try to look natural while pulling off.
This article is going to go into whether or not this unfortunate sidestep from your daily routine is going to have any lasting impact on you or your future. By the end of this article, you will know what to say when someone asks, “Do traffic warnings go on your record?”
The Two Types of Warnings
Before we get started, you should know that warnings are given in two different ways. The best outcome is that the officer gives you a verbal warning, stating why he stopped you and what needs to be rectified. This is a warning that stays between you, the officer, and anyone the two of you decide to relay the situation to.
The second is a written warning, which will be detailed on a paper that is given to you by the officer that pulled you over. These warnings, if you obtain multiple in a limited amount of time, increase your chances of not being let off with a warning in future stops. For most written warnings, say your tags are out of date, you will need to fix the issue in an allotted time.
Do Traffic Warnings Go on Your Record? What Do Warnings Affect?
The first thing to understand is that warnings do not go on your record. If you are worried about your record being marred by traffic stops, there are ways to check your record online. As we discussed above, written warnings will increase the likelihood that you may be given a ticket or citation in the future.
Similarly, they will not affect your insurance. A warning will not increase your rates, though if you end up getting enough warnings that you receive a citation, that may increase your insurance rate. If you are let off with a warning for a vehicular issue, fix the issue as soon as possible. If you are given a warning for speeding or running a stop, be more mindful going forward.
Overwhelmingly, speeding is the reason that most people are pulled over, as it is the most obvious thing a cop will notice. As everyone has seen, speeds are monitored regularly, and if you are going exceedingly high, you can expect to be pulled over. Similarly, keep an eye on complete stops, and obviously do not drive while under the influence.
Last Look at Do Traffic Warnings Go on Your Record
Traffic warnings will not appear on your record, but you should still do your best to avoid them at all costs. Traffic warnings, when they are written, will show up in future traffic stops if it has been a short amount of time. Similarly, if the written warning is something that needs to be fixed, ensure that you have solved the issue in a timely manner.
Many times, officers will give a driver a verbal warning if they feel the issue is a one-time thing. If this is the case, there really is no trace of the interaction unless the same officer pulls you over again. Warnings, both written and verbal, will not increase insurance rates, and drivers should not worry about paying more per month.
