2021-2023 Ford F-150, 2023-2026 F-250 Recall: 47K Obstructed Rearview Camera Image
Bianca Bailey
Bianca Bailey
August 5, 2026
2026 Ford F-250 (Photo courtesy of Ford Motor Company)
A recall of 47,587 Ford F150 and F250 trucks for an obstructed rearview camera image.
Ford Motor Company (Ford) is recalling certain 2021-2023 F-150 and 2023-2026 F-250 SD vehicles equipped with 8-inch SYNC infotainment screens. A software error may cause the rearview camera image to be obstructed by the infotainment home screen menu when the vehicle is placed in reverse. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 111, “Rear Visibility.”
NHTSA ID Number: 26V489
Components: BACK OVER PREVENTION
Potential Number of Units Affected: 47,587
Descriptive Information
On F-250 trucks the recalled part was introduced into production on 3/16/2022 and was taken out of production on 6/1/2026.
On F-150 trucks the recalled part was introduced into production on 1/30/2020 and was taken out of production on 12/22/2023.
Affected vehicles are equipped with Accessory Protocol Interface Module (APIM) software prior to version 2.4.12, which in certain conditions may display the camera view menu over the rearview image in Reverse.
23,179 F-250 vehicles are affected.
24,408 F-150 vehicles are affected.
If a customer leaves the camera “Views” menu open on the SYNC 4 screen and shifts the vehicle into Reverse, the menu overlay does not auto-dismiss. As a result, the menu persists on the screen and will remain on until either (a) the user selects a view or closes the menu, or (b) the vehicle is shifted to Drive and speed exceeds 5 mph. If tested according to FMVSS No. 111, the menu overlay on these vehicles will partially cover certain test objects in the Rear View Camera (RVC) image.
A rearview camera image that is noncompliant with FMVSS No. 111 could increase the risk of a crash.
Description of the cause:
Affected vehicles contain APIM software that does not dismiss the camera views menu in reverse incertain conditions.
None.
Chronology
On May 14, 2026, an issue pertaining to a camera views menu that did not dismiss as expected when the vehicle was shifted into Reverse was brought to Ford’s Critical Concern Review Group (CCRG) for review. CCRG reviewed data from the ADAS engineering team showing that the condition can be consistently reproduced by a sequence of customer inputs: if a driver manually activates a camera view (such as the Front View Camera) while not in Reverse, opens the camera views menu, makes no selection, and then shifts into Reverse, the camera views menu fails to auto-dismiss, remaining on-screen and potentially obscuring a portion of the rearview camera image.
During late May and June 2026, CCRG and ADAS engineering teams conducted a read-across of all SYNC 4 vehicle lines, considering every build configuration for display size, screen orientation, and available camera views. CCRG and the Ford Rear Visibility Subject Matter Expert evaluated the rearview image with each configuration against the Field of View requirements of FMVSS 111, Section S5.5.1. The team identified two specific vehicle configurations—Model Year 21-23 F-150 and MY23-26 Super Duty equipped with 8-inch landscape displays and 360 view camera system—where the persistent menu overlay obscured one of the required test objects specified in the NHTSA Laboratory Test Procedure (TP-111V-01, Section C – Default View). Other vehicle configurations use the same software and will have a menu overlay that can persist after shifting into reverse if the entry conditions are met; however, in those configurations, the menu overlays only minimally interfere with the camera image and do not obscure any test objects.
On July 8, 2026, Ford’s Automotive Safety Office (ASO) reviewed the technical findings with the NHTSA Office of Vehicle Safety Compliance (OVSC).
As of July 14, 2026, Ford’s Automotive Safety Office (ASO) and CCRG confirmed that no other global safety or compliance standards are impacted by this condition. Ford is not aware of any warranty reports or Vehicle Owner Questionnaires (VOQs) related to this concern.
On July 21, 2026, Ford’s Field Review Committee reviewed the concern and approved a field action for the affected F-150 and Super Duty vehicle populations.
Ford is not aware of any reports of accident or injury related to this condition.
Remedy
Description of Remedy
Remedy Type: Software, Software OTA
The remedy for this program is an APIM software update. Ford is anticipated to begin Ford Software Update Over-The-Air (OTA) deployment to update the APIM software for affected vehicles in August 2026. Alternatively, owners will have the option to take their vehicle to a Ford or Lincoln dealer to complete the software update. There will be no charge for this service.
The remedy APIM software level will be version 2.4.12 or above and will include improvements to dismiss the camera views menu while in reverse.
Notification to dealers is expected to occur on July 31, 2026. Mailing of interim owner notification letters is expected to begin August 17, 2026 and is expected to be completed by August 21, 2026. Mailing of remedy owner notification letters is expected to begin September 21, 2026 and is expected to be completed by October 23, 2026. The date VINs are planned to be searchable is July 31, 2026.
