2019 Lincoln Navigator, Nautilus, More Recall: 4K Instrument Cluster Issu
2019 lincoln navigator cr
2019 Lincoln Navigator (Photo courtesy of Consumer Reports)
A recall of 4,151 Ford Mustangs, Lincoln MKX, and Lincoln Navigators for instrument clusters that may go blank on startup.
Ford Motor Company (Ford) is recalling certain 2019 Ford Mustang, Lincoln Nautilus, and Lincoln Navigator vehicles previously repaired incorrectly under recall number 19V076. At vehicle start-up, the Instrument Panel Cluster Assembly (IPC) may not function, showing a blank display. As a result, these vehicles fail to comply with Federal Motor Vehicle Safety Standard (FMVSS) number 101, “Controls and Displays.”
NHTSA ID Number: 26V372
Components: ELECTRICAL SYSTEM
Potential Number of Units Affected: 4,151
Descriptive Information
The Ford process is capable of determining which software part numbers have been installed in production and service. Affected vehicles may not have received the Instrument Panel Cluster (IPC) system software remedy for Ford Recall 19C03 / 19V076.
1,802 MKX vehicles are affected.
1,406 Navigator vehicles are affected.
943 Mustang vehicles are affected.
According to Ford’s records, certain 2019 model year Ford Mustang and Lincoln Navigator and Nautilus vehicles did not have the remedy for Safety Recall 19C03 / 19V-076 installed correctly but were recorded as having the repair successfully completed. Because the correct software update remedy may not be installed on the vehicle, the underlying condition specified in Safety Recall 19C03 / 19V-076 may still exist, and the operators may experience a blank instrument cluster display upon key-on, including PRNDL illumination, gauge indicators and telltale warning lights.
The underlying safety risk specified in Safety Recall 19C03 / 19V-076 still exists on this specified vehicle. Ford described that safety risk as, “An inoperative IP cluster may not provide the specific controls, telltales and indicators at vehicle start-up as required in FMVSS 101, increasing the risk of a crash.”
Description of the cause:
During high-temperature bench testing, the supplier identified an issue with the 2GB memory chips in the LX and SX level cluster assemblies where certain clusters may not properly load the data required to run the display, resulting in blank cluster at start-up.
This condition can only occur at key-on, prior to vehicle operation.
Chronology
On November 26, 2024, an issue pertaining to incomplete software recall remedies was brought to Ford’s Critical Concern Group (CCRG) for review. This issue was initially identified in a Quality Office forum, where an audit was requested for software part numbers applied to vehicles remedied under a sample of field service actions (FSAs). Initial review of three FSAs revealed insufficient data to confirm correct software application across all FSAs using the current field service tool, known as FDRS. CCRG decided to conduct further investigation.
In December 2024, a cross-functional team was formed to audit all software FSAs that used the FDRS service tool, with its first focus being on safety and compliance FSAs. Templates were created to track software lineage part numbers.
On December 19, 2024, Ford informed NHTSA of this concern — the service tool data confirmed that the software state on the service tool at the time of installation matches the FSA software release for most vehicles. However, there are vehicles that do not have a match between the software state on the service tool and the FSA software release. Ford discussed with NHTSA its plan to address the mismatched vehicles.
In January 2025, the cross-functional team created database records to store all software lineage part numbers for previously launched FSAs. The team then began auditing the current software level for every VIN repaired under several previously launched FSAs.
In March 2025, during a comprehensive audit of software-related FSAs dating back to 2017, discrepancies were identified during the transition between the legacy field service tool, known as IDS, and the new FDRS service tool. The audit revealed that implementation inconsistencies found in FDRS could also be present within the IDS software as well as a significant lack of historical data. Further investigation was deemed necessary.
In November 2025, a harvest program was approved to assess the success of remedies applied using the IDS tool for programs administered during this transition period. Results of this harvest program showed that in some FSAs, the intended remedy software may not have been successfully applied to all vehicles.
On April 16, 2026, the matter was presented to the Critical Concern Review Group (CCRG). The CCRG determined that several FSAs that had a recall remedy implemented using the IDS tool may have been closed without that remedy being installed. As a result, an activity was initiated to verify the software levels of vehicles that previously received these FSA repairs. The VINs included in this program are both (1) VINs confirmed to contain the incorrect software, and (2) VINs with a closed FSA, but the software version cannot be confirmed due to gaps in the records.
On May 27, 2026, Ford’s audit team confirmed that the software state matched the FSA software release in a subset of vehicles out of the total population of completed FSA 19C03 remedy repairs.
On June 2, 2026, Ford’s Field Review Committee reviewed the concern and approved a field action.
Ford is not aware of any reports of accident or injury related to this condition.
Remedy
Description of Remedy
Remedy Type: Software
Owners will be notified by mail and instructed to take their vehicle to a Ford or Lincoln dealer to have the IPC software updated. Then, the software part numbers will be validated using the Software Validation Form in the Professional Technician System before the FSA is closed. There will be no charge for this service.
Ford provided the general reimbursement plan for the cost of remedies paid for by vehicle owners prior to notification of a safety recall in May 2023. Owners who have paid to have these repairs completed at their own expense may be eligible for reimbursement, in accordance with the recall reimbursement plan on file with NHTSA.
The software service package will have the intended remedy for 19C03 / 19V-076.
Notification to dealers is expected to occur on July 6, 2026. Mailing of remedy owner notification letters is expected to begin July 6, 2026 and is expected to be completed by July 10, 2026. The date VINs are planned to be searchable is July 6, 2026.
