2017 Ford F-150 Recall: 4K Instrument Cluster Failure
2017 ford f 150
2017 Ford F-150 (Photo courtesy of Ford Motor Company)
A recall of 4,445 Ford F-150s for instrument clusters that may lose power and fail to display critical safety information.
Ford Motor Company (Ford) is recalling certain 2017 F-150 vehicles previously repaired incorrectly under recall number 17V053. The instrument cluster may lose power after initial vehicle start-up in cold ambient temperatures. Several gauges, including the transmission gear position indicator, may not illuminate. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 102, “Transmission Shift Lever Sequence, Starter Interlock, and Transmission Braking Effect.”
NHTSA ID Number: 26V370
Components: ELECTRICAL SYSTEM
Potential Number of Units Affected: 4,445
Descriptive Information
The Ford process is capable of determining which software part numbers have been installed in production and service. Affected vehicles may not have received the Instrument Panel Cluster (IPC) software remedy for Ford Recall 17C01 / 17V053.
4,445 F-150 vehicles are affected.
According to Ford’s records, certain 2017 Ford F-150 vehicles did not have the remedy for Safety Recall 17C01 / 17V-053 installed correctly but were recorded as having the repair successfully completed. Because the correct software update remedy may not be installed on the vehicle, the underlying condition specified in Safety Recall 17C01 / 17V-053 may still exist, and immediately after engine start-up in cold ambient temperatures, operators may experience a loss of instrument cluster display functionality, including the loss of PRNDL illumination, jittering gauge pointers and flashing on/off warning lights. Loss of instrument cluster functionality may range from two seconds to several minutes.
Ford is not aware of any reports of accident or injury related to this condition.
The underlying safety risk specified in Safety Recall 17C01 / 17V-053 still exists on this specified vehicle. Ford described that safety risk as, “The transmission shift position indicator located in the instrument panel cluster may not illuminate and display the selected transmission gear position. Increasing the risk of injury or crash from unintended vehicle movement. In addition, an inoperative instrument panel cluster display may prevent activation of certain warning chimes, messages, and warning lights.”
Description of the cause:
Immediately after engine start-up in cold ambient temperatures, the power supply within the eight inch instrument cluster productivity screen may be unable to maintain electrical output control.
None.
Chronology
On November 26, 2024, an issue pertaining to incomplete software recall remedies was brought to Ford’s Critical Concern Group (CCRG) for review. This issue was initially identified in a Quality Office forum, where an audit was requested for software part numbers applied to vehicles remedied under a sample of field service actions (FSAs). Initial review of three FSAs revealed insufficient data to confirm correct software application across all FSAs using the current field service tool, known as FDRS. CCRG decided to conduct further investigation.
In December 2024, a cross-functional team was formed to audit all software FSAs that used the FDRS service tool, with its first focus being on safety and compliance FSAs. Templates were created to track software lineage part numbers.
On December 19, 2024, Ford informed NHTSA of this concern — the service tool data confirmed that the software state on the service tool at the time of installation matches the FSA software release for most vehicles. However, there are vehicles that do not have a match between the software state on the service tool and the FSA software release. Ford discussed with NHTSA its plan to address the mismatched vehicles.
In January 2025, the cross-functional team created database records to store all software lineage part numbers for previously launched FSAs. The team then began auditing the current software level for every VIN repaired under several previously launched FSAs.
In March 2025, during a comprehensive audit of software-related FSAs dating back to 2017, discrepancies were identified during the transition between the legacy field service tool, known as IDS, and the new FDRS service tool. The audit revealed that implementation inconsistencies found in FDRS could also be present within the IDS software as well as a significant lack of historical data. Further investigation was deemed necessary.
In November 2025, a harvest program was approved to assess the success of remedies applied using the IDS tool for programs administered during this transition period. Results of this harvest program showed that in some FSAs, the intended remedy software may not have been successfully applied to all vehicles.
On April 16, 2026, the matter was presented to the Critical Concern Review Group (CCRG). The CCRG determined that several FSAs that had a recall remedy implemented using the IDS tool may have been closed without that remedy being installed. As a result, an activity was initiated to verify the software levels of vehicles that previously received these FSA repairs. The VINs included in this program are both (1) VINs confirmed to contain the incorrect software, and (2) VINs with a closed FSA, but the software version cannot be confirmed due to gaps in the records.
On May 27, 2026, Ford’s audit team confirmed that the software state matched the FSA software release in a subset of vehicles out of the total population of completed FSA 17C01 remedy repairs.
On June 2, 2026, Ford’s Field Review Committee reviewed the concern and approved a field action.
Remedy
Description of Remedy
Remedy Type: Software
Owners will be notified by mail and instructed to take their vehicle to a Ford or Lincoln dealer to have the Instrument Panel Cluster (IPC) software updated. Then, the software part numbers will be validated using the Software Validation Form in the Professional Technician System before the FSA is closed. There will be no charge for this service.
Ford provided the general reimbursement plan for the cost of remedies paid for by vehicle owners prior to notification of a safety recall in May 2023. Owners who have paid to have these repairs completed at their own expense may be eligible for reimbursement, in accordance with the recall reimbursement plan on file with NHTSA.
The software service package will have the intended remedy for 17C01 / 17V-053
Notification to dealers is expected to occur on July 6, 2026. Mailing of remedy owner notification letters is expected to begin July 6, 2026 and is expected to be completed by July 10, 2026. The date VINs are planned to be searchable is July 6, 2026.
