How Automotive Trends Are Shaping New PCB Manufacturing Standards
Automotive trends are driving changes in how PCB manufacturing is conducted. Makers must adhere to stringent regulations for quality and reliability. The IATF 16949:2016 standard necessitates robust quality control measures. DIN EN 60068-2 outlines environmental requirements. OEMs establish their own performance standards.
SegmentCAGR (%)Market Size (2024)
EV-related PCBs10USD 12.5 Billion
ADAS-related PCBs9N/A
Connected car PCBs7.5N/A
Automotive Trends
Electrification and EVs
Electric vehicles have changed how PCBs are made. Engineers work to keep PCBs cool. They use heat sinks and layers to handle more power. PCBs must also resist shaking, so designers add special materials. System-in-Package helps make parts smaller. Flexible and rigid-flex PCBs fit into small spaces. People care more about the environment now. So, makers use lead-free solder and green materials. PCBs must be safer and last longer. Thicker copper and controlled impedance help with this. Makers follow strict rules and test PCBs a lot. This stops problems and saves money on repairs.
  • Better cooling and less shaking
  • Smaller parts with new packaging
  • Flexible and rigid-flex PCBs for tight spaces
  • More focus on being green and reliable
ADAS and Safety Systems
Safety systems and ADAS need special PCBs. These boards keep signals safe for radar and cameras. The table below lists important PCB features for these systems:
FeatureDescription
PCB OptionsSingle, double, and multilayer PCBs for different car jobs.
Advanced HDI StackupsHelps with tiny parts and tricky wiring for ADAS.
Controlled Impedance DesignsMakes sure radar and fast data lines work right.
Material OptionsUses FR4, PTFE, and mixes for speed and strength.
High-Density Layout SupportLets ECUs and ADAS have lots of circuits.
Blind, Buried, and Microvia StructuresGives more ways to connect and control signals.
Surface FinishesProtects copper and makes boards last longer.
Quick-Turn Prototyping ServicesLets engineers test ideas fast and fix designs quickly.
ADAS is growing fast because of new safety laws. Electric and smart cars also help this growth.
Connectivity Features
New cars have more ways to connect. This makes PCBs more complex. Cars now use central control units and zonal designs. These changes let cars get software updates and use less wiring. Engineers add more layers to PCBs for CAN, LIN, and Ethernet. Each control unit has more parts, like microcontrollers and chips. The market for connected cars is getting bigger, especially for fancy cars. Infotainment, telematics, and updates are now common. PCB makers build boards with more parts and harder designs.
Automotive PCB technology keeps changing to meet new needs in cars.
PCB Manufacturing Requirements
Industry Standards Compliance
Automotive PCB makers must follow strict rules for safety. IPC-6012DA tells how to make strong and well-controlled PCBs. IATF 16949 adds more rules to ISO 9001 just for cars. This helps lower mistakes and makes work faster. It also checks for risks and how good suppliers are. IPC-A-610 shows what good electronic assemblies look like. North America and Europe lead in new car electronics. Asia-Pacific is growing fast because they make a lot and use more electric cars. The LAMEA area is growing as more factories open. Suppliers must follow AEC-Q100 and AEC-Q200 for parts. These rules make sure car electronics are safe and work well.
Reliability and Durability
Automotive PCBs need to last in tough places. They face hot and cold, shaking, and bumps every day. Engineers build boards to last many years and work in hard spots. The table below lists important things for reliability and strength:
Benchmark TypeRequirement Details
Operating Temperature Range-40°C to 125°C (150°C peak for engine components)
Humidity ResistanceMust withstand 85°C/85% RH for 1000+ hours
Design Lifespan15 years or 200,000 km
Compliance StandardsAEC-Q100 (ICs), AEC-Q101 (discrete semiconductors), AEC-Q200 (passive components)
Testing RequirementsThermal cycling (-40°C to 125°C, 1000 cycles), Mechanical vibration (50Hz–2000Hz)
Material SelectionHigh-Tg laminates (Tg ≥ 170°C), ceramic substrates, metal-core PCBs
Engineers use special tests to guess how long PCBs will last. They heat and wet the boards for 1,000 hours. Vibration tests look for weak spots, like cracked solder or broken lines. MIL-STD-810 and ISO 16750-3 help make sure PCBs can handle real car use.
  • Hot and cold can stress the board.
  • Shaking might break some parts.
  • Bumps test how strong the board is.
Materials and Testing
PCB makers use new materials to make boards work better. High-performance FR-4 laminates handle heat well. RF materials like PTFE and ceramics help with fast signals. Metal bases, like aluminum and DBC, move heat away fast. Copper foil types, like HDI and RTF, stick well and lose less power. ENEPIG and ENIG keep boards easy to solder and last longer. Solder mask inks protect from heat and chemicals.
Material TypeKey Properties
High-performance FR-4 laminatesGlass transition temperature (Tg), decomposition temperature (TD), coefficient of thermal expansion (CTE)
RF materials (PTFE, ceramics)Low-loss characteristics for high-frequency applications
Metal substrates (aluminum, DBC)Superior thermal conductivity for power module PCBs
Copper foil (HDI, RTF)Ductility, surface roughness for strong bonding and minimized skin effect losses
Surface treatments (ENEPIG, ENIG)Eco-friendly processes ensuring solderability and long shelf life
Solder mask inksHigh thermal resistance, strong adhesion, chemical corrosion resistance
Car PCB testing is tougher than in other fields. Engineers use thermal cycling to see if boards handle hot and cold. Thermal shock tests check how boards do with quick changes. Vibration tests find weak spots in the design.
Testing ProtocolPurpose
Thermal CyclingAssesses PCB’s ability to endure temperature fluctuations without compromising functionality.
Thermal ShockEvaluates PCB’s response to sudden temperature changes, ensuring it can withstand abrupt variations.
Vibration TestingIdentifies weak points in design or manufacturing under mechanical vibrations encountered in vehicles.
Engineers pick materials and tests carefully. This makes sure car PCBs are safe and work well.
Production Process Impact
Precision Engineering
Automotive PCB manufacturing needs careful engineering. Engineers pick materials that handle heat and shaking. They place parts so signals do not mix up. Flexible parts help absorb shocks. Impedance matching keeps signals fast. These steps help PCBs work in tough places. Automotive PCBs last longer than regular electronics. They face heat, cold, shaking, oil, and fuel. Safety matters a lot. If a PCB fails, it can cause big trouble.
Precision engineering makes PCBs more reliable. It helps new car technology grow.
Quality Control
Quality control is very important for making automotive PCBs. Companies use process control to keep things steady. They check suppliers to make sure materials are good. They keep records so they can track everything. FMEA helps find risks and fix them. Tests like thermal cycle, shock, and vibration check if PCBs can handle real life. Standards like IATF 16949 guide quality checks. Zero-defect rules mean every PCB gets checked.
Quality Control MeasureDescription
Process ControlMakes manufacturing steady and reliable.
Supplier AuditsChecks if suppliers use good materials.
DocumentationKeeps records for tracking parts.
Continuous ImprovementUses FMEA to find and fix problems.
Testing ProtocolsMakes sure PCBs work and are safe.
Compliance with StandardsFollows IATF 16949 for quality checks.
Supplier Selection
Picking suppliers is stricter now. Companies want suppliers who follow ISO 26262 and AEC-Q100. They choose parts that meet these rules. Strong design and testing are needed. Automated tools like optical and X-ray check quality. Suppliers must keep records and reports. Companies look for backup sources to avoid running out of parts. They work with suppliers to get what they need.
  • Following industry rules
  • Strong testing steps
  • Automated checks for quality
  • Keeping records and reports
  • Flexible sourcing and teamwork
CompanyContribution to PCB TechnologyImpact on Automotive Trends
Unimicron TechnologyHigh-density PCBs make circuits work better.Helps small systems in EVs and smart cars.
Chin PoonEco-friendly PCBs use green materials.Supports cleaner tech in cars.
Delphi TechnologiesHigh-performance PCBs help EVs and batteries.Gives strong support for electric car power.
Daeduck ElectronicsMulti-layer PCBs help data in smart systems.Makes sensors and automation more reliable.
Meiko ElectronicsSmall, powerful PCBs help connected cars.Lets cars talk in real time and use V2X tech.
Wonderful PCB’s Automotive PCB Manufacturing and Assembly Services
Comprehensive Manufacturing Capabilities
Wonderful PCB is known for many manufacturing choices. They make single, double, and multilayer PCBs for cars. Advanced HDI stackups help with small parts and tricky wiring. Engineers use controlled impedance designs for radar and fast data lines. They pick materials like FR4, PTFE, and hybrids for speed and reliability. High-density layouts support ECUs, ADAS, and EV power electronics. Blind, buried, and microvia structures give more ways to connect parts. Surface finishes like ENIG and hard gold make boards last longer. Quick-turn prototyping lets engineers test ideas quickly.
CapabilitiesSpecifications
Advanced HDI StackupsHelps with tiny parts and tricky wiring.
Controlled Impedance DesignsWorks for radar and fast data lines.
Material OptionsFR4, PTFE, and hybrid materials for speed and strength.
High-Density Layout SupportLots of circuits for ECUs and power electronics.
Blind, Buried, MicroviaMore ways to connect and manage signals.
Surface FinishesENIG, OSP, hard gold, and immersion tin for strong boards.
Quick-Turn PrototypingLets engineers test designs fast before making lots.
Automotive-Grade Quality Assurance
Wonderful PCB uses strict checks to meet car standards. They follow IATF 16949 rules for quality. Process control keeps production steady. Supplier audits make sure materials are good. Full documentation tracks every step. Continuous improvement uses FMEA to fix risks.
  • Follows IATF 16949 rules
  • Uses process control for steady work
  • Checks suppliers for good materials
  • Keeps records for tracking
  • Improves with FMEA
CertificationDescription
IATF 16949Quality management for cars
IPC-6012 Class 3Certification for strong electronics
Custom Solutions for Automotive Applications
Wonderful PCB gives custom solutions for special car needs. They design custom Battery Management Systems (BMS) for different vehicles. Integration services connect BMS with power electronics and communication systems. Testing and validation check function, environment, and safety. Specialized PCB design meets industry standards. High-quality production and assembly make boards strong. Reverse engineering helps improve old designs and save money.
Service TypeDescription
Custom BMS DevelopmentCustom BMS for special car needs.
Integration ServicesBMS connects with power and communication systems.
Testing and ValidationChecks function, environment, and safety.
Specialized PCB DesignDesigns for car standards and needs.
ManufacturingHigh-quality production for car demands.
AssemblyStrong assembly for tough places.
Reverse Engineering and CloningMakes old designs better and cheaper.
Wonderful PCB helps car clients with quick service, strong boards, and lower costs.
Automotive trends make PCB makers follow new rules. Companies need to change fast because technology and safety keep improving. To stay ahead, manufacturers and suppliers should do these things:
  1. Check their work often with audits and inspections.
  2. Get important certificates like ISO 9001 and IPC-6012.
  3. Use good systems to control quality.
  4. Team up with partners who know what they are doing.
