Is Turbocharged Engine Reliability Worse Than a V8? Engineer who Designed Both Explains Reality
January 30, 2026
3 comments
Turbocharged Engine Reliability 1
Is a turbocharged engine going to be unreliable simply due to its nature? (Photo courtesy Stellantis)
During a recent interview, Stellantis Director of Propulsion Engineering Alan Falowski addressed the concerns about turbocharged engine reliability explaining the history behind the fears and how those don’t apply anymore. He was part of the team that designed the Hemi V8 and now lead the team that designed the Hurricane inline 6 twin-turbocharged engine.
Turbocharged Engine Reliability Concerns Are Rooted in the Past
Turbocharged Engine Reliability 2
There is a lot of distrust for turbocharged engines out there. (Photo courtesy Stellantis)
Falowski acknowledged that distrust of turbocharged engines didn’t come out of nowhere. Early gasoline turbos earned a reputation for failure decades ago.
“Back in the ’80s and ’90s, turbos were often added to engines that were never designed to be turbocharged,” Falowski said. “As a result, you did have some reliability issues.”
Those engines struggled with heat, lubrication, and materials not suited for boost. According to Falowski, many of today’s criticisms are still based on those outdated experiences.
Modern Turbo Engines Are Designed for Boost From Day One
Turbocharged Engine Reliability 3
When you start with the idea of being a turbocharged engine from day 1, it is a lot different than the old days. (Photo courtesy Stellantis)
Falowski emphasized that the Hurricane engine was engineered as a turbocharged platform from its earliest design phase—not adapted later.
“When you start from the very beginning knowing this is going to be a turbocharged engine, you can determine cylinder pressures, temperatures, cooling requirements, and materials upfront,” he explained.
Using modern simulation and analysis tools, engineers design the block, cooling system, and internal components specifically to withstand sustained boost, eliminating the compromises that plagued earlier turbo conversions.
Diesel Engines Prove Turbos Can Be Durable
Turbocharged Engine Reliability 4
Turbocharged engines aren’t new. They have been used for years in different applications. (Photo courtesy Stellantis)
To reinforce his argument, Falowski pointed to diesel engines as a long-standing example of turbo reliability.
“Turbochargers have been used on diesel engines for a long time, and diesel engines are known for reliability,” he said.
He noted that the same durability principles used in turbo diesel development—thermal control, lubrication management, and structural strength—are now applied to gasoline turbo engines like the Hurricane.
Cooling and Testing Are Key to Long-Term Reliability
Turbocharged Engine Reliability 5
Engineers push the engines much further than customers will ever do with their vehicles. (Photo courtesy Stellantis)
One of the biggest historical turbo failure points was oil coking caused by excessive heat. Falowski said Stellantis directly addressed that issue.
“We use a low-temperature cooling circuit to cool the turbocharger, even after the engine is shut down,” he said. “That prevents oil coking, which was a major cause of turbo failures in the past.”
Beyond cooling, the Hurricane undergoes aggressive durability testing designed to simulate a full engine lifespan in a compressed timeframe.
“We run engines at peak power for hundreds of hours,” Falowski added. “Most customers might only see peak power for about 30 minutes over the life of the engine.”
Bottom Line
Turbocharged Engine Reliability 6
Should you fear turbocharged engines? That’s up to you. (Photo courtesy Stellantis)
Falowski’s message was clear: turbocharged engines aren’t unreliable by nature. When they are purpose-built, properly cooled, and rigorously tested, modern turbo gasoline engines can deliver durability on par with—or better than—older naturally aspirated designs.
2,834 messages 4,724 likes
During a recent interview, Stellantis Director of Propulsion Engineering Alan Falowski addressed the concerns about turbocharged engine reliability explaining the history behind the fears and how those don’t apply anymore. He was part of the team that designed the Hemi V8 and now lead the team that designed the Hurricane inline 6 twin-turbocharged engine. Turbocharged Engine Reliability Concerns Are Rooted in the Past Falowski acknowledged that distrust of turbocharged engines didn’t come out of nowhere. Early gasoline turbos earned a reputation for failure decades ago. “Back in the ’80s and ’90s, turbos were often added to engines that were never […] (read full article...)
Reply 3 likes
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
"What!? Heresy I say! Absolute heresy!"
What's that noise in the distance? Sounds like steel on flint.....yep, they're starting to light the torches......lol
Reply 3 likes
I'm not sure if most people are aware of this, but it has been 15 years since the first EcoBoost made its way in the F-150. It is now the engine family of choice for Ford SUVs and is in most F-150 trucks. Yet, it is still the same argument till this day that the engine is unreliable and won't last more than 100k miles. I've even seen people say it won't last 30k miles.
Avatar of Hilux
Hilux
Well-known member
461 messages 775 likes
It's not the engine that's the problem, its all of the ridiculous complicated crap they bolt onto it, the giant complex plastic thermostat for instance, or a wet belt oil pump belt, its ridiculous.
