Why 275/60R20 Sizes Are Common on Crossovers and Trucks
Unpack the symbology of 275/60R20 printed on a tire’s sidewall, and you find that this series of letters and numbers actually contains lots of useful information about this particular tire’s size, construction, and application.
This is part of the reason that this is such a popular fitment for 21st-century SUVs, crossovers, and pickups. The 275 is the width of the tire, in millimeters, and suggests a wide tire that will generate a lot of grip on-road. 60, meanwhile, is the ratio of height to width of the sidewall, suggesting that it is relatively tall, which helps absorb impacts from any road irregularities and protects the wheel and suspension from damage through the lifetime of the tire. The R indicates radial construction, by far the industry standard these days, and 20 indicates the diameter of the wheel, in inches. That’s how you get 275/60R20 tires. Continue reading to find out why this series is fitted to so many SUVs and crossovers.
On-Pavement Performance: Ride, Handling, and Comfort
There are a few reasons why so many drivers are sold on 275/60R20 tires. For one, they tend to offer some of the most comfortable rides on the tarmac in the segment. That’s mostly because the tall sidewall referenced above gives the tire more opportunity to smooth out irregularities in the road surface, making driving every day a little bit more rewarding. On a clean highway, 275/60R20 tires often transmit a more settled, more composed ride to passengers, and with less impact harshness than their lower sidewall-height counterparts. Over bumps, cracks, and urban decay, the thicker band of rubber placed between the wheel and the road offers an extra layer of suspension protection.
The steering and handling of a quality set of 270/60R20 tires doesn’t underwhelm, either. If you asked us, it actually punches above. The 275mm width of the tire means that when you turn the steering wheel or change lanes, there’s a lot of rubber underneath. The resultant benefits are many, whether in increased cornering grip, stability at speed, or a little more assurance when you make a hasty lane change to catch an exit you nearly missed. The handling doesn’t feel truly “clicky” like it does on an ultra-high-performance tire, but it’s perfectly calibrated on something designed for a crossover. If you’re a driver with some extra enthusiasm behind the wheel, and you’re thinking of other ways the 275/60R20 tires let you feel the steering, you may consult the pages that discuss driving position and how the distance to the steering wheel affects steering feel and impression of control; these suggest the best seating arrangement for you, as the way in which they change the distance makes the tire feel through the steering wheel.
The overall noise of the tire has a lot to do with the design of any particular tread pattern, but as a general rule, highway and all-road-season 275/60R20 tires are built to offer a hushed feel on the street. Really technical all-terrain tires can feel like a loud chorus, but these are not the semi-good looks that one cannot praise. All in all, most well-designed 275/60R20 tires are exceptionally quiet on the street, even on longer hauls. For those drivers who split time between on and off-road adventures, this means it offers the driver a well-balanced combination of all factors that give comfort and assurance.
Off-Road Capability: Traction and Resistance
Not only are 275/60R20 tires good for on-road manners, but these tires are also beneficial for going off-road. The most off-road benefit is the better grip due to its wider surface that spreads the weight of the vehicle on looser surfaces of gravel, dirt, or sand. Traction on muddier surfaces depends on the aggressiveness of treads available, but many 275/60R20 all-terrain tires possess adept grip without making the tire perform like it’s from the pits of hell.
Another pro of the size is sidewall performance. Because it’s a 60-series sidewall, you’ll have a more capable and protective sidewall compared to shorter counterparts. That means the risk of loss to puncture wounds when fighting off rocks or jagged terrains is less. This is why the size in question works for those looking to dabble in light off-roading. The size ranks among the ultimate tire sizings for diagonal crossing and crater dodging that overlanding truck owners and adventure pickup fans find so appealing.
All-terrain and mud-terrain tires are two areas that tire-spec nerds love to draw lines through when comparing. For those mudding a rut, 275/60R20 has things to offer in the all-terrain vs. mud-terrain debate via the tractor-tread side of things.
Fuel Economy and Lifespan: What to Know for Everyday Life
It’s easier to think of plus-size 275/60R20 tires as thirstier than narrower equivalents, but the best 275/60R20 tires are rather good at conserving fuel when cared for properly. However, running 275/60R20 tires on your SUV or truck probably will reduce its fuel economy. I mean, slightly wider tires can’t be more fuel-efficient than their narrow counterparts — right? Contemporary rubber technology and manufacturing methods, as well as some choice design features, do help shave off drag. When all factors come into play, 275/60R20 fuel economy loss isn’t as pitiful as you’d think. SUVs and trucks are built to guzzle gas anyway, wider 275/60R20 tires or not.
275/60R20 tire durability isn’t the subject of many exaggerations, because, in all honesty, much larger tires bring much larger issues. That doesn’t mean that 275/60R20 tire longevity is bad, though. Properly maintained (rotated every 5,000 to 6,000 miles, aligned, and inflated evenly), almost any of the 275/60R20 tires out there can last you a good long time. A taller sidewall is your best friend when dodging potholes and driving through ditches. A little extra padding in the sidewall does wonders for 275/60R20 tires, and you’ll even forget that you don’t have regular all-season tires.
Conclusion: Is 275/60R20 for You?
275/60R20 is the Goldilocks SUV plus-size. Today’s overly cushy SUVs and bare-knuckle pickups enjoy the benefits of an ever-so-slightly wider tire. The wider track only increases stability, and the big sidewall takes the drama out of things. Because the market’s full of all-terrain tires for 275/60R20s, there’s hardly a quicker setup on the market for an A-to-B vehicle. All-terrains are on-road compatible and slightly less useless than the regular all-season (road-biased) 275/60R20 tires. Transporting your vehicle during winter requires some extra work in some cases. If all-around performance sounds like your cup of tea, you’d better keep 275/60R20 tires in the wallpaper.
