2020-2026 Jeep Wrangler XE, Grand Cherokee XE Recall: 320K Battery Fault Can Cause Fire
Cory Casciato
Cory Casciato
November 7, 2025
Both Jeep Wrangler XE models like this one, and Grand Cherokee XE models, are facing a recall due to battery issues (Photo courtesy of Stellantis)
A recall for 320K Jeep Wrangler 4XE and Grand Cherokee 4XE vehicles has been announced. The battery may fail, leading to a vehicle fire.
2020-2025 Wrangler XE and 2022-2026 Grand Cherokee XE Models Affected
Just over 228K Wrangler XE models from 2020-2025 and almost 92K Grand Cherokee models from 2022-2026 are affected by the recall, which is caused by manufacturing faults in the high-capacity battery used in these models. Similar models are not affected. The faults may cause the battery to catch fire while driving or parked. Because the danger is lower when the battery has a low charge, Stellantis is advising owners not to charge the batteries until the issue can be fixed. Out of an abundance of caution, owners are also advised not to park near other structures or vehicles. No fix is currently available.
NHTSA.gov has the official recall information as follows:
NHTSA ID Number: 25V741000
Manufacturer: Chrysler (FCA US, LLC)
Components: ELECTRICAL SYSTEM
Potential Number of Units Affected: 320065
Estimated percentage with defect: 5%
Descriptive Information:
Some 2020-2025MY Jeep Wrangler plug-in hybrid electric vehicles (“PHEVs”) may have been built with a high voltage (“HV”) battery pack manufactured with cells which may be susceptible to separator damage.
The suspect vehicle population began on July 1, 2020, when PHEV production began, and ended on August 25, 2025, when the last vehicle with a suspect HV battery was built. Vehicle manufacturing records were used to determine the suspect period.
Similar vehicles not included in this recall are not PHEVs.
Some 2022-2026MY Jeep Grand Cherokee PHEVs may have been built with a HV battery pack manufactured with cells which may be susceptible to separator damage.
The suspect vehicle population began on July 23, 2021, when PHEV production began, and ended on October 15, 2025, when the last vehicle with a suspect HV battery was built. Vehicle manufacturing records were used to determine the suspect period.
Identification of any warning that can occur: None
Remedy:
Owners are advised to park outside and away from structures and not to charge their vehicles until the remedy is completed. The remedy is currently under development. Interim notification letters explaining the safety risk are expected to be mailed December 2, 2025. Additional letters will be sent once the final remedy is available. Owners may contact Chrysler customer service at 800-853-1403. Chrysler’s number for this recall is 68C. Vehicle Identification Numbers (VINs) involved in this recall will be searchable on NHTSA.gov beginning November 6, 2025. Vehicles that were previously recalled for the same issue under NHTSA Recalls 24V720 and 23V787 will need to have the new remedy performed.
Chronology
On July 3, 2025, the FCA US LLC (“FCA US”) Technical Safety and Regulatory Compliance (“TSRC”) organization opened an investigation after receiving reports of fires originating from the HV battery in certain Jeep Wrangler PHEVs and Jeep Grand Cherokee PHEVs outside the scope of FCA US Recall ID 95B (NHTSA ID 24V-720) (“95B”), as well as reports of fires originating from the HV battery pack in vehicles which have received the 95B remedy. Samsung SDI obtained a battery pack from a vehicle which experienced a HV battery fire with cells manufactured outside the scope of 95B. After fully analyzing the battery pack, Samsung SDI determined the fire was caused by the same defect reported in the previous 95B campaign and has been working to identify additional factors potentially relating to root cause.
As of October 13, 2025, FCA US has received 9 reports of fires originating from the HV battery in Jeep Wrangler and Jeep Grand Cherokee vehicles which have received the 95B remedy software. FCA US has determined the 95B remedy is ineffective at detecting certain abnormalities within the HV battery which may lead to a fire.
As of October 13, 2025, FCA US is aware of 10 fires originating from HV batteries which have cells manufactured outside the scope of 95B. Samsung SDI has stated the most likely root cause is separator damage combined with other complex interactions within the cell. FCA US and
Samsung SDI continue to investigate potential factors relating to root cause.
As of October 13, 2025, FCA US is aware of 19 customer assistance records, 0 warranty claims, and 19 field reports potentially relating to this issue for all markets with dates of receipt ranging from January 27, 2025, to September 2, 2025.
As of October 13, 2025, FCA US is aware of 1 injury and 0 accidents potentially related to this issue for all markets.
On October 24, 2025, FCA US determined, through the Vehicle Regulations Committee, a defect affecting motor vehicle safety potentially exists in all affected vehicles.
Related NHTSA Recall Number: 24V720
For more information, and to see if your vehicle is affected, visit NHTSA.gov.
