Are Leather Seats in Trucks Going Away? Automakers Getting Cheap?
August 18, 2025
23 comments
Leather Seats in Trucks 1
New truck interiors are now filled with bigger screens, new technology and digital driver displays. However, if you want real leather seats, you better be prepared to pay a lot more money for a new truck. (Photo courtesy Transwest Ford Scottsbluff)
A new truck trend lately has seen leather seats replaced with leather-like leaving just the high-end trucks with true leather. What gives?
Leather Seats in Trucks 3
Cloth bench seats used to be the norm and if you got leather, people knew you paid extra. (Photo by Tim Esterdahl)
For years, trucks seats came in really two setups with two choices. You either had a bench seat or bucket seats and you either had cloth or leather.
The bench seat with cloth was the work truck. While the bucket seat with leather was the fancier truck.
Leather was seen as the premium or luxury truck.
Essentially, you had two choices and two trim levels of trucks. Simple. Easy.
Somewhere along the way, trucks started becoming a lot more complex and now there are not just two trim levels offered, there are a dozen with different packages, options and a ton of different choices. Heck even the headliner of some trucks can be made of suede.
Leather-Like Seats?
Leather Seats in Trucks 2
This 2025 Ford F-150 Lariat doesn’t come with leather seats anymore and that could be quite the surprise for some folks. (Photo by Tim Esterdahl)
Leather, though, was still leather. Sure there was a phase of time where a material called pleather or artificial leather made its debut in passenger cars, but trucks were different.
If you got in say a Ford King Ranch edition, you wanted to smell the leather or a sport truck like the 2025 Ram 1500 RHO. The same thing with a Tundra 1794 edition. The leather was specifically chosen for the way it felt, smoothness and the smell.
Consumers expected this to be the case as well. They knew you had the work truck, the base consumer grade with cloth and the next grade or trim level up would have leather seats.
However, that’s not the case. I recently stopped at my local Ford dealership, Transwest Scottsbluff, after fans of this outlet pointed out the 2025 Ford F-150 Lariat doesn’t have leather seats anymore. A $65,000 F-150 Lariat without leather seats? Yup. It has “ActiveX” as I show in this TikTok video.
Ford says these seats are a synthetic leather alternative and it has been around for a few years in their SUVs and the Ford Maverick. They are supposedly more durable, resistant to staining, fading and temperature changes. They shouldn’t burn your legs in the summer or be cold in the winter.
It doesn’t use cow hides instead it used recycled plastic bottles to create the material.
Ford does offer leather, but you have to step up into the higher trim levels like the Platinum trim starting at $74,905 to get them. This is quite the step up from the base XLT which starts around the mid $40k for a regular cab and $50k for a crew cab.
Other Brands Don’t Use Leather Either?
Leather Seats in Trucks 4
These “softex” seats in Toyota vehicles has replaced leather seats and is synthetic leather. (Photo by Tim Esterdahl)
Ford isn’t alone in not using leather.
Toyota uses Softex and leather-trimmed seats until you get into their higher-trim levels. Ram has leather-trimmed seats and reserves its best leather for the higher-trim levels like the Toyota 1794 or Capstone trim.
GM is the only automaker I found that still offers leather seats in the middle trim levels with premium leather in the higher trim levels.
Why is Leather Going Away?
Leather Seats in Trucks 6
Real leather seats are increasingly only found in the highest trim levels like this 2025 Ram 1500 RHO. (Photo by Tim Esterdahl)
A few factors are causing leather to go away that are obvious and not so obvious.
The first is cost. That’s always a factor. Automakers have a profit margin to hit and a price point they need to stay under to be competitive. As they add more feature consumers want like more technology and capability, they have to cut somewhere they don’t think consumers care as much about. If they can offer a leather-like seating material with the benefits stated above and consumers don’t complain, then why not?
Second, weight. Payload on full-size trucks has been a problem in recent years. Adding more stuff in the cabin (screens, massaging seats, dual-pano moonroofs, etc…) adds weight. As you add stuff, you subtract from what the truck can carry in terms of people, their gear and what the truck can tow with all that stuff in total. Basically, the truck’s capability goes down.
What do you do? You can’t beef up the frame to accommodate the weight without sacrificing ride comfort. And you don’t want to take away the stuff consumers are shopping for when buying a new truck.
So, you remove where you can and since leather is heavy, it is an easy target.
For the higher-end luxury trucks, you can keep leather since the customer expectation is different. Let’s be real, that customer isn’t going to haul a bed full of paving stones every day.
Leather Seats in Trucks 7
Imagine spending $65k for a truck and finding out that doesn’t even get you real leather seats anymore. (Photo courtesy Transwest Ford Scottsbluff)
The fact is some people are going to irate at the idea they are now going to be spending $65,000 on a new truck that doesn’t come with leather seats when just 10 years ago that truck was $50,000 with leather (insert your own year and price).
That’s the quick judgement on price and seating material.
They will miss the fact the truck itself has changed dramatically in that timeframe and the truck they bought 10 years ago doesn’t really exist today. Has their truck needs changed? Not likely. The truck world has changed and whether that’s a good or bad thing is just how you see it.
2,850 messages 4,744 likes
A new truck trend lately has seen leather seats replaced with leather-like leaving just the high-end trucks with true leather. What gives? Leather Seats in Trucks For years, trucks seats came in really two setups with two choices. You either had a bench seat or bucket seats and you either had cloth or leather. The bench seat with cloth was the work truck. While the bucket seat with leather was the fancier truck. Leather was seen as the premium or luxury truck. Essentially, you had two choices and two trim levels of trucks. Simple. Easy. Somewhere along the way, trucks […] (read full article...)
Avatar of Hilux
Hilux
Well-known member
473 messages 786 likes
Cloth seats all the way.
Reply 5 likes
Avatar of TheDo114
TheDo114
Well-known member
779 messages 1,219 likes
Amen
D
Dusdaddy
Well-known member
1,387 messages 2,060 likes
Well, for Ram, it used to be that only the Limited/Longhorn got all leather seats. Laramie and below got leather seating surfaces only. That's what I have. Not sure what it is now. They bury it in the fine print somewhere.
I'd still rather have quality cloth. Or at least cloth on the seating surfaces and the sides can be anything that durable. My leather wore and cracked on the wings from sliding in and out because I never got running boards.
Reply 3 likes
R
Rotten.dalton
Active member
109 messages 223 likes
I like leather and I was very disappointed that my 23 Tundra Limited had softex(synthetic) seats. Yes, that seemed like a cheap out to me.
Avatar of James-kd2cm
James-kd2cm
Well-known member
230 messages 415 likes
I prefer cloth seats. If I could have gotten the options I wanted on my 23 RAM sport (Canada) and still get cloth seats I would have. I use seat covers during cottage season due to all of the outdoor work I do from spring through late fall (chainsawing etc). Then I take them off in the winter. Just too many foreign substances getting brought into the cab (by me) in the summer. I used seat covers on my last 2 trucks as well over my cloth seats. The result is the seats look great at trade in time…lol. I don’t have cooled seats.
Reply 3 likes
Avatar of Fightnfire
Fightnfire
Moderator
1,259 messages 2,162 likes
Hmm, I love my leather seats. There are alot of different seat materials out there now, it's not just cloth and leather. The "cloth" of the 90's and 00's was garbage and failed constantly. Most manufacturers started moving towards different materials years ago and we just keep calling them cloth. Not all cloth is the same. Some of them are great and hold up extremely well to wear, stains etc.
I'll take leather all day though. The new vehicles heat up, and cool down, much quicker than back in the day. I don't want to run any sort of seat cover, I did that for years on cloth seats and they all look like garbage after a while. Leather is durable and easy to clean.
A viewer yesterday was telling me he is positive the 2026 Tundra Limited will go back to real leather. I'll believe it when I see it. He says the dealer agrees with him. I just can't see that big of a change without a full refresh, but I guess stranger things have happened.
Avatar of TheDo114
TheDo114
Well-known member
It’s part of the update for the 2026 tundra.
Straight from the press release: IMG_8087.png
Straight from the press release: View attachment 1052
Dang it. Using facts to prove me wrong. LOL
S
Saddle Tramp
Moderator
1,111 messages 1,229 likes
For those that prefer leather, how often are you conditioning it and what product do you use?
I'm not a leather fan but if I had it, I'd condition it with pure mink oil just to be sure.
Mink oil works great on boots but does darken the leather.
Reply Like
