SUVs and trucks: Improvement in performance by advanced spring testing
Tokyo Auto Salon 2022 spring suspension testing
There’s overkill, and then there are the Suzuki Jimny builds from companies like N’s Style. A quick peek underneath proves that this rig does indeed get thrashed in the wild, as rock trips and scratches were in abundance. Just the sort of thing we like to see on purpose-built 4×4 vehicles.
With their versatility, power, and comfort, SUVs and trucks continue to grow in popularity, with car manufacturers continuously bringing new products and refreshed generations to market.
Forever looking to enhance the performance, handling, and ride quality of these vehicles, these developments require the reengineering of advanced suspension systems, with spring technology and testing methods being one of them.
The importance of suspension systems
Suspension systems form the very backbone of performance and comfort in SUVs and trucks. These systems handle vehicle stability, absorb road shock and vibrations, maintain proper wheel alignment, and provide for smooth cornering and handling. Of course, at the heart of any suspension system are springs that carry the weight of the vehicle and absorb most of the impact from road irregularities.
Spring technology: A key component
Suspension springs are arguably the most critical component in suspension, as their design and performance determine the vehicle’s ride quality and handling characteristics. Following are the types of springs used in SUVs and trucks:
  1. Coil springs: The most common type, which provides a good balance between performance and comfort
  2. Leaf springs: Often used in heavy-duty trucks for their load-bearing capacity
  3. Air springs: Offering adjustable ride height and comfort levels
  4. Torsion bars: Compact design suitable for certain smaller vehicle layouts
The characteristics, advantages, and restrictions of each style of suspension vary with the type of spring utilized. Each has to be carefully chosen and tuned by the manufacturer to attain the correct performance in a vehicle.
The role of spring rate in vehicle performance
Of all the factors pertaining to spring performance, the most critical would be the spring rate, which may be defined as the force needed to compress the spring through a specified distance. The spring rate influences a range of vehicle performances, including:
  • Ride comfort
  • Handling responsiveness
  • Load carrying capacity
  • Body roll when cornering
Engineers have a very fine line to walk when determining the perfect spring rate for a vehicle. Higher spring rates improve handling and reduce body roll while making for a harsher ride. Lowering the spring rate improves comfort at the cost of handling and stability.
Advanced spring testing techniques
In search of the perfect balance between performance and comfort, auto manufacturers hone their spring designs to perfection with an indispensable tool: the spring rate tester.
A spring rate tester is a precision instrument that measures the force-deflection characteristics of a spring with high accuracy. Here are some of the perks of using this device:
  • Determine the exact spring rate at various points of compression
  • Identify spring behavior non-linearities
  • Verify consistency that can be reproduced between groups of several springs
  • Empirical data to validate computer simulations and theoretical calculations
Most modern spring rate testers are designed to be computer-controlled and have the capability to deliver very accurate and repeatable measures. This level of accuracy is becoming increasingly significant in optimizing suspension performance for SUVs and trucks, as even minor variations can sometimes produce identifiable changes in ride quality and handling.
Benefits of advanced spring testing
Advantages of using a competent testing device like a spring rate tester during SUV and truck development include:
  1. Ride Quality: The manufacturer can employ precisely tuned spring rates offering a smooth ride without any loss in handling performance.
  2. Better Handling: With accurate spring rate data, engineers are allowed to fine-tune suspension characteristics for better cornering, stability, and overall driving dynamics.
  3. Stronger construction: Comprehensive testing points to possible weak spots in the design of springs, resulting in components that are much stronger and last longer.
  4. Tuned carrying capacity: For trucks and SUVs that have been designed to carry heavy loads, the precise testing of the spring rate allows the suspension to maintain proper ride height and stability under a variety of loading conditions.
  5. Better consistency: Higher-order testing methods assist manufacturers in providing consistent quality within their production runs.
Future developments in suspension technology
Just as SUVs and trucks are constantly evolving, so too is the technology involved in the development and testing of these vehicles. Some developing trends in this field include adaptive suspension systems, which employ active electronic controls to tweak spring rates and damping characteristics in real time. This provides the perfect balance between comfort and performance in any driving condition. Furthermore, machine learning and AI can now analyze massive volumes of data derived from spring rate testers and other test instruments far more rapidly and with greater accuracy than humans, thus optimizing suspension designs.
  • Interfacing with other vehicle systems: Future suspension systems may interface with steering, braking, and powertrain systems to provide a more rounded approach to the driving dynamics of a vehicle.
  • Materials innovation: New alloys and composite materials may someday allow springs to perform better and reduce weight.
It is through improved suspension technologies and testing methods that SUVs and trucks improve. By employing advanced tools such as spring rate testers, manufacturers can keep pushing the performance, comfort, and versatility envelope in virtually any popular vehicle category.
With consumers continuing to insist on vehicles that combine on-road refinement with off-road capability, the requirement for very specific suspension tuning is more critical than ever before. Thanks to tough testing and innovative design, the next generation of SUVs and trucks promise an even more impressive blend of comfort, performance, and functionality.
