How often should you service a Land Rover?
LS3 Powered Custom $100k+ Land Rover Defender from Fusion Motor Company
The Land Rover has been a fan favorite for those on the hunt for off-road adventures around the world. With unparalleled off-roading capabilities and a close-to-indestructible design, it feels right to say that these vehicles are incredible!
But even the strongest machines need refreshing now and then; it’s just a matter of when. So, how often does a Land Rover need to be serviced? Every year? Every three months?
So, how often should you service your Land Rover?
Once you’re a Landy owner, there’s no turning back. Land Rovers make people feel like they can literally go anywhere, which is partly true. But to keep your Land Rover capable of overcoming all-terrain, it needs to be well maintained. This means catching issues early and staying on top of the fundamental parts, so they work in optimum condition.
In terms of the interior, you can get away with giving it a good clean every two weeks or so. Adding some chair covers would be a nice touch as well. It’s not the interior you have to watch out for, though. It’s everything else.
Neglecting to service your Landy regularly will cause issues to worsen. For example, after a while, your shocks might need a change. If you don’t change them, they’ll cause other parts to loosen, rattle, and possibly cause more damage. On average, Land Rovers can go for about 25,000km comfortably before they need a service. With some, you can push this figure to 30,000km, but we wouldn’t suggest it. Dealers will usually suggest that you bring your Rover in at around 19,000km just to be safe.
Why should I service my Land Rover?
You want to keep tackling the outdoors, right? Well then, there’s your answer. We’re just being facetious, but seriously, keeping up with servicing your Rover is what will keep it on the road.
Often, people fall behind on services when their original service plans expire. As a result, they’re stuck with issues that will cost them a pretty penny to fix. But if you aim to keep your Land Rover in the best possible condition, it’ll serve you for a lifetime!
What happens in a basic Land Rover service?
When you take your Landy in for a service, the mechanics will do a series of checks to see what needs to be done. The checks will differ depending on what kind of service you’ve gone in for. A basic service will just cover the basics, like spark plugs, oil changes, and air filter replacements. A full-service covers everything from brakes to suspension. Here is a list of the things a service would cover:
  • Bodywork
  • Air filters
  • Engine oil
  • Oil filters
  • Lights bulb replacements
  • Tires
  • Suspension and shock absorbers
  • Exhaust
  • Steering realignment
  • Brakes
  • Fluid and coolant levels
  • Battery testing
There’s no guarantee that all of these parts will be addressed in full service. Most mechanics run on a system that doesn’t change something if it isn’t broken. So, if some of these parts are still in good condition, they’ll be left for the next service. They may also find other issues with your Landy during the service. In this case, the mechanic would get a hold of you to ask if they should proceed with fixing it if they can or whether you want to book it for another day.
How much does a Land Rover service cost?
The price for servicing a Land Rover will depend on a few factors. For one, it’ll depend on who you go to. Independent mechanics will usually charge you a lower fee for a service, but they might not provide you with the same quality service as a certified service center would. Certified Land Rover service centers have Land Rover technicians who are specially trained to work on and repair Landy’s. They’ll have the right tools, access to the original parts, and the knowledge to get repairs done efficiently and correctly. But they typically cost extra.
Frequently asked questions
Can you service your Land Rover yourself?
While it’s not suggested, you can service your Land Rover yourself. There are simple tasks that can be done in your garage at home like changing a spark plug, putting in a new lightbulb, and changing the air filter. But when it comes to mechanical maintenance we’d suggest going to a professional.
What are the signs that your Land Rover needs a service?
There are some pretty obvious signs that any Land Rover fanatic would pick up on pretty quickly. Here are some of them:
  • Strange noises or vibrations while driving
  • Warning lights on the dashboard
  • Using more fuel
  • Difficulty starting the engine
  • Changes in handling or braking performance
Can you use aftermarket parts for your Landy?
As a general rule of thumb, original parts are always better. But they’re not always available. So, for older Land Rover models, yes. Parts for older models that aren’t being manufactured anymore can be difficult to find. So, if you can find aftermarket parts for them, then use them. But for newer models, we’d suggest you stick to the original parts. This will ensure that your Landy performs well and lasts longer.
